How can i get the x,y,z location of the detected object ?
Is that possible using DeepStream?
Hi
Here is deepstream application architecture, you also can get from here, NVIDIA DeepStream SDK Developer Guide — DeepStream 6.1.1 Release documentation, we have metadata associated with each frame, by iterating metadata you can get detetected objects coordinates. NVIDIA Metropolis Documentation
Hello amycao
I can get the output of DeepStream the detected object location ,bounding box in this form (Top,Bottom,Left,Right) . IS there a way to have the 3d location of the object on space with respect to camera coordinate frame like (x,y,z) or not
I think you’ll have map the screen coordinates to real world. XY plane is probably not too hard if the ground is flat. Z could be considerably harder.
I think Nvidia has a smart parking demo app you could look at. I haven’t looked at it myself but there’s probably some code in there you can reuse.
I just had a look. Seems there’s a tracker written in Python you could re-implement in whatever. It can get you the XY coordinates of cars. You can probably adapt it to whatever you want to do.
