DGX Spark GB10 / vLLM 0.19.1: TurboQuant KV cache integration results on Qwen3.5 and Nemotron, including gather-free Triton decode and CUDA WPH decode
This post summarizes the current state of my TurboQuant work on DGX Spark GB10 (Blackwell, SM121) with a patched vLLM 0.19.1 stack.
Repository:
https://github.com/bjk110/spark_vllm_docker/tree/feat/turboquant
Environment
  • Hardware: DGX Spark GB10 (Blackwell, SM121) ×2
  • Memory: 121 GB unified
  • Base image: NGC PyTorch 26.03
  • vLLM: 0.19.1 (a7d79fa, source build)
  • FlashInfer: 0.6.7 (CUTLASS 4.4.2, SM121 source build)
  • PyTorch: 2.11.0a0
  • CUDA: 13.2
  • Transformers: 5.5.0
  • TurboQuant base: vLLM PR #38280
  • CUDA WPH extension: AOT build, SM121, BLOCK_D=128/256
Summary of changes
1. Initial TurboQuant integration
  • Ported PR #38280 onto vLLM 0.19.1
  • Resolved page-size mismatch with _next_pow2(slot_bytes) padding
  • Increased KV cache capacity from 155K to 413K tokens
2. Incremental decode
  • Added dirty-block-only decode
  • Added full decode fallback for CUDA graph capture path
  • Improved c=4 throughput from 31.2 to 36.3 t/s
3. Gather-free Triton decode
  • Removed cache[flat_bt] full memcpy/gather path
  • Triton kernel now reads paged cache directly
  • Added early exit for padding slots
  • Fixed odd-offset fp16 crash (norm_offset=93) using byte-level _safe_view_fp16
  • Improved c=4 throughput from 36.3 to 39.9 t/s
4. CUDA WPH decode
  • Implemented AOT-built CUDA warp-per-head decode for SM121/aarch64
  • Added gather-free direct paged-cache read
  • Added BLOCK_D=128/256 template dispatch
  • Moved norm read into the CUDA kernel
  • Added 4-warp CTA configuration (128 threads)
  • Current WPH path is slightly faster than Triton on Qwen3.5 at c=2 and c=4
Main issues encountered
Issue Cause Resolution
Page-size mismatch TurboQuant slot size mismatch with Mamba/GDN layers _next_pow2() padding
CUDA graph capture crash Python-side CPU ops (.tolist(), .unique()) capture-aware branching
WPH serving garbage output output tensor mismatch under old path gather-free direct-read conversion
Odd norm_offset fp16 crash misaligned fp16 view at offset 93 byte-level _safe_view_fp16
BLOCK_D=128 mismatch with head_dim=256 models WPH hardcoded for 128 templated BLOCK_D=128/256
Low occupancy with 1-warp CTA insufficient scheduler utilization 4-warp CTA
AOT build namespace error at::cuda no longer valid in this path c10::cuda
Nemotron int32 block_table incompatibility int32 block table input cast to int64
Results
Qwen3.5-122B-A10B-NVFP4 (TP1)
Metric bf16 KV TQ Triton TQ WPH v2
tg32 c=1 17.0 t/s 14.1 t/s 14.0 t/s
tg32 c=2 33.3 t/s 23.5 t/s 24.5 t/s
tg32 c=4 55.2 t/s 39.7 t/s 40.6 t/s
KV cache 155K 405K 405K
Korean QA sanity — 12/12 pass 12/12 pass
Interpretation:
  • KV cache increased from 155K to 405K
  • Initial TurboQuant c=4 throughput was 31.2 t/s
  • Current WPH v2 c=4 throughput is 40.6 t/s
  • This is approximately a 30% recovery relative to the initial TurboQuant state, while keeping the larger KV cache budget
Nemotron-H 120B-A12B-NVFP4 (TP1)
Metric TQ Triton TQ WPH v2
tg32 c=1 15.1 t/s 15.3 t/s
KV cache 1,548K 1,423K
Compatibility OK OK
Gemma 4 31B-it
Current status: not supported in this branch.
Reason:
  • heterogeneous head_dim (256 + 512)
  • vLLM currently forcing TRITON_ATTN
  • likely requires per-layer backend dispatch or BLOCK_D=512 support
Regression test
Added:
  • scripts/test_wph_v2.py
Current status:
  • 6/6 PASS
  • covers BLOCK_D=128/256, outlier on/off, multi-head, and stress cases
Current status
At this point:
  • TurboQuant integration is functional on DGX Spark GB10
  • gather-free Triton decode is stable
  • CUDA WPH direct-read decode is functional in serving
  • 4-warp CTA is currently the best-performing WPH configuration
  • On Qwen3.5, WPH is slightly faster than Triton at c=2 and c=4
  • The main practical gain remains the increased KV cache budget
Relevant commits
  • 7fe59cf — TurboQuant full implementation
  • bf4ca06 — branch-specific README / development history
  • f1e3239 — WPH int32 fix + Nemotron/Gemma4 presets
Remaining work
Main items not addressed yet:
  1. Better support for heterogeneous head_dim models
  2. Additional CTA/layout experiments beyond the current 4-warp configuration
  3. Possible cleanup for upstreaming the gather-free WPH path independently of the full branch
If useful, I can post a follow-up with implementation details or a phase-by-phase patch breakdown.
Outstanding! Can’t wait to test it; past bedtime here :) Thank you for sharing all your insights and the repo.
Thanks for sharing, I will move this to GB10 projects
Thanks for sharing
Very much interested in a follow-up and seeing your work being contributed back to spark-vllm-docker, too!
Given Gemma 4 31B is my daily driver I’d especially appreciate to see if you can get it to work.
Thanks for sharing. Do I interpret it correctly that this early implementation/PoC allows using prompts utilizing ~ 2.6x more KV cache at small performance hit and no noticeable accuracy loss vs FP16?
Or the same as above , but rather so far, it only gives 2.6x cache compression in VRAM/unified memory? so still the same context size is used for prefill, but the benefit is that it takes 2.6x less VRAM/memory?
