Deepstream with triton is stuck and not outputting anything
• Hardware Platform (Jetson / GPU) → NVIDIA GeForce GTX 1650
• DeepStream Version → 6.1-triron
• JetPack Version (valid for Jetson only) N/A
• TensorRT Version → NA
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA driver 510.85.02
| NVIDIA-SMI 510.85.02    Driver Version: 510.85.02    CUDA Version: 11.6     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  On   | 00000000:01:00.0  On |                  N/A |
| N/A   53C    P3    15W /  N/A |    895MiB /  4096MiB |     15%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1672      G   /usr/lib/xorg/Xorg                 69MiB |
|    0   N/A  N/A    352982      G   /usr/lib/xorg/Xorg                467MiB |
|    0   N/A  N/A    353212      G   /usr/bin/gnome-shell               58MiB |
|    0   N/A  N/A    353851      G   ...AAAAAAAAA= --shared-files       38MiB |
|    0   N/A  N/A    358772      G   ...878537524551413047,131072      119MiB |
|    0   N/A  N/A    369298      G   ...RendererForSitePerProcess       91MiB |
|    0   N/A  N/A    539011      G   ...AAAAAAAAA= --shared-files       16MiB |
|    0   N/A  N/A    571607      G   ...649167501785457681,131072       19MiB |
• Issue Type( questions, new requirements, bugs) Question
I’ve been trying to deploy yolov5 with onnxruntime backend using deepstream and triton
Here are the inputs you may need,
Image used:
nvcr.io/nvidia/deepstream     6.1-triton                 28776904eac1
Main file is: deepstream_yolo.py
deepstream_yolo.py (15.5 KB)
yolo_parser.py for post-processing
yolo_parser.py (11.4 KB)
nms.py
nms.py (3.7 KB)
yolov5 model configuration
yolov5_nopostprocess.txt (811 Bytes)
Also the pbtxt file:
config.pbtxt (306 Bytes)
And the labels file:
yolov5_labels.txt (629 Bytes)
After running the application:
python3 deepstream_yolo.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_1080p_h264.mp4
This is the output I’m getting:
deepstream_yolo.py:281: PyGIDeprecationWarning: Since version 3.11, calling threads_init is no longer needed. See: https://wiki.gnome.org/PyGObject/Threading
  GObject.threads_init()
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating NvStreamMux
Creating Nvinferserver
Creating Nvvidconv
Creating OSD (nvosd)
Creating Queue
Creating Converter 2 (nvvidconv2)
Creating capsfilter
Creating Encoder
Creating Code Parser
Creating Container
Creating Sink
Playing file /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_1080p_h264.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
deepstream_yolo.py:397: PyGIDeprecationWarning: GObject.MainLoop is deprecated; use GLib.MainLoop instead
  loop = GObject.MainLoop()
Starting pipeline
WARNING: infer_proto_utils.cpp:201 backend.trt_is is deprecated. updated it to backend.triton
I0831 13:53:46.753136 1354 libtorch.cc:1309] TRITONBACKEND_Initialize: pytorch
I0831 13:53:46.753158 1354 libtorch.cc:1319] Triton TRITONBACKEND API version: 1.8
I0831 13:53:46.753163 1354 libtorch.cc:1325] 'pytorch' TRITONBACKEND API version: 1.8
2022-08-31 13:53:46.826130: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
2022-08-31 13:53:46.852126: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
I0831 13:53:46.852177 1354 tensorflow.cc:2176] TRITONBACKEND_Initialize: tensorflow
I0831 13:53:46.852189 1354 tensorflow.cc:2186] Triton TRITONBACKEND API version: 1.8
I0831 13:53:46.852193 1354 tensorflow.cc:2192] 'tensorflow' TRITONBACKEND API version: 1.8
I0831 13:53:46.852197 1354 tensorflow.cc:2216] backend configuration:
{"cmdline":{"allow-soft-placement":"true","gpu-memory-fraction":"0.800000"}}
I0831 13:53:46.870268 1354 onnxruntime.cc:2319] TRITONBACKEND_Initialize: onnxruntime
I0831 13:53:46.870281 1354 onnxruntime.cc:2329] Triton TRITONBACKEND API version: 1.8
I0831 13:53:46.870284 1354 onnxruntime.cc:2335] 'onnxruntime' TRITONBACKEND API version: 1.8
I0831 13:53:46.870286 1354 onnxruntime.cc:2365] backend configuration:
I0831 13:53:46.898280 1354 openvino.cc:1207] TRITONBACKEND_Initialize: openvino
I0831 13:53:46.898296 1354 openvino.cc:1217] Triton TRITONBACKEND API version: 1.8
I0831 13:53:46.898300 1354 openvino.cc:1223] 'openvino' TRITONBACKEND API version: 1.8
I0831 13:53:46.955826 1354 pinned_memory_manager.cc:240] Pinned memory pool is created at '0x7f0654000000' with size 268435456
I0831 13:53:46.955982 1354 cuda_memory_manager.cc:105] CUDA memory pool is created on device 0 with size 67108864
I0831 13:53:46.956281 1354 server.cc:524]
| Repository Agent | Path |
I0831 13:53:46.956319 1354 server.cc:551]
| Backend     | Path        | Config        |
| pytorch     | /opt/tritonserver/backends/pytorch/libtriton_pytorch.so                 | {}        |
| tensorflow  | /opt/tritonserver/backends/tensorflow1/libtriton_tensorflow1.so         | {"cmdline":{"allow-soft-placement":"true","gpu-memory-fraction":"0.800000"}} |
| onnxruntime | /opt/tritonserver/backends/onnxruntime/libtriton_onnxruntime.so         | {}        |
| openvino    | /opt/tritonserver/backends/openvino_2021_4/libtriton_openvino_2021_4.so | {}        |
I0831 13:53:46.956333 1354 server.cc:594]
| Model | Version | Status |
I0831 13:53:46.983453 1354 metrics.cc:651] Collecting metrics for GPU 0: NVIDIA GeForce GTX 1650
I0831 13:53:46.983729 1354 tritonserver.cc:1962]
| Option                           | Value        |
| server_id                        | triton        |
| server_version                   | 2.20.0        |
| server_extensions                | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_ |
|                                  | memory binary_tensor_data statistics trace        |
| model_repository_path[0]         | /opt/nvidia/deepstream/deepstream-6.1/sources/project        |
| model_control_mode               | MODE_EXPLICIT        |
| strict_model_config              | 0        |
| rate_limit                       | OFF        |
| pinned_memory_pool_byte_size     | 268435456        |
| cuda_memory_pool_byte_size{0}    | 67108864        |
| response_cache_byte_size         | 0        |
| min_supported_compute_capability | 6.0        |
| strict_readiness                 | 1        |
| exit_timeout                     | 30        |
I0831 13:53:46.984552 1354 model_repository_manager.cc:997] loading: yolov5:1
I0831 13:53:47.084792 1354 onnxruntime.cc:2400] TRITONBACKEND_ModelInitialize: yolov5 (version 1)
I0831 13:53:47.085489 1354 onnxruntime.cc:614] skipping model configuration auto-complete for 'yolov5': inputs and outputs already specified
I0831 13:53:47.086393 1354 onnxruntime.cc:2443] TRITONBACKEND_ModelInstanceInitialize: yolov5 (GPU device 0)
W0831 13:53:47.986790 1354 metrics.cc:427] Unable to get power limit for GPU 0. Status:Success, value:0.000000
I0831 13:53:48.817166 1354 model_repository_manager.cc:1152] successfully loaded 'yolov5' version 1
INFO: infer_trtis_backend.cpp:206 TrtISBackend id:5 initialized model: yolov5
W0831 13:53:48.986964 1354 metrics.cc:427] Unable to get power limit for GPU 0. Status:Success, value:0.000000
W0831 13:53:49.988451 1354 metrics.cc:427] Unable to get power limit for GPU 0. Status:Success, value:0.000000
Killed
The script could run for hours if left without killing it, and the output is always a file of size 0 bytes.
EDIT:
I also included the output of :
 nvidia-smi -q -d POWER
Here:
==============NVSMI LOG==============
Timestamp                                 : Wed Aug 31 16:24:15 2022
Driver Version                            : 510.85.02
CUDA Version                              : 11.6
Attached GPUs                             : 1
GPU 00000000:01:00.0
    Power Readings
        Power Management                  : N/A
        Power Draw                        : 6.55 W
        Power Limit                       : N/A
        Default Power Limit               : N/A
        Enforced Power Limit              : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Power Samples
        Duration                          : Not Found
        Number of Samples                 : Not Found
        Max                               : Not Found
        Min                               : Not Found
        Avg                               : Not Found
  1. there are many tritonserver logs, but from your configuration file, you will start triton native. did you succeed to run deepstream sample deepstream-ssd-parser ? here is the link: deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
  2. you can refer to deepstream onnxruntime sample, the path: /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app-triton/source1_primary_classifier.txt, please set config-file=config_infer_primary_classifier_densenet_onnx.txt
1. As for the sample deepstream-ssd-parser
Here’s how I ran the sample:
python3 deepstream_ssd_parser.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_1080p_h264.mp4
There are absolutely no errors, but nothing is processing either, nvidia-smi shows no use of GPU what so ever and the output from the pipeline (out.mp4) is 0 bytes in size.
And here’s the log:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating Nvvidconv
Creating Queue
Creating capsfilter
Creating Encoder
Creating Container
Creating Sink
Starting pipeline
I0904 10:11:15.922192 361 libtorch.cc:1309] TRITONBACKEND_Initialize: pytorch
I0904 10:11:15.922209 361 libtorch.cc:1319] Triton TRITONBACKEND API version: 1.8
I0904 10:11:15.922212 361 libtorch.cc:1325] 'pytorch' TRITONBACKEND API version: 1.8
2022-09-04 10:11:15.991721: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
2022-09-04 10:11:16.016621: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
I0904 10:11:16.016660 361 tensorflow.cc:2176] TRITONBACKEND_Initialize: tensorflow
I0904 10:11:16.016670 361 tensorflow.cc:2186] Triton TRITONBACKEND API version: 1.8
I0904 10:11:16.016673 361 tensorflow.cc:2192] 'tensorflow' TRITONBACKEND API version: 1.8
I0904 10:11:16.016677 361 tensorflow.cc:2216] backend configuration:
{"cmdline":{"allow-soft-placement":"true","gpu-memory-fraction":"0.400000"}}
I0904 10:11:16.035775 361 onnxruntime.cc:2319] TRITONBACKEND_Initialize: onnxruntime
I0904 10:11:16.035795 361 onnxruntime.cc:2329] Triton TRITONBACKEND API version: 1.8
I0904 10:11:16.035799 361 onnxruntime.cc:2335] 'onnxruntime' TRITONBACKEND API version: 1.8
I0904 10:11:16.035801 361 onnxruntime.cc:2365] backend configuration:
I0904 10:11:16.046240 361 openvino.cc:1207] TRITONBACKEND_Initialize: openvino
I0904 10:11:16.046253 361 openvino.cc:1217] Triton TRITONBACKEND API version: 1.8
I0904 10:11:16.046256 361 openvino.cc:1223] 'openvino' TRITONBACKEND API version: 1.8
I0904 10:11:16.100710 361 pinned_memory_manager.cc:240] Pinned memory pool is created at '0x7f348e000000' with size 268435456
I0904 10:11:16.100856 361 cuda_memory_manager.cc:105] CUDA memory pool is created on device 0 with size 67108864
I0904 10:11:16.101228 361 server.cc:524]
I0904 10:11:16.101265 361 server.cc:551]
| tensorflow  | /opt/tritonserver/backends/tensorflow1/libtriton_tensorflow1.so         | {"cmdline":{"allow-soft-placement":"true","gpu-memory-fraction":"0.400000"}} |
I0904 10:11:16.101281 361 server.cc:594]
I0904 10:11:16.126865 361 metrics.cc:651] Collecting metrics for GPU 0: NVIDIA GeForce GTX 1650
I0904 10:11:16.127152 361 tritonserver.cc:1962]
| Option                           | Value        |
| server_extensions                | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_memory binar |
| model_repository_path[0]         | /opt/nvidia/deepstream/deepstream-6.1/samples/triton_model_repo        |
| rate_limit                       | OFF        |
| exit_timeout                     | 30        |
I0904 10:11:16.127963 361 model_repository_manager.cc:997] loading: ssd_inception_v2_coco_2018_01_28:1
I0904 10:11:16.228394 361 tensorflow.cc:2276] TRITONBACKEND_ModelInitialize: ssd_inception_v2_coco_2018_01_28 (version 1)
I0904 10:11:16.231778 361 tensorflow.cc:2325] TRITONBACKEND_ModelInstanceInitialize: ssd_inception_v2_coco_2018_01_28_0 (GPU device 0)
W0904 10:11:17.128718 361 metrics.cc:427] Unable to get power limit for GPU 0. Status:Success, value:0.000000
2022-09-04 10:11:17.471737: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 2499950000 Hz
2022-09-04 10:11:17.472385: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x7f33e74ea800 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2022-09-04 10:11:17.472433: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): Host, Default Version
2022-09-04 10:11:17.473526: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcuda.so.1
2022-09-04 10:11:17.473798: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-09-04 10:11:17.474016: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x7f33ddb382c0 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2022-09-04 10:11:17.474031: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): NVIDIA GeForce GTX 1650, Compute Capability 7.5
2022-09-04 10:11:17.474312: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-09-04 10:11:17.474437: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1666] Found device 0 with properties:
name: NVIDIA GeForce GTX 1650 major: 7 minor: 5 memoryClockRate(GHz): 1.68
pciBusID: 0000:01:00.0
2022-09-04 10:11:17.474455: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
2022-09-04 10:11:17.474538: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.11
2022-09-04 10:11:17.474564: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2022-09-04 10:11:17.474586: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2022-09-04 10:11:17.474634: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.11
2022-09-04 10:11:17.474659: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.11
2022-09-04 10:11:17.474680: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2022-09-04 10:11:17.474715: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-09-04 10:11:17.474819: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-09-04 10:11:17.474897: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1794] Adding visible gpu devices: 0
2022-09-04 10:11:17.474917: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1206] Device interconnect StreamExecutor with strength 1 edge matrix:
2022-09-04 10:11:17.474924: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1212]      0
2022-09-04 10:11:17.474929: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1225] 0:   N
2022-09-04 10:11:17.474980: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-09-04 10:11:17.475080: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-09-04 10:11:17.475170: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1351] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 1564 MB memory) -> physical GPU (device: 0, name: NVIDIA GeForce GTX 1650, pci bus id: 0000:01:00.0, compute capability: 7.5)
I0904 10:11:17.593195 361 model_repository_manager.cc:1152] successfully loaded 'ssd_inception_v2_coco_2018_01_28' version 1
INFO: infer_trtis_backend.cpp:206 TrtISBackend id:5 initialized model: ssd_inception_v2_coco_2018_01_28
W0904 10:11:18.128967 361 metrics.cc:427] Unable to get power limit for GPU 0. Status:Success, value:0.000000
W0904 10:11:19.130400 361 metrics.cc:427] Unable to get power limit for GPU 0. Status:Success, value:0.000000
2022-09-04 10:11:19.446272: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2022-09-04 10:11:20.612957: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.11
  1. As for the the deepstream onnxruntime sample, it worked okay
deepstream-app -c source1_primary_classifier.txt
And here’s the log:
(deepstream-app:315): GLib-GObject-WARNING **: 10:09:19.589: g_object_set_is_valid_property: object class 'GstNvInferServer' has no property named 'input-tensor-meta'
0:00:00.149357517   315 0x555913d0e030 WARN           nvinferserver gstnvinferserver_impl.cpp:293:validatePluginConfig:<primary_gie> warning: Configuration file unique-id reset to: 1
2022-09-04 10:09:19.974893: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
INFO: infer_trtis_backend.cpp:206 TrtISBackend id:1 initialized model: densenet_onnx
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:194>: Pipeline ready
WARNING from primary_gie: Configuration file unique-id reset to: 1
Debug info: gstnvinferserver_impl.cpp(293): validatePluginConfig (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInferServer:primary_gie
** INFO: <bus_callback:180>: Pipeline running
**PERF:  FPS 0 (Avg)
**PERF:  37.76 (37.69)
**PERF:  30.01 (31.78)
**PERF:  30.02 (31.01)
**PERF:  29.96 (30.70)
**PERF:  30.00 (30.54)
^C** ERROR: <_intr_handler:140>: User Interrupted..
Quitting
App run successful
How can I proceed from here?
please use h264 file,
python3 deepstream_yolo.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_720p.h264
