Hey all,
I’ve been banging my head against this for hours. Running a Qwen3.6-27B AWQ INT8 model (cyankiwi/Qwen3.6-27B-AWQ-BF16-INT8, compressed-tensors format) on a DGX Spark (GB10 Blackwell, SM_120) with vLLM 0.21.0 and it’s completely impossible to get it running.
THE PROBLEM
The only kernel that can handle W8A16 INT8 on vLLM is conch-triton-kernels (v1.3 by Stack AV). Every other kernel rejects it:
Marlin: “Quant type (uint8) not supported, supported types are: [ScalarType.uint4]”
Exllama: “only supports float16 activations”
AllSpark: “Zero points currently not supported”
So conch-triton-kernels is installed, vLLM picks it up (Using ConchLinearKernel for CompressedTensorsWNA16), model loads fine (34.44 GiB), and then it crashes with:
torch.AcceleratorError: CUDA error: an illegal memory access was encountered
Crash location: conch/ops/quantization/gemm.py:164 in mixed_precision_gemm
WHAT I’VE TRIED (everything fails with same error)
–enforce-eager (no torch.compile, no CUDA graphs) → Same crash
–kv-cache-dtype fp8_e4m3 → Same crash
–kv-cache-dtype auto (bf16 KV) → Same crash
CUDA_MANAGED_FORCE_DEVICE_ALLOC=1 → Same crash
TRITON_NUM_STAGES=1 → Same crash
All of the above combined → Same crash
–gpu-memory-utilization from 0.85 to 0.90 → Same crash
–max-num-batched-tokens 80k and 131k → Same crash
Clearing Triton cache → Same crash
MY THEORY
DGX Spark (GB10) uses unified memory (CPU+GPU share the same 128GB). Triton JIT-compiled kernels assume discrete GPU memory (standard CUDA device pointers). On unified memory, the generated PTX uses TMA descriptors / L2 residency hints that don’t work with cudaMallocManaged regions which causes the illegal memory access.
This matches Triton issue #9348 (make_block_ptr + TMA on SM90+) but there’s no fix available. GB10 is SM_120 (Blackwell) so likely same class of issue.
SETUP
Hardware: NVIDIA DGX Spark (GB10 Blackwell, SM_120, 128GB unified memory, aarch64)
Driver: 580.159
CUDA: 12.8
vLLM: 0.21.0
PyTorch: 2.11.0
conch-triton-kernels: 1.3
Model: cyankiwi/Qwen3.6-27B-AWQ-BF16-INT8 (compressed-tensors, W8A16)
WHAT WORKS FINE ON SAME HARDWARE
BF16 unquantized Qwen3.6-27B runs perfectly for 13+ hours
All standard vLLM features (prefix caching, chunked prefill, MTP speculative decoding)
QUESTIONS
Has anyone successfully run W8A16 INT8 quantized models on DGX Spark / GB10 Blackwell (or any unified memory system)?
Is there an alternative to conch-triton-kernels for INT8 W8A16? (Machete? CUTLASS direct?)
Is this a known limitation of unified memory (GB10/GH200) with Triton kernels?
Would INT4 AWQ (Marlin kernel) work fine since Marlin is pure CUDA, no Triton?
Any help appreciated. It feels like INT8 quantization is just completely unsupported on DGX Spark right now, which is wild given this is NVIDIA’s own hardware.
