Hi,everyone. I am setting DIGITS system on my host PC. When I installed NVcaffe, I encounter some questions. Here is error information:
(base) zhaoyu@zhaoyu:~$ cd caffe
(base) zhaoyu@zhaoyu:~/caffe$ make all
CXX .build_release/src/caffe/proto/caffe.pb.cc
In file included from .build_release/src/caffe/proto/caffe.pb.cc:4:0:
.build_release/src/caffe/proto/caffe.pb.h:17:2: error: #error This file was generated by an older version of protoc which is
.build_release/src/caffe/proto/caffe.pb.h:18:2: error: #error incompatible with your Protocol Buffer headers. Please
.build_release/src/caffe/proto/caffe.pb.h:19:2: error: #error regenerate this file with a newer version of protoc.
In file included from /usr/include/c++/5/atomic:38:0,
from /usr/local/include/google/protobuf/io/coded_stream.h:115,
from .build_release/src/caffe/proto/caffe.pb.h:23,
/usr/include/c++/5/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
#error This file requires compiler and library support \
In file included from /usr/local/include/google/protobuf/io/coded_stream.h:141:0,
/usr/local/include/google/protobuf/stubs/common.h: In function ‘void google::protobuf::internal::StrongReference(const T&)’:
/usr/local/include/google/protobuf/stubs/common.h:194:17: error: ‘unused’ does not name a type
auto volatile unused = &var;
/usr/local/include/google/protobuf/stubs/common.h:195:10: error: ‘unused’ was not declared in this scope
(void)&unused; // Use address to avoid an extra load of "unused".
In file included from /usr/local/include/google/protobuf/io/coded_stream.h:142:0,
/usr/local/include/google/protobuf/stubs/logging.h: In function ‘T* google::protobuf::internal::CheckNotNull(const char*, int, const char*, T*)’:
/usr/local/include/google/protobuf/stubs/logging.h:167:14: error: ‘nullptr’ was not declared in this scope
if (val == nullptr) {
In file included from /usr/local/include/google/protobuf/stubs/stringpiece.h:152:0,
from /usr/local/include/google/protobuf/stubs/strutil.h:39,
from /usr/local/include/google/protobuf/io/coded_stream.h:143,
/usr/local/include/google/protobuf/stubs/hash.h: At global scope:
/usr/local/include/google/protobuf/stubs/hash.h:51:31: error: expected template-name before ‘<’ token
struct hash : public std::hash<Key> {};
/usr/local/include/google/protobuf/stubs/hash.h:51:31: error: expected ‘{’ before ‘<’ token
/usr/local/include/google/protobuf/stubs/hash.h:51:31: error: expected unqualified-id before ‘<’ token
In file included from /usr/local/include/google/protobuf/stubs/strutil.h:39:0,
/usr/local/include/google/protobuf/stubs/stringpiece.h: In constructor ‘google::protobuf::StringPiece::StringPiece()’:
/usr/local/include/google/protobuf/stubs/stringpiece.h:212:24: error: ‘nullptr’ was not declared in this scope
StringPiece() : ptr_(nullptr), length_(0) {}
/usr/local/include/google/protobuf/stubs/stringpiece.h: In constructor ‘google::protobuf::StringPiece::StringPiece(const char*)’:
/usr/local/include/google/protobuf/stubs/stringpiece.h:216:16: error: ‘nullptr’ was not declared in this scope
if (str != nullptr) {
/usr/local/include/google/protobuf/stubs/stringpiece.h: In member function ‘void google::protobuf::StringPiece::clear()’:
/usr/local/include/google/protobuf/stubs/stringpiece.h:253:12: error: ‘nullptr’ was not declared in this scope
ptr_ = nullptr;
I have tried a whole day, but still cannot find the solution. If you have encounter the similar problems, hope you can help me solve the problem.
Thanks a lot.
Sophia
