DS 5.0
Jetson NX
Is it possible to run segmentation model on live rtsp source using DS 5.0?
If yes how?
Hi
You can refer to the TLT (Transfer Learning Toolkit) which has a segmentation model as an example and the generated engine for DS. However, DS does not have support for segmentation metadata and overlaying.
You would need to implement a custom solution to handle the segmentation information.
Regards
Angel
