based on baristankut’s Spark image, inspired by shahizat.
Still subject to further testing — does it respond with DFlash the same way as without? But the token rate is outstanding.
Setup Overview
| Component | Details |
| Base Image | lmsysorg/sglang:spark (arm64, SM121, PyTorch 2.9.0, sgl-kernel 0.3.16) |
| SGLang Version | 0.5.6 from PR #16818 (DFlash Speculative Decoding) |
| flashinfer | 0.6.3 (pure Python, JIT via TVM/Triton) |
| Target Model | Qwen3-Coder-30B-A3B-Instruct BF16 (57 GB, 16 Shards) |
| Draft Model | z-lab/Qwen3-Coder-30B-A3B-DFlash (~900 MB, 0.5B Diffusion Drafter) |
| Performance | 50.1 tok/s on DGX Spark |
| SM121 Workarounds | DeepGEMM disabled, flashinfer instead of FA3, BF16 instead of FP8 |
Dockerfile
FROM docker.io/lmsysorg/sglang:spark
# DFlash on top of lmsysorg/sglang:spark (arm64, GB10/SM121)
# sgl-kernel + Triton already compiled for DGX Spark
# Remove old flashinfer-cubin (0.5.0, conflicts with new flashinfer)
# Upgrade flashinfer 0.6.3 (pure Python wheel, kernels via TVM/Triton JIT)
RUN pip uninstall -y --break-system-packages flashinfer-cubin && \
pip install --no-cache-dir --break-system-packages \
"flashinfer-python>=0.5.3"
# Install DFlash SGLang PR (overwrites stock SGLang)
RUN pip install --no-cache-dir --no-deps --break-system-packages \
"git+https://github.com/sgl-project/sglang.git@refs/pull/16818/head#subdirectory=python"
# Patch: fused_qk_norm_rope missing in sgl-kernel 0.3.16 (spark)
# SGLang 0.5.6 imports it top-level → entire Qwen3MoE module fails
# Fix: try/except so the unfused fallback path is used
RUN python3 -c "\
p = '/usr/local/lib/python3.12/dist-packages/sglang/srt/models/qwen3_moe.py'; \
t = open(p).read(); \
t = t.replace( \
' from sgl_kernel import fused_qk_norm_rope', \
' try:\\n from sgl_kernel import fused_qk_norm_rope\\n except ImportError:\\n fused_qk_norm_rope = None'); \
open(p,'w').write(t)"
WORKDIR /
Launch Script
#!/bin/bash
set -euo pipefail
TARGET_MODEL="/data/tensordata/Qwen3-Coder-30B-A3B-Instruct"
DRAFT_MODEL="/data/tensordata/Qwen3-Coder-30B-A3B-DFlash"
PORT=8011
CONTAINER_NAME="dflash"
podman run -d \
--replace \
--name "$CONTAINER_NAME" \
--device nvidia.com/gpu=all \
--security-opt=label=disable \
--hooks-dir=/usr/share/containers/oci/hooks.d \
--ipc=host \
--network host \
-v /data/tensordata:/data/tensordata \
-v "$HOME/.cache/huggingface:/root/.cache/huggingface" \
-e SGLANG_ALLOW_OVERWRITE_LONGER_CONTEXT_LEN=1 \
-e SGLANG_SKIP_SGL_KERNEL_VERSION_CHECK=1 \
-e SGLANG_ENABLE_JIT_DEEPGEMM=false \
localhost/dflash \
python3 -m sglang.launch_server \
--model-path "$TARGET_MODEL" \
--speculative-algorithm DFLASH \
--speculative-draft-model-path "$DRAFT_MODEL" \
--host 0.0.0.0 \
--port "$PORT" \
--served-model-name qwen3-coder-30b-dflash \
--tp-size 1 \
--dtype bfloat16 \
--attention-backend flashinfer \
--mem-fraction-static 0.75 \
--trust-remote-code
The key insight: DFlash speculative decoding with a tiny 0.5B diffusion drafter “gives” roughly a 6x speedup on the Spark. All the SM121 pain points (no FA3, no FP8 GEMM, no DeepGEMM) are worked around — flashinfer JIT + BF16 does the job.
BF16 Memory-Bound Throughput Calculation
| Parameter | Value |
| Active parameters per token | 3B (MoE, A3B) |
| Bytes per parameter (BF16) | 2 |
| Weights per token | 3B × 2 = 6 GB |
| Memory bandwidth GB10 | 273 GB/s |
Theoretical maximum: 273 GB/s ÷ 6 GB/token = 45.5 tok/s
This lines up well with what we’re seeing:
| Mode | tok/s | vs. Theory |
| Theory (100% BW) | 45.5 | 100% |
| DFlash (measured) | 50.1 | 110% |
| Vanilla (estimated) | ~35–40 | ~80–85% |
DFlash exceeds the single-token limit because speculative decoding validates multiple tokens per target forward pass — the drafter proposes e.g. 4–8 tokens, the target verifies them in a single batch. This means >1 token is generated per weight load cycle.
With vanilla autoregressive inference (no speculation), you’d realistically expect ~38–40 tok/s (85–90% bandwidth utilization, plus attention/embedding overhead).
So DFlash delivers roughly 25–30% speedup beyond the pure memory bandwidth limit.
Lets find the missing 470%
