I am trying to use the Modulus library to solve a set of partial differential equations, specifically, a set of heat diffusion equations with varying heat source terms. This requires DeepONet, and the methods in the manual all rely on prepared training data, but I hope to introduce physical information as constraints (predicted temperature results are brought into the equation to calculate the loss) without using training data, because I need to obtain training data through the finite element method, which is time-consuming. So, is there an example of this method that is completely physically driven? Or has anyone else tried this? Can you give me some guidance, thank you!
Related topics
| How to add real sensor data to PINN | 2 | 222 | March 13, 2025 | |
| How is the parametric PINN applied? | 5 | 2427 | July 14, 2022 | |
| Solving Fuselage Panel problem using DeepONet | 1 | 186 | July 15, 2024 | |
| Integral continuity constraints for DeepONets | 0 | 99 | October 9, 2024 | |
| Discrete Time PINNs in Modulus | 0 | 157 | July 22, 2024 | |
| How to create a digital twin with only data-driven? | 1 | 922 | December 21, 2022 | |
| Automatic differentiation in PINO | 4 | 1102 | July 21, 2023 | |
| New Course: Introduction to Physics-Informed Machine Learning with PhysicsNeMo | 0 | 865 | September 29, 2022 | |
| Using Physics-Informed Deep Learning for Transport in Porous Media | 1 | 743 | June 27, 2021 | |
| Using Nvidia Modulus for Non-PDE Equation | 0 | 887 | November 10, 2023 |
