Deploying VSS blueprint using kubernetes
  • Hardware Platform (GPU model and numbers): 1 GPU, RTX A2000 12GB
  • System Memory: 32 GB
  • Ubuntu Version: 20.04
  • NVIDIA GPU Driver Version (valid for GPU only) :550
  • Issue Type( questions, new requirements, bugs) : Questions
I am trying to deploy this blueprint using kubernetes.
https://catalog.ngc.nvidia.com/orgs/nvidia/teams/blueprint/helm-charts/nvidia-blueprint-vss/files?version=2.1.0
I have some questions. I can see the default models are : emmbedding-1B, VILA-40B, llm-70B. From the documentation I can see that the llm and vlm models can be customized. My question is what model can I use to run on my hardware config. And how do I config my download directories? My root directory has no space to spare.
We recommend that you use at least 8x48G GPU and 256G+ CPU. Your current device may not be able to meet the resource requirements even if it is customized.
I am going to ugrade the system. But trying to understand the blueprint now. I am using OpenAI API for VLM, llama3-8B for LLM and the parameters of embedding model is 1B. Why 12GB vram and 32GB system ram is not enough to run the embedding and llm model? I can seperately run bigger ollama models with this system.
# Copyright (c) 2023, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
global: {ngcImagePullSecretName: ""}
nvcf:
  dockerRegSecrets: []
  additionalSecrets: []
  localStorageProvisioner: []
vss:
  applicationSpecs:
    vss-deployment:
      containers:
        vss:
          env:
          - name: FRONTEND_PORT
            value: '9000'
          - name: BACKEND_PORT
            value: '8000'
          - name: GRAPH_DB_URI
            value: bolt://neo-4-j-service:7687
          - name: GRAPH_DB_USERNAME
            value: neo4j
          - name: GRAPH_DB_PASSWORD
            value: password
          - name: MILVUS_DB_HOST
            value: milvus-milvus-deployment-milvus-service
          - name: MILVUS_DB_PORT
            value: '19530'
          - name: VLM_MODEL_TO_USE
            # value: vila-1.5
            value: openai-compat
          - name: OPENAI_API_KEY
            valueFrom:
              secretKeyRef:
                key: OPENAI_API_KEY
          # - name: MODEL_PATH
          #   value: ngc:nim/nvidia/vila-1.5-40b:vila-yi-34b-siglip-stage3_1003_video_v8
          - name: DISABLE_GUARDRAILS
            value: 'false'
          - name: OPENAI_API_KEY_NAME
            value: VSS_OPENAI_API_KEY
          - name: NVIDIA_API_KEY_NAME
            value: VSS_NVIDIA_API_KEY
          - name: NGC_API_KEY_NAME
            value: VSS_NGC_API_KEY
          - name: TRT_LLM_MODE
            value: int4_awq
          - name: VLM_BATCH_SIZE
            value: ''
          - name: VIA_VLM_OPENAI_MODEL_DEPLOYMENT_NAME
            value: ''
          - name: VIA_VLM_ENDPOINT
            value: ''
          - name: VIA_VLM_API_KEY
            value: ''
          - name: OPENAI_API_VERSION
            value: ''
          - name: AZURE_OPENAI_API_VERSION
            value: ''
          # - name: NVIDIA_VISIBLE_DEVICES
          #   value: "1"
      initContainers:
      - command:
        - sh
        - -c
        - until nc -z -w 2 milvus-milvus-deployment-milvus-service 19530; do echo
          waiting for milvus; sleep 2; done
        image: busybox:1.28
        imagePullPolicy: IfNotPresent
      - command:
        - sh
        - -c
        - until nc -z -w 2 neo-4-j-service 7687; do echo waiting for neo4j; sleep
          2; done
        image: busybox:1.28
      - args:
        - "while ! curl -s -f -o /dev/null http://llm-nim-svc:8000/v1/health/live;\
          \ do\n  echo \"Waiting for LLM...\"\n  sleep 2\ndone\n"
        command:
        - sh
        - -c
        image: curlimages/curl:latest
  llmModel: meta/llama-3.1-8b-instruct
  llmModelChat: meta/llama-3.1-8b-instruct
  resources:
    limits:
      nvidia.com/gpu: 1
  # vlmModelPath: ngc:nim/nvidia/vila-1.5-40b:vila-yi-34b-siglip-stage3_1003_video_v8
  # vlmModelType: vila-1.5
  configs:
    ca_rag_config.yaml:
      chat:
        embedding:
          base_url: http://nemo-embedding-embedding-deployment-embedding-service:8000/v1
        llm:
          base_url: http://llm-nim-svc:8000/v1
          model: meta/llama-3.1-8b-instruct
        reranker:
          base_url: http://nemo-rerank-ranking-deployment-ranking-service:8000/v1
      summarization:
        embedding:
        llm:
    guardrails_config.yaml:
      models:
      - engine: nim
        parameters:
        type: main
      - engine: nim_patch
        model: nvidia/llama-3.2-nv-embedqa-1b-v2
        parameters:
        type: embeddings
  extraPodVolumes:
  - name: secret-ngc-api-key-volume
    secret:
      secretName: ngc-api-key-secret
      items:
      - key: NGC_API_KEY
        path: ngc-api-key
  - name: secret-graph-db-username-volume
    secret:
      secretName: graph-db-creds-secret
      items:
      - key: username
        path: graph-db-username
  - name: secret-graph-db-password-volume
    secret:
      items:
      - key: password
        path: graph-db-password
  extraPodVolumeMounts:
    mountPath: /secrets/ngc-api-key
    subPath: ngc-api-key
    readOnly: true
    mountPath: /secrets/graph-db-username
    subPath: graph-db-username
    readOnly: true
    mountPath: /secrets/graph-db-password
    subPath: graph-db-password
    readOnly: true
  egress:
    milvus:
      address: milvus-milvus-deployment-milvus-service
      port: 19530
    neo4j-bolt:
      address: neo-4-j-service
      port: 7687
    llm-openai-api:
      address: llm-nim-svc
      port: 8000
    nemo-embed:
      address: nemo-embedding-embedding-deployment-embedding-service
      port: 8000
    nemo-rerank:
      address: nemo-rerank-ranking-deployment-ranking-service
      port: 8000
milvus:
  applicationSpecs:
    milvus-deployment:
      containers:
        milvus-container:
          env:
          - name: ETCD_ENDPOINTS
            value: etcd-etcd-deployment-etcd-service:2379
          - name: MINIO_ADDRESS
            value: minio-minio-deployment-minio-service:9010
          - name: KNOWHERE_GPU_MEM_POOL_SIZE
            value: 2048;4096
  egress:
    etcd:
      address: etcd-etcd-deployment-etcd-service
      port: 2379
    minio:
      address: minio-minio-deployment-minio-service
      port: 9010
neo4j:
  extraPodVolumes:
  - name: secret-db-username-volume
    secret:
      items:
      - key: username
        path: db-username
  - name: secret-db-password-volume
    secret:
      items:
      - key: password
        path: db-password
    mountPath: /secrets/db-username
    subPath: db-username
    readOnly: true
    mountPath: /secrets/db-password
    subPath: db-password
    readOnly: true
nim-llm:
  # env:
  #   value: "1"
  image:
    repository: nvcr.io/nim/meta/llama-3.1-8b-instruct
    tag: 1.3.0
  resources:
    limits:
      nvidia.com/gpu: 1
  model:
    ngcAPISecret: ngc-api-key-secret
  persistence:
    enabled: true
  hostPath:
    enabled: true
  service:
nemo-embedding:
  # env:
  #   value: "0"
  resources:
    limits:
      nvidia.com/gpu: 1
nemo-rerank:
  # env:
  #   value: "0"
  resources:
    limits:
      nvidia.com/gpu: 1
This is my config file
The GPU resource of the llama-3_2-nv-embedqa-1b-v2 and the llama-3_2-nv-rerankqa-1b-v2 is insufficient on your device.
