Continuing the discussion from How to change the USB behavior of USB_VBUS_EN0 and USB_VBUS_EN1?:
I’ve configured a regulator for the USB_VBUS_EN0 port and a regulator for the USB_VBUS_EN1 port. These power regulators are defined as:
reg_5v_usb: regulator@11 {
compatible = "regulator-fixed";
reg = <11>;
regulator-name = "5V USB";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 2) GPIO_ACTIVE_HIGH>;
regulator-boot-on;
enable-active-high;
regulator-state-mem {
regulator-off-in-suspend;
but the part for regulator-off-in-suspend
doesn’t do anything. The power stays on for the USB during suspend (the 5V of the USB). When manually toggling the TEGRA194_MAIN_GPIO(Z, 2) pin, the 5V power goes off correctly
The vbus supply for the usb’s are set by setting the following:
xusb_padctl: xusb_padctl@3520000 {
status = "okay";
ports {
usb2-0 {
vbus-supply = <®_5v_rp>;
usb2-1 {
vbus-supply = <®_5v_fp>;
usb2-2 {
Am I doing something wrong for disabling the VBUS power during suspend?
