Dino FAN small inference time is high
• Hardware (T4)
• Network Type (Dino FAN small)
• How to reproduce the issue ?
Converting the .pth weights into onnx (config attached below) and onnx to tensorRT and run the inference inside a docker with T4 GPU in cloud VM, with batch size as 1
When running the inference (for Dino FAN small FP32 ) to process 80 images , it took around 45 Sec, which is very close to the inference time of Dino FAN large FP32
But as mentioned in below NVIDIA docs Dino FAN small is around 2 times faster than Dino FAN large
Which is same for all the other small versions of Dino, than Dino FAN large
Could you please advice why is that and guide me on this
Configuration used for .pth weight to onnx conversion
export:
  gpu_id: 0
  input_width: 960
  input_height: 544
  opset_version: 17
  on_cpu: False
dataset:
  num_classes: 91
  batch_size: -1
model:
  backbone: fan_small
  num_feature_levels: 4
  dec_layers: 6
  enc_layers: 6
  num_queries: 900
  num_select: 100
  dropout_ratio: 0.0
  dim_feedforward: 2048
Configuration used for onnx to tensorRT
gen_trt_engine:
  gpu_id: 0
  input_width: 960
  input_height: 544
  tensorrt:
    data_type: fp32
    workspace_size: 4096
    min_batch_size: 1
    opt_batch_size: 8
    max_batch_size: 8
dataset:
  num_classes: 91
  batch_size: 1
model:
  backbone: fan_small
Please use trtexec to profile. You can refer to TRTEXEC with DINO - NVIDIA Docs.
For example, run below against the two onnx files.
trtexec --onnx=/path/to/model.onnx \
        --maxShapes=inputs:16x3x544x960 \
        --minShapes=inputs:1x3x544x960 \
        --optShapes=inputs:8x3x544x960 \
        --saveEngine=/path/to/save/trt/model.engine
Then check the log.
There is “compute time” in the log.
