Here is some code that looks a lot like what I’m using to compute the dense optical flow:
#include <opencv2/core/version.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include <opencv2/videoio.hpp>
#include <vpi/OpenCVInterop.hpp>
#include <vpi/Array.h>
#include <vpi/Image.h>
#include <vpi/ImageFormat.h>
#include <vpi/Status.h>
#include <vpi/Stream.h>
#include <vpi/algo/ConvertImageFormat.h>
#include <vpi/algo/OpticalFlowDense.h>
#include <iostream>
#include <sstream>
#define CHECK_STATUS(STMT) \
do \
VPIStatus status = (STMT); \
if (status != VPI_SUCCESS) \
char buffer[VPI_MAX_STATUS_MESSAGE_LENGTH]; \
vpiGetLastStatusMessage(buffer, sizeof(buffer)); \
std::ostringstream ss; \
ss << "line " << __LINE__ << ": "; \
ss << vpiStatusGetName(status) << ": " << buffer; \
throw std::runtime_error(ss.str()); \
} while (0);
static void ProcessMotionVector(VPIImage mvImg, cv::Mat &outputImage)
// Lock the input image to access it from CPU
VPIImageData mvData;
CHECK_STATUS(vpiImageLockData(mvImg, VPI_LOCK_READ, VPI_IMAGE_BUFFER_HOST_PITCH_LINEAR, &mvData));
// Create a cv::Mat that points to the input image data
cv::Mat mvImage;
CHECK_STATUS(vpiImageDataExportOpenCVMat(mvData, &mvImage));
// Convert S10.5 format to float
cv::Mat flow(mvImage.size(), CV_32FC2);
mvImage.convertTo(flow, CV_32F, 1.0f / (1 << 5));
// Image not needed anymore, we can unlock it.
CHECK_STATUS(vpiImageUnlock(mvImg));
// Create an image where the motion vector angle is
// mapped to a color hue, and intensity is proportional
// to vector's magnitude.
cv::Mat magnitude, angle;
cv::Mat flowChannels[2];
split(flow, flowChannels);
cv::cartToPolar(flowChannels[0], flowChannels[1], magnitude, angle, true);
float clip = 5;
cv::threshold(magnitude, magnitude, clip, clip, cv::THRESH_TRUNC);
// build hsv image
cv::Mat _hsv[3], hsv, bgr;
_hsv[0] = angle;
_hsv[1] = cv::Mat::ones(angle.size(), CV_32F);
_hsv[2] = magnitude / clip; // intensity must vary from 0 to 1
merge(_hsv, 3, hsv);
cv::cvtColor(hsv, bgr, cv::COLOR_HSV2BGR);
bgr.convertTo(outputImage, CV_8U, 255.0);
int main(int argc, char *argv[])
// OpenCV image that will be wrapped by a VPIImage.
// Define it here so that it's destroyed *after* wrapper is destroyed
cv::Mat cvPrevFrame, cvCurFrame;
// VPI objects that will be used
VPIStream stream = NULL;
VPIImage imgPrevFramePL = NULL;
VPIImage imgPrevFrameTmp = NULL;
VPIImage imgPrevFrameBL = NULL;
VPIImage imgCurFramePL = NULL;
VPIImage imgCurFrameTmp = NULL;
VPIImage imgCurFrameBL = NULL;
VPIImage imgMotionVecBL = NULL;
VPIPayload payload = NULL;
int retval = 0;
try
if (argc != 3)
throw std::runtime_error(std::string("Usage: ") + argv[0] + "<input_video> <low|medium|high>");
// Parse input parameters
std::string strInputVideo = argv[1];
std::string strQuality = argv[2];
VPIOpticalFlowQuality quality;
if (strQuality == "low")
quality = VPI_OPTICAL_FLOW_QUALITY_LOW;
else if (strQuality == "medium")
quality = VPI_OPTICAL_FLOW_QUALITY_MEDIUM;
else if (strQuality == "high")
quality = VPI_OPTICAL_FLOW_QUALITY_HIGH;
else
throw std::runtime_error("Unknown quality provided");
VPIBackend backend = VPI_BACKEND_NVENC;
int gridSize = 4;
int numLevels = 1;
// Load the input video
cv::VideoCapture invid;
if (!invid.open(strInputVideo))
throw std::runtime_error("Can't open '" + strInputVideo + "'");
// Create the stream where processing will happen. We'll use user-provided backend
// for Optical Flow, and CUDA/VIC for image format conversions.
CHECK_STATUS(vpiStreamCreate(backend | VPI_BACKEND_CUDA | VPI_BACKEND_VIC, &stream));
// Fetch the first frame
if (!invid.read(cvPrevFrame))
throw std::runtime_error("Cannot read frame from input video");
// Create the previous and current frame wrapper using the first frame. This wrapper will
// be set to point to every new frame in the main loop.
CHECK_STATUS(vpiImageCreateWrapperOpenCVMat(cvPrevFrame, 0, &imgPrevFramePL));
CHECK_STATUS(vpiImageCreateWrapperOpenCVMat(cvPrevFrame, 0, &imgCurFramePL));
// Define the image formats we'll use throughout this sample.
VPIImageFormat imgFmt = VPI_IMAGE_FORMAT_NV12_ER;
VPIImageFormat imgFmtBL = VPI_IMAGE_FORMAT_NV12_ER_BL;
int32_t width = cvPrevFrame.cols;
int32_t height = cvPrevFrame.rows;
// Create Dense Optical Flow payload to be executed on the given backend
std::vector<int32_t> pyrGridSize(numLevels, gridSize); // all levels will have the same grid size
CHECK_STATUS(vpiCreateOpticalFlowDense(backend, width, height, imgFmtBL, &pyrGridSize[0], pyrGridSize.size(),
quality, &payload));
// The Dense Optical Flow on NVENC or OFA backends expects input to be in block-linear format.
// Since Convert Image Format algorithm doesn't currently support direct BGR
// pitch-linear (from OpenCV) to Y8 block-linear conversion, it must be done in two
// passes, first from BGR/PL to Y8/PL using CUDA, then from Y8/PL to Y8/BL using VIC.
// The temporary image buffer below will store the intermediate Y8/PL representation.
CHECK_STATUS(vpiImageCreate(width, height, imgFmt, 0, &imgPrevFrameTmp));
CHECK_STATUS(vpiImageCreate(width, height, imgFmt, 0, &imgCurFrameTmp));
// Now create the final block-linear buffer that'll be used as input to the algorithm.
CHECK_STATUS(vpiImageCreate(width, height, imgFmtBL, 0, &imgPrevFrameBL));
CHECK_STATUS(vpiImageCreate(width, height, imgFmtBL, 0, &imgCurFrameBL));
// Motion vector image width and height, align to be multiple of gridSize
int32_t mvWidth = (width + gridSize - 1) / gridSize;
int32_t mvHeight = (height + gridSize - 1) / gridSize;
// The output video will be heatmap of motion vector image
int fourcc = cv::VideoWriter::fourcc('M', 'P', 'E', 'G');
double fps = invid.get(cv::CAP_PROP_FPS);
cv::VideoWriter outVideo("denseoptflow_mv.mp4", fourcc, fps, cv::Size(mvWidth, mvHeight));
if (!outVideo.isOpened())
throw std::runtime_error("Can't create output video");
// Create the output motion vector buffer
CHECK_STATUS(vpiImageCreate(mvWidth, mvHeight, VPI_IMAGE_FORMAT_2S16_BL, 0, &imgMotionVecBL));
// First convert the first frame to NV12_BL. It'll be used as previous frame when the algorithm is called.
CHECK_STATUS(vpiSubmitConvertImageFormat(stream, VPI_BACKEND_CUDA, imgPrevFramePL, imgPrevFrameTmp, nullptr));
CHECK_STATUS(vpiSubmitConvertImageFormat(stream, VPI_BACKEND_VIC, imgPrevFrameTmp, imgPrevFrameBL, nullptr));
// Create a output image which holds the rendered motion vector image.
cv::Mat mvOutputImage;
// Fetch a new frame until video ends
int idxFrame = 1;
while (invid.read(cvCurFrame))
printf("Processing frame %d\n", idxFrame++);
// Wrap frame into a VPIImage, reusing the existing imgCurFramePL.
CHECK_STATUS(vpiImageSetWrappedOpenCVMat(imgCurFramePL, cvCurFrame));
// Convert current frame to NV12_BL format
CHECK_STATUS(vpiSubmitConvertImageFormat(stream, VPI_BACKEND_CUDA, imgCurFramePL, imgCurFrameTmp, nullptr));
CHECK_STATUS(vpiSubmitConvertImageFormat(stream, VPI_BACKEND_VIC, imgCurFrameTmp, imgCurFrameBL, nullptr));
CHECK_STATUS(vpiSubmitOpticalFlowDense(stream, backend, payload, imgPrevFrameBL, imgCurFrameBL, imgMotionVecBL));
// Wait for processing to finish.
CHECK_STATUS(vpiStreamSync(stream));
// Render the resulting motion vector in the output image
ProcessMotionVector(imgMotionVecBL, mvOutputImage);
// Save to output video
outVideo << mvOutputImage;
// Swap previous frame and next frame
std::swap(cvPrevFrame, cvCurFrame);
std::swap(imgPrevFramePL, imgCurFramePL);
std::swap(imgPrevFrameBL, imgCurFrameBL);
catch (std::exception &e)
std::cerr << e.what() << std::endl;
retval = 1;
// Destroy all resources used
vpiStreamDestroy(stream);
vpiPayloadDestroy(payload);
vpiImageDestroy(imgPrevFramePL);
vpiImageDestroy(imgPrevFrameTmp);
vpiImageDestroy(imgPrevFrameBL);
vpiImageDestroy(imgCurFramePL);
vpiImageDestroy(imgCurFrameTmp);
vpiImageDestroy(imgCurFrameBL);
vpiImageDestroy(imgMotionVecBL);
return retval;
I can’t provide source video. In my real program, I’m using TIF file, not mp4 as input.
But any 2028 x 1520 px video should generate the error.
