• Hardware Platform (Jetson / GPU) : NVIDIA GeForce RTX 3090
• DeepStream Version : 6.3
• TensorRT Version : 12.2
• NVIDIA GPU Driver Version (valid for GPU only) : 535.104.05
using docker container image using deepstream and triton nvcr.io/nvidia/deepstream:6.3-triton-multiarch
when trying to run deepstream-test3
python3 deepstream_test_3.py -i file:///opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_720p.h264 --pgie nvinferserver -c /opt/nvidia/deepstream/deepstream-6.3/samples/configs/tao_pretrained_models/deepstream_app_source1_peoplenet.txt
output
{‘input’: [‘file:///opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_720p.h264’], ‘configfile’: ‘/opt/nvidia/deepstream/deepstream-6.3/samples/configs/tao_pretrained_models/deepstream_app_source1_peoplenet.txt’, ‘pgie’: ‘nvinferserver’, ‘no_display’: False, ‘file_loop’: False, ‘disable_probe’: False, ‘silent’: False}
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
WARNING: Overriding infer-config batch-size 0 with number of sources 1
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
0 : file:///opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_720p.h264
Starting pipeline
[libprotobuf ERROR /workspace/build/_deps/repo-third-party-build/grpc-repo/src/grpc/third_party/protobuf/src/google/protobuf/text_format.cc:335] Error parsing text-format nvdsinferserver.config.PluginControl: 24:1: Extension “application” is not defined or is not an extension of “nvdsinferserver.config.PluginControl”.
0:00:00.156345420 4994 0x34a90f0 WARN nvinferserver gstnvinferserver_impl.cpp:523:start: error: Configuration file parsing failed
0:00:00.156370800 4994 0x34a90f0 WARN nvinferserver gstnvinferserver_impl.cpp:523:start: error: Config file path: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/tao_pretrained_models/deepstream_app_source1_peoplenet.txt
0:00:00.156400131 4994 0x34a90f0 WARN nvinferserver gstnvinferserver.cpp:518:gst_nvinfer_server_start: error: gstnvinferserver_impl start failed
Error: gst-library-error-quark: Configuration file parsing failed (5): gstnvinferserver_impl.cpp(523): start (): /GstPipeline:pipeline0/GstNvInferServer:primary-inference:
Exiting app
Appreciate your help to fix the issue
