Hi, a question - I’m trying to run inference using tao-deploy for the detectnet_v2 model using an engine file. This gives the following error:
File “</usr/local/lib/python3.8/dist-packages/nvidia_tao_deploy/cv/detectnet_v2/scripts/inference.py>”, line 3, in
google.protobuf.text_format.ParseError: 1:1 : Message type “Inference” has no field named “evaluation_config”.
What would be really helpful is if the “Inference” message definition is printed. Now I have to guess if perhaps the documentation that I am following is out-of-date, or there might be a bug, or I am still doing something wrong after trying for one hour. I tried finding the source code to see what is going on - but the pip package nvidia-tao-deploy is obfuscated! Why? This makes it really hard to tackle the issue without your help :-/
I can provide you with the full details like the spec file and everything, but I would rather be able to solve this issue myself.
Q1 - Can you provide the nvidia-tao-deploy without obfuscation?
If not, can you provide the “Inference” message proto?
If not, what do you suggest?
I am afraid there is something mismatching in the inference spec file.
Please refer to the notebook and find the detectnet_v2’s spec file and its .ipynb file.
