Hi! the vkWaitForFence function after the vkSubmit, return the code error (-4), it happens after I recreate the descriptors when I try to add a new render component with my editor. (It doesn’t crash with the validation layers enabled when it runs slower so I guess the driver try to access to a wrong descriptor even when adding vkDeviceWaitIdle…
window::Device::QueueFamilyIndices indices = vkDevice.findQueueFamilies(vkDevice.getPhysicalDevice(), nullptr);
if (vkQueueSubmit(vkDevice.getQueue(indices.graphicsFamily.value(), queueIndex), 1, &submitInfo, (fenceToSubmit == nullptr) ? inFlightFences[currentFrame] : fenceToSubmit) != VK_SUCCESS) {
throw core::Erreur(0, “échec de l’envoi d’un command buffer!”, 1);
std::cout<<"wait on fence : "<<inFlightFences[currentFrame]<<std::endl;
VkResult r = vkWaitForFences(vkDevice.getDevice(), 1, (fenceToSubmit == nullptr) ? &inFlightFences[currentFrame] : &fenceToSubmit, VK_TRUE, UINT64_MAX);
printf(“wait for fence result : %d\n”, r);
In fact I need to recreate the descriptors of every renderers when I add new resources like shaders otherwise I’ve errors. I’ve ids for shader which point to a specific descriptor, and even sometimes a topology index because I use different buffers depending on the topology. I also have different pipelines that I also recreate when I add resources like shaders. Here is where I create/recreate the pipelines :
void RenderTarget::createGraphicPipeline(PrimitiveType type,
RenderStates states, unsigned int depthStencilId, unsigned int nbDepthStencil, unsigned int id) {
Shader* shader = const_cast<Shader*>(states.shader);
states.blendMode.updateIds();
//system("PAUSE");
unsigned int blendModeId = states.blendMode.id;
unsigned int nbBlendMode = states.blendMode.nbBlendModes;
if ((Batcher::nbPrimitiveTypes - 1) * shader->getNbShaders() > graphicsPipeline.size()) {
graphicsPipeline.resize((Batcher::nbPrimitiveTypes - 1) * shader->getNbShaders());
pipelineLayoutInfo.resize((Batcher::nbPrimitiveTypes - 1) * shader->getNbShaders());
pipelineLayout.resize((Batcher::nbPrimitiveTypes - 1) * shader->getNbShaders());
depthStencil.resize((Batcher::nbPrimitiveTypes - 1) * shader->getNbShaders());
for (unsigned int i = 0; i < (Batcher::nbPrimitiveTypes - 1) * shader->getNbShaders(); i++) {
if ((id + 1) > graphicsPipeline[i].size()) {
graphicsPipeline[i].resize(id+1);
pipelineLayoutInfo[i].resize(id+1);
pipelineLayout[i].resize(id+1);
depthStencil[i].resize(id+1);
for (unsigned int j = 0; j < (id + 1); j++) {
if (nbDepthStencil * nbBlendMode > graphicsPipeline[i][j].size()) {
graphicsPipeline[i][j].resize(nbDepthStencil*nbBlendMode);
pipelineLayoutInfo[i][j].resize(nbDepthStencil*nbBlendMode);
pipelineLayout[i][j].resize(nbDepthStencil*nbBlendMode);
depthStencil[i][j].resize(nbDepthStencil*nbBlendMode);
unsigned int descriptorId = shader->getId();
//std::cout<<"descriptor set layout id : "<<descriptorId<<std::endl;
////////std::cout<<"rt dl size : "<<descriptorSetLayout.size()<<std::endl;
/*//////std::cout<<"descriptor id : "<<descriptorId<<std::endl;*/
////////std::cout<<"pipeline id : "<<pipelineId<<std::endl;
/*for (unsigned int i = 0; i < pipelinesId.size(); i++) {
if (pipelinesId[i] == pipelineId) {
//////std::cout<<"Erreur"<<std::endl;
system("PAUSE");
pipelinesId.push_back(pipelineId);*/
VkShaderModule vertShaderModule;
VkShaderModule fragShaderModule;
VkShaderModule geomShaderModule=nullptr;
if (states.shader == nullptr) {
defaultShader.createShaderModules();
vertShaderModule = defaultShader.getVertexShaderModule();
fragShaderModule = defaultShader.getFragmentShaderModule();
states.shader = &defaultShader;
} else {
shader->createShaderModules();
vertShaderModule = shader->getVertexShaderModule();
fragShaderModule = shader->getFragmentShaderModule();
if (shader->getGeometryShaderModule() != nullptr) {
geomShaderModule = shader->getGeometryShaderModule();
std::vector<VkPipelineShaderStageCreateInfo> shaderStages;
if (geomShaderModule == nullptr) {
VkPipelineShaderStageCreateInfo vertShaderStageInfo{};
vertShaderStageInfo.sType = VK_STRUCTURE_TYPE_PIPELINE_SHADER_STAGE_CREATE_INFO;
vertShaderStageInfo.stage = VK_SHADER_STAGE_VERTEX_BIT;
vertShaderStageInfo.module = vertShaderModule;
vertShaderStageInfo.pName = "main";
VkPipelineShaderStageCreateInfo fragShaderStageInfo{};
fragShaderStageInfo.sType = VK_STRUCTURE_TYPE_PIPELINE_SHADER_STAGE_CREATE_INFO;
fragShaderStageInfo.stage = VK_SHADER_STAGE_FRAGMENT_BIT;
fragShaderStageInfo.module = fragShaderModule;
fragShaderStageInfo.pName = "main";
shaderStages = {vertShaderStageInfo, fragShaderStageInfo};
} else {
VkPipelineShaderStageCreateInfo geomShaderStageInfo{};
geomShaderStageInfo.sType = VK_STRUCTURE_TYPE_PIPELINE_SHADER_STAGE_CREATE_INFO;
geomShaderStageInfo.stage = VK_SHADER_STAGE_GEOMETRY_BIT;
geomShaderStageInfo.module = geomShaderModule;
geomShaderStageInfo.pName = "main";
shaderStages = {vertShaderStageInfo, fragShaderStageInfo, geomShaderStageInfo};
VkPipelineVertexInputStateCreateInfo vertexInputInfo{};
auto bindingDescription = Vertex::getBindingDescription();
auto attributeDescriptions = Vertex::getAttributeDescriptions();
vertexInputInfo.sType = VK_STRUCTURE_TYPE_PIPELINE_VERTEX_INPUT_STATE_CREATE_INFO;
vertexInputInfo.vertexBindingDescriptionCount = 1;
vertexInputInfo.vertexAttributeDescriptionCount = static_cast<uint32_t>(attributeDescriptions.size());
vertexInputInfo.pVertexBindingDescriptions = &bindingDescription;
vertexInputInfo.pVertexAttributeDescriptions = attributeDescriptions.data();
VkPipelineInputAssemblyStateCreateInfo inputAssembly{};
inputAssembly.sType = VK_STRUCTURE_TYPE_PIPELINE_INPUT_ASSEMBLY_STATE_CREATE_INFO;
VkPrimitiveTopology modes[] = {VK_PRIMITIVE_TOPOLOGY_POINT_LIST, VK_PRIMITIVE_TOPOLOGY_LINE_LIST, VK_PRIMITIVE_TOPOLOGY_LINE_STRIP, VK_PRIMITIVE_TOPOLOGY_TRIANGLE_LIST, VK_PRIMITIVE_TOPOLOGY_TRIANGLE_STRIP, VK_PRIMITIVE_TOPOLOGY_TRIANGLE_FAN};
inputAssembly.topology = modes[type];
inputAssembly.primitiveRestartEnable =
(inputAssembly.topology == VK_PRIMITIVE_TOPOLOGY_LINE_STRIP ||
inputAssembly.topology == VK_PRIMITIVE_TOPOLOGY_TRIANGLE_STRIP ||
inputAssembly.topology == VK_PRIMITIVE_TOPOLOGY_TRIANGLE_FAN)
? VK_TRUE : VK_FALSE;
VkPipelineViewportStateCreateInfo viewportState{};
viewportState.sType = VK_STRUCTURE_TYPE_PIPELINE_VIEWPORT_STATE_CREATE_INFO;
viewportState.viewportCount = viewports.size();
//viewportState.pViewports = &viewport;
viewportState.scissorCount = scissors.size();
//viewportState.pScissors = &scissor;
std::vector<VkDynamicState> dynamicStates = {
VK_DYNAMIC_STATE_VIEWPORT,
VK_DYNAMIC_STATE_SCISSOR
VkPipelineDynamicStateCreateInfo dynamicState{};
dynamicState.sType = VK_STRUCTURE_TYPE_PIPELINE_DYNAMIC_STATE_CREATE_INFO;
dynamicState.dynamicStateCount = static_cast<uint32_t>(dynamicStates.size());
dynamicState.pDynamicStates = dynamicStates.data();
VkPipelineRasterizationStateCreateInfo rasterizer{};
rasterizer.sType = VK_STRUCTURE_TYPE_PIPELINE_RASTERIZATION_STATE_CREATE_INFO;
rasterizer.depthClampEnable = VK_FALSE;
rasterizer.rasterizerDiscardEnable = VK_FALSE;
rasterizer.polygonMode = VK_POLYGON_MODE_FILL;
rasterizer.lineWidth = 1.0f;
if (cm == NONE)
rasterizer.cullMode = VK_CULL_MODE_NONE;
else if (cm == FRONT)
rasterizer.cullMode = VK_CULL_MODE_FRONT_BIT;
else if (cm == BACK)
rasterizer.cullMode = VK_CULL_MODE_BACK_BIT;
else
rasterizer.cullMode = VK_CULL_MODE_FRONT_AND_BACK;
rasterizer.frontFace = VK_FRONT_FACE_CLOCKWISE;
rasterizer.depthBiasEnable = VK_FALSE;
VkPipelineMultisampleStateCreateInfo multisampling{};
multisampling.sType = VK_STRUCTURE_TYPE_PIPELINE_MULTISAMPLE_STATE_CREATE_INFO;
multisampling.sampleShadingEnable = VK_FALSE;
multisampling.rasterizationSamples = VK_SAMPLE_COUNT_1_BIT;
VkPipelineColorBlendAttachmentState colorBlendAttachment{};
colorBlendAttachment.colorWriteMask = VK_COLOR_COMPONENT_R_BIT | VK_COLOR_COMPONENT_G_BIT | VK_COLOR_COMPONENT_B_BIT | VK_COLOR_COMPONENT_A_BIT;
colorBlendAttachment.blendEnable = VK_TRUE;
colorBlendAttachment.srcColorBlendFactor = factorToVkConstant(states.blendMode.colorSrcFactor);
colorBlendAttachment.dstColorBlendFactor = factorToVkConstant(states.blendMode.colorDstFactor);
colorBlendAttachment.colorBlendOp = equationToVkConstant(states.blendMode.colorEquation);
colorBlendAttachment.srcAlphaBlendFactor = factorToVkConstant(states.blendMode.alphaSrcFactor);
colorBlendAttachment.dstAlphaBlendFactor = factorToVkConstant(states.blendMode.alphaDstFactor);
colorBlendAttachment.alphaBlendOp = equationToVkConstant(states.blendMode.alphaEquation);
VkPipelineColorBlendStateCreateInfo colorBlending{};
colorBlending.sType = VK_STRUCTURE_TYPE_PIPELINE_COLOR_BLEND_STATE_CREATE_INFO;
colorBlending.logicOpEnable = VK_FALSE;
colorBlending.logicOp = VK_LOGIC_OP_COPY;
colorBlending.attachmentCount = 1;
colorBlending.pAttachments = &colorBlendAttachment;
colorBlending.blendConstants[0] = 0.0f;
colorBlending.blendConstants[1] = 0.0f;
colorBlending.blendConstants[2] = 0.0f;
colorBlending.blendConstants[3] = 0.0f;
pipelineLayoutInfo[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].sType = VK_STRUCTURE_TYPE_PIPELINE_LAYOUT_CREATE_INFO;
pipelineLayoutInfo[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].setLayoutCount = descriptorSetLayout[descriptorId].size();
pipelineLayoutInfo[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].pSetLayouts = descriptorSetLayout[descriptorId].data();
//std::cout<<"ids : "<<shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type<<","<<id<<","<<depthStencilId*nbBlendMode+blendModeId<<std::endl;
if (pipelineLayout[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId] != nullptr) {
//std::cout<<"destroy pipeline layout ids : "<<shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type<<","<<id<<","<<depthStencilId*nbBlendMode+blendModeId<<std::endl;
vkDestroyPipelineLayout(vkDevice.getDevice(), pipelineLayout[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId], nullptr);
/*std::cout<<"create pipeline layout ids : "<<shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type<<","<<id<<","<<depthStencilId*nbBlendMode+blendModeId<<std::endl;
std::cout<<"sizes : "<<pipelineLayout.size()<<","<<pipelineLayout[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type].size()<<","<<pipelineLayout[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id].size()<<std::endl;*/
if (vkCreatePipelineLayout(vkDevice.getDevice(), &pipelineLayoutInfo[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId], nullptr, &pipelineLayout[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId]) != VK_SUCCESS) {
throw core::Erreur(0, "failed to create pipeline layout!", 1);
////////std::cout<<"pipeline layout : "<<pipelineLayout[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId]<<std::endl;
depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].sType = VK_STRUCTURE_TYPE_PIPELINE_DEPTH_STENCIL_STATE_CREATE_INFO;
depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].depthTestEnable = (depthTestEnabled) ? VK_TRUE : VK_FALSE;
depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].depthBoundsTestEnable = VK_FALSE;
depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].minDepthBounds = 0.0f; // Optional
depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].maxDepthBounds = 1.0f; // Optional
depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].stencilTestEnable = (stencilTestEnabled) ? VK_TRUE : VK_FALSE;
/*if (depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId].depthTestEnable == VK_TRUE)
//std::cout<<"depth test enabled"<<std::endl;*/
VkGraphicsPipelineCreateInfo pipelineInfo{};
pipelineInfo.sType = VK_STRUCTURE_TYPE_GRAPHICS_PIPELINE_CREATE_INFO;
pipelineInfo.stageCount = shaderStages.size();
pipelineInfo.pStages = shaderStages.data();
pipelineInfo.pVertexInputState = &vertexInputInfo;
pipelineInfo.pInputAssemblyState = &inputAssembly;
pipelineInfo.pViewportState = &viewportState;
pipelineInfo.pRasterizationState = &rasterizer;
pipelineInfo.pMultisampleState = &multisampling;
pipelineInfo.pColorBlendState = &colorBlending;
pipelineInfo.pDynamicState = &dynamicState;
pipelineInfo.layout = pipelineLayout[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId];
/*if (getSurface() != VK_NULL_HANDLE)
//////std::cout<<"render pass ppl rw : "<<getRenderPass()<<std::endl;
else
//////std::cout<<"render pass ppl rt : "<<getRenderPass()<<std::endl;*/
pipelineInfo.renderPass = (depthTestEnabled || stencilTestEnabled) ? getRenderPass(1) : getRenderPass(0);
pipelineInfo.subpass = 0;
pipelineInfo.basePipelineHandle = VK_NULL_HANDLE;
pipelineInfo.pDepthStencilState = &depthStencil[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId];
if (graphicsPipeline[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId] != nullptr) {
//std::cout<<"destroy pipeline"<<std::endl;
vkDestroyPipeline(vkDevice.getDevice(), graphicsPipeline[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId], nullptr);
/*std::cout<<"create graphics pipeline ids : "<<(shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type)<<","<<id<<","<<(depthStencilId*nbBlendMode+blendModeId)<<std::endl;
std::cout<<"sizes : "<<graphicsPipeline.size()<<","<<graphicsPipeline[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type].size()<<","<<graphicsPipeline[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id].size()<<std::endl;*/
if (vkCreateGraphicsPipelines(vkDevice.getDevice(), VK_NULL_HANDLE, 1, &pipelineInfo, nullptr, &graphicsPipeline[shader->getId() * (Batcher::nbPrimitiveTypes - 1)+type][id][depthStencilId*nbBlendMode+blendModeId]) != VK_SUCCESS) {
throw core::Erreur(0, "failed to create graphics pipeline!", 1);
shader->cleanupShaderModules();
And in my other renderer which use the main renderer I update the descriptors like this :
void PerPixelLinkedListRenderComponent::createDescriptorPool(unsigned int p, RenderStates states) {
std::vector<std::vector<VkDescriptorPool>>& descriptorPool = frameBuffer.getDescriptorPool();
if (shader == &indirectRenderingShader) {
unsigned int descriptorId = p * shader->getNbShaders() + shader->getId();
if (shader->getNbShaders() * (Batcher::nbPrimitiveTypes - 1) > descriptorPool.size())
descriptorPool.resize(shader->getNbShaders() * (Batcher::nbPrimitiveTypes - 1));
descriptorPool[descriptorId].resize(1);
std::array<VkDescriptorPoolSize, 6> poolSizes;
poolSizes[0].type = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
poolSizes[0].descriptorCount = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight());
poolSizes[1].type = VK_DESCRIPTOR_TYPE_STORAGE_IMAGE;
poolSizes[1].descriptorCount = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight());
poolSizes[2].type = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
poolSizes[2].descriptorCount = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight());
poolSizes[3].type = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER_DYNAMIC;
poolSizes[3].descriptorCount = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight());
poolSizes[4].type = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER_DYNAMIC;
poolSizes[4].descriptorCount = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight());
poolSizes[5].type = VK_DESCRIPTOR_TYPE_COMBINED_IMAGE_SAMPLER;
poolSizes[5].descriptorCount = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight() * MAX_TEXTURES);
if (descriptorPool[descriptorId][0] != nullptr) {
vkDestroyDescriptorPool(vkDevice.getDevice(), descriptorPool[descriptorId][0], nullptr);
VkDescriptorPoolCreateInfo poolInfo{};
poolInfo.sType = VK_STRUCTURE_TYPE_DESCRIPTOR_POOL_CREATE_INFO;
poolInfo.poolSizeCount = static_cast<uint32_t>(poolSizes.size());
poolInfo.pPoolSizes = poolSizes.data();
poolInfo.maxSets = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight());
if (vkCreateDescriptorPool(vkDevice.getDevice(), &poolInfo, nullptr, &descriptorPool[descriptorId][0]) != VK_SUCCESS) {
throw std::runtime_error("echec de la creation de la pool de descripteurs!");
} else if (shader == &perPixelLinkedListP2) {
std::array<VkDescriptorPoolSize, 2> poolSizes{};
poolSizes[0].type = VK_DESCRIPTOR_TYPE_STORAGE_IMAGE;
poolSizes[1].type = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
} else {
std::array<VkDescriptorPoolSize, 1> poolSizes;
poolSizes[0].type = VK_DESCRIPTOR_TYPE_COMBINED_IMAGE_SAMPLER;
void PerPixelLinkedListRenderComponent::createDescriptorSetLayout(RenderStates states) {
std::vector<std::vector<VkDescriptorSetLayout>>& descriptorSetLayout = frameBuffer.getDescriptorSetLayout();
if (shader->getNbShaders() > descriptorSetLayout.size())
descriptorSetLayout.resize(shader->getNbShaders());
descriptorSetLayout[descriptorId].resize(1);
////////std::cout<<"ppll descriptor id : "<<descriptorId<<std::endl;
std::vector<Texture*> allTextures = Texture::getAllTextures();
VkDescriptorSetLayoutBinding counterLayoutBinding{};
counterLayoutBinding.binding = 0;
counterLayoutBinding.descriptorCount = 1;
counterLayoutBinding.descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
counterLayoutBinding.pImmutableSamplers = nullptr;
counterLayoutBinding.stageFlags = VK_SHADER_STAGE_FRAGMENT_BIT;
VkDescriptorSetLayoutBinding headPtrImageLayoutBinding;
headPtrImageLayoutBinding.binding = 1;
headPtrImageLayoutBinding.descriptorCount = 1;
headPtrImageLayoutBinding.descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_IMAGE;
headPtrImageLayoutBinding.pImmutableSamplers = nullptr;
headPtrImageLayoutBinding.stageFlags = VK_SHADER_STAGE_FRAGMENT_BIT;
VkDescriptorSetLayoutBinding linkedListLayoutBinding{};
linkedListLayoutBinding.binding = 2;
linkedListLayoutBinding.descriptorCount = 1;
linkedListLayoutBinding.descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
linkedListLayoutBinding.pImmutableSamplers = nullptr;
linkedListLayoutBinding.stageFlags = VK_SHADER_STAGE_FRAGMENT_BIT;
std::vector<VkDescriptorBindingFlags> bindingFlags(6, 0); // 6 bindings, flags par défaut à 0
bindingFlags[5] = VK_DESCRIPTOR_BINDING_VARIABLE_DESCRIPTOR_COUNT_BIT |
VK_DESCRIPTOR_BINDING_PARTIALLY_BOUND_BIT; // seulement pour sampler[]
VkDescriptorSetLayoutBindingFlagsCreateInfo bindingFlagsInfo{};
bindingFlagsInfo.sType = VK_STRUCTURE_TYPE_DESCRIPTOR_SET_LAYOUT_BINDING_FLAGS_CREATE_INFO;
bindingFlagsInfo.bindingCount = static_cast<uint32_t>(bindingFlags.size());
bindingFlagsInfo.pBindingFlags = bindingFlags.data();
VkDescriptorSetLayoutBinding modelDataLayoutBinding{};
modelDataLayoutBinding.binding = 3;
modelDataLayoutBinding.descriptorCount = 1;
modelDataLayoutBinding.descriptorType = (useThread) ? VK_DESCRIPTOR_TYPE_STORAGE_BUFFER_DYNAMIC : VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
modelDataLayoutBinding.pImmutableSamplers = nullptr;
modelDataLayoutBinding.stageFlags = VK_SHADER_STAGE_VERTEX_BIT;
VkDescriptorSetLayoutBinding materialDataLayoutBinding{};
materialDataLayoutBinding.binding = 4;
materialDataLayoutBinding.descriptorCount = 1;
materialDataLayoutBinding.descriptorType = (useThread) ? VK_DESCRIPTOR_TYPE_STORAGE_BUFFER_DYNAMIC : VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
materialDataLayoutBinding.pImmutableSamplers = nullptr;
materialDataLayoutBinding.stageFlags = VK_SHADER_STAGE_VERTEX_BIT;
VkDescriptorSetLayoutBinding samplerLayoutBinding{};
samplerLayoutBinding.binding = 5;
samplerLayoutBinding.descriptorCount = MAX_TEXTURES;
samplerLayoutBinding.descriptorType = VK_DESCRIPTOR_TYPE_COMBINED_IMAGE_SAMPLER;
samplerLayoutBinding.pImmutableSamplers = nullptr;
samplerLayoutBinding.stageFlags = VK_SHADER_STAGE_FRAGMENT_BIT;
if (descriptorSetLayout[descriptorId][0] != nullptr) {
vkDestroyDescriptorSetLayout(vkDevice.getDevice(), descriptorSetLayout[descriptorId][0], nullptr);
std::array<VkDescriptorSetLayoutBinding, 6> bindings = {counterLayoutBinding, headPtrImageLayoutBinding, linkedListLayoutBinding, modelDataLayoutBinding, materialDataLayoutBinding, samplerLayoutBinding};
VkDescriptorSetLayoutCreateInfo layoutInfo{};
layoutInfo.sType = VK_STRUCTURE_TYPE_DESCRIPTOR_SET_LAYOUT_CREATE_INFO;
layoutInfo.pNext = &bindingFlagsInfo;
//layoutInfo.flags = VK_DESCRIPTOR_SET_LAYOUT_CREATE_PUSH_DESCRIPTOR_BIT_KHR;
layoutInfo.bindingCount = static_cast<uint32_t>(bindings.size());;
layoutInfo.pBindings = bindings.data();
if (vkCreateDescriptorSetLayout(vkDevice.getDevice(), &layoutInfo, nullptr, &descriptorSetLayout[descriptorId][0]) != VK_SUCCESS) {
throw std::runtime_error("failed to create descriptor set layout!");
} else {
//std::cout<<"shader id : "<<descriptorId<<std::endl;
samplerLayoutBinding.binding = 0;
samplerLayoutBinding.descriptorCount = 1;
std::array<VkDescriptorSetLayoutBinding, 1> bindings = {samplerLayoutBinding};
void PerPixelLinkedListRenderComponent::allocateDescriptorSets(unsigned int p, RenderStates states) {
std::vector<std::vector<std::vector<VkDescriptorSet>>>& descriptorSets = frameBuffer.getDescriptorSet();
if (shader->getNbShaders() * (Batcher::nbPrimitiveTypes - 1) > descriptorSets.size())
descriptorSets.resize(shader->getNbShaders() * (Batcher::nbPrimitiveTypes - 1));
descriptorSets[descriptorId].resize(1);
for (unsigned int i = 0; i < descriptorSets[descriptorId].size(); i++) {
descriptorSets[descriptorId][i].resize(frameBuffer.getMaxFramesInFlight());
std::vector<uint32_t> variableCounts(frameBuffer.getMaxFramesInFlight(), static_cast<uint32_t>(MAX_TEXTURES));
VkDescriptorSetVariableDescriptorCountAllocateInfo variableCountInfo{};
variableCountInfo.sType = VK_STRUCTURE_TYPE_DESCRIPTOR_SET_VARIABLE_DESCRIPTOR_COUNT_ALLOCATE_INFO;
variableCountInfo.descriptorSetCount = static_cast<uint32_t>(variableCounts.size());;
variableCountInfo.pDescriptorCounts = variableCounts.data();
std::vector<VkDescriptorSetLayout> layouts(frameBuffer.getMaxFramesInFlight(), descriptorSetLayout[shader->getId()][0]);
VkDescriptorSetAllocateInfo allocInfo{};
allocInfo.sType = VK_STRUCTURE_TYPE_DESCRIPTOR_SET_ALLOCATE_INFO;
allocInfo.pNext = &variableCountInfo;
allocInfo.descriptorPool = descriptorPool[descriptorId][0];
allocInfo.descriptorSetCount = static_cast<uint32_t>(frameBuffer.getMaxFramesInFlight());
allocInfo.pSetLayouts = layouts.data();
if (vkAllocateDescriptorSets(vkDevice.getDevice(), &allocInfo, descriptorSets[descriptorId][0].data()) != VK_SUCCESS) {
throw std::runtime_error("echec de l'allocation d'un set de descripteurs!");
} else {
if (shader->getNbShaders() * (Batcher::nbPrimitiveTypes - 1)> descriptorSets.size())
//std::cout<<"descriptor skybox ids : "<<descriptorId<<","<<shader->getId()<<std::endl;
void PerPixelLinkedListRenderComponent::updateDescriptorSets(unsigned int currentFrame, unsigned int p, RenderStates states) {
std::vector<VkDescriptorImageInfo> descriptorImageInfos;
descriptorImageInfos.resize(allTextures.size());
for (unsigned int j = 0; j < allTextures.size(); j++) {
descriptorImageInfos[j].imageLayout = VK_IMAGE_LAYOUT_SHADER_READ_ONLY_OPTIMAL;
descriptorImageInfos[j].imageView = allTextures[j]->getImageView();
descriptorImageInfos[j].sampler = allTextures[j]->getSampler();
std::array<VkWriteDescriptorSet, 6> descriptorWrites{};
VkDescriptorBufferInfo counterStorageBufferInfoLastFrame{};
counterStorageBufferInfoLastFrame.buffer = counterShaderStorageBuffers[currentFrame];
counterStorageBufferInfoLastFrame.offset = 0;
counterStorageBufferInfoLastFrame.range = sizeof(AtomicCounterSSBO);
descriptorWrites[0].sType = VK_STRUCTURE_TYPE_WRITE_DESCRIPTOR_SET;
descriptorWrites[0].dstSet = descriptorSets[descriptorId][0][currentFrame];
descriptorWrites[0].dstBinding = 0;
descriptorWrites[0].dstArrayElement = 0;
descriptorWrites[0].descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
descriptorWrites[0].descriptorCount = 1;
descriptorWrites[0].pBufferInfo = &counterStorageBufferInfoLastFrame;
VkDescriptorImageInfo headPtrDescriptorImageInfo;
headPtrDescriptorImageInfo.imageLayout = VK_IMAGE_LAYOUT_GENERAL;
headPtrDescriptorImageInfo.imageView = headPtrTextureImageView[currentFrame];
headPtrDescriptorImageInfo.sampler = headPtrTextureSampler[currentFrame];
descriptorWrites[1].sType = VK_STRUCTURE_TYPE_WRITE_DESCRIPTOR_SET;
descriptorWrites[1].dstSet = descriptorSets[descriptorId][0][currentFrame];
descriptorWrites[1].dstBinding = 1;
descriptorWrites[1].dstArrayElement = 0;
descriptorWrites[1].descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_IMAGE;
descriptorWrites[1].descriptorCount = 1;
descriptorWrites[1].pImageInfo = &headPtrDescriptorImageInfo;
VkDescriptorBufferInfo linkedListStorageBufferInfoLastFrame{};
linkedListStorageBufferInfoLastFrame.buffer = linkedListShaderStorageBuffers[currentFrame];
linkedListStorageBufferInfoLastFrame.offset = 0;
unsigned int nodeSize = 5 * sizeof(float) + sizeof(unsigned int);
linkedListStorageBufferInfoLastFrame.range = maxNodes * nodeSize;
descriptorWrites[2].sType = VK_STRUCTURE_TYPE_WRITE_DESCRIPTOR_SET;
descriptorWrites[2].dstSet = descriptorSets[descriptorId][0][currentFrame];
descriptorWrites[2].dstBinding = 2;
descriptorWrites[2].dstArrayElement = 0;
descriptorWrites[2].descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
descriptorWrites[2].descriptorCount = 1;
descriptorWrites[2].pBufferInfo = &linkedListStorageBufferInfoLastFrame;
VkDescriptorBufferInfo modelDataStorageBufferInfoLastFrame{};
modelDataStorageBufferInfoLastFrame.buffer = modelDataBufferMT[p][currentFrame];
modelDataStorageBufferInfoLastFrame.offset = 0;
modelDataStorageBufferInfoLastFrame.range = maxAlignedSizeModelData[p];
descriptorWrites[3].sType = VK_STRUCTURE_TYPE_WRITE_DESCRIPTOR_SET;
descriptorWrites[3].dstSet = descriptorSets[descriptorId][0][currentFrame];
descriptorWrites[3].dstBinding = 3;
descriptorWrites[3].dstArrayElement = 0;
descriptorWrites[3].descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER_DYNAMIC;
descriptorWrites[3].descriptorCount = 1;
descriptorWrites[3].pBufferInfo = &modelDataStorageBufferInfoLastFrame;
VkDescriptorBufferInfo materialDataStorageBufferInfoLastFrame{};
materialDataStorageBufferInfoLastFrame.buffer = materialDataBufferMT[p][currentFrame];
materialDataStorageBufferInfoLastFrame.offset = 0;
materialDataStorageBufferInfoLastFrame.range = maxAlignedSizeMaterialData[p];
descriptorWrites[4].sType = VK_STRUCTURE_TYPE_WRITE_DESCRIPTOR_SET;
descriptorWrites[4].dstSet = descriptorSets[descriptorId][0][currentFrame];
descriptorWrites[4].dstBinding = 4;
descriptorWrites[4].dstArrayElement = 0;
descriptorWrites[4].descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER_DYNAMIC;
descriptorWrites[4].descriptorCount = 1;
descriptorWrites[4].pBufferInfo = &materialDataStorageBufferInfoLastFrame;
descriptorWrites[5].sType = VK_STRUCTURE_TYPE_WRITE_DESCRIPTOR_SET;
descriptorWrites[5].dstSet = descriptorSets[descriptorId][0][currentFrame];
descriptorWrites[5].dstBinding = 5;
descriptorWrites[5].dstArrayElement = 0;
descriptorWrites[5].descriptorType = VK_DESCRIPTOR_TYPE_COMBINED_IMAGE_SAMPLER;
descriptorWrites[5].descriptorCount = allTextures.size();
descriptorWrites[5].pImageInfo = descriptorImageInfos.data();
vkUpdateDescriptorSets(vkDevice.getDevice(), static_cast<uint32_t>(descriptorWrites.size()), descriptorWrites.data(), 0, nullptr);
std::array<VkWriteDescriptorSet, 2> descriptorWrites{};
descriptorWrites[0].descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_IMAGE;
descriptorWrites[0].pImageInfo = &headPtrDescriptorImageInfo;
descriptorWrites[1].descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
descriptorWrites[1].pBufferInfo = &linkedListStorageBufferInfoLastFrame;
} else {
VkDescriptorImageInfo descriptorImageInfo;
std::array<VkWriteDescriptorSet, 1> descriptorWrites{};
descriptorImageInfo.imageLayout = VK_IMAGE_LAYOUT_SHADER_READ_ONLY_OPTIMAL;
descriptorImageInfo.imageView = skybox->getTexture().getImageView();
descriptorImageInfo.sampler = skybox->getTexture().getSampler();
descriptorWrites[0].descriptorType = VK_DESCRIPTOR_TYPE_COMBINED_IMAGE_SAMPLER;
descriptorWrites[0].pImageInfo = &descriptorImageInfo;
void PerPixelLinkedListRenderComponent::createDescriptorSetLayout2(RenderStates states) {
headPtrImageLayoutBinding.binding = 0;
linkedListLayoutBinding.binding = 1;
std::array<VkDescriptorSetLayoutBinding, 2> bindings = {headPtrImageLayoutBinding, linkedListLayoutBinding};
I don’t understand why I’ve device lost issue, without recreating descriptors everything runs fine…
