Degrade throughout when one of VLs in congested status
Hello, we got a problem.
There are 5 servers, each connected to one 40 ports switch with one 200Gbps IB card (HDRx4).
Lets named server as A, B, C, D, E.
Test topology:
C <---- A -----> B
run following command:
  • node B: start service on B
    • ib_write_bw -S 0 -p 10000 -q 4
  • node C: start service on C
    • ib_write_bw -S 1 -p 10001 -q 4
  • node A: send data to B via SL0 and send data to C via SL1
    • ib_write_bw -S 0 -q 4 -p 10000 -D 1 -F --run_infinitely --report_gbits ip_of_B
    • ib_write_bw -S 1 -q 4 -p 10001 -D 1 -F --run_infinitely --report_gbits ip_of_C
Test Result shows as following:
  • A->B SL0 100Gbps
  • A->C SL1 100Gbps
Then, we add more traffic to node C, make C as a congested node. Test topology:
D
    C <---- A -----> B
E
running following commands:
  • node C: start services, receive data from D and E
    • ib_write_bw -S 1 -p 10002 -q 4
    • ib_write_bw -S 1 -p 10003 -q 4
  • node D: send data to C via SL1
    • ib_write_bw -S 1 -q 4 -p 10002 -D 1 -F --run_infinitely --report_gbits ip_of_C
  • node E: send data to C via SL1
    • ib_write_bw -S 1 -q 4 -p 10003 -D 1 -F --run_infinitely --report_gbits ip_of_C
Test result shows as following:
  • A->B SL0 80Gbps
  • A->C SL1 66Gbps
  • D->C SL1 66Gbps
  • E->C SL1 66Gbps
My question is, why A->B is 80Gbps? Shouldn’t it be about 130Gbps?
