Hello NVIDIA Community,
I’m currently working with a Mellanox BlueField DPU and I’m facing some challenges regarding the power saving features that seem to be affecting the network performance.
I have used ethtool
to explore and adjust network card settings, but haven’t found any specific options related to power saving (like EEE - Energy Efficient Ethernet).
$ sudo ethtool -i enp3s0f0np0
driver: mlx5_core
version: 5.8-4.1.5
firmware-version: 18.24.0302 (MSF0000000005)
expansion-rom-version:
bus-info: 0000:03:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: yes
ethtool --show-features
- There were no EEE settings or similar power management features available to toggle.
$ sudo ethtool --set-eee enp3s0f0np0 eee off
Cannot get EEE settings: Operation not supported
I can find some configurations related to power but I don’t know what they mean:
$ sudo mlxconfig -d /dev/mst/mt41682_pciconf0 query
Device #1:
Device type: BlueField
Description: N/A
Device: /dev/mst/mt41682_pciconf0
Configurations: Next Boot
DISABLE_SLOT_POWER_LIMITER True(1)
ADVANCED_POWER_SETTINGS True(1)
More info:
$ sudo lshw -c network
*-network:0
description: Ethernet interface
product: MT416842 BlueField integrated ConnectX-5 network controller
vendor: Mellanox Technologies
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0f0np0
logical name: /dev/fb0
version: 00
serial: b8:59:9f:42:6d:24
capacity: 56Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pciexpress vpd msix pm bus_master cap_list rom ethernet physical 1000bt-fd 10000bt-fd 25000bt-fd 40000bt-fd 56000bt-fd autonegotiation fb
configuration: autonegotiation=on broadcast=yes depth=32 driver=mlx5_core driverversion=5.8-4.1.5 duplex=full firmware=18.24.0302 (MSF0000000005) ip=192.168.3.2 latency=0 link=yes mode=1024x768 multicast=yes promiscuous=yes visual=truecolor xres=1024 yres=768
resources: iomemory:3000-2fff irq:84 memory:30002000000-30003ffffff memory:96200000-962fffff memory:30006000000-300073fffff
*-network:1
physical id: 0.1
bus info: pci@0000:03:00.1
logical name: enp3s0f1np1
version: 00
serial: b8:59:9f:42:6d:25
capacity: 56Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=mlx5_core driverversion=5.8-4.1.5 firmware=18.24.0302 (MSF0000000005) ip=192.168.3.3 latency=0 link=yes multicast=yes promiscuous=yes
resources: iomemory:3000-2fff irq:149 memory:30004000000-30005ffffff memory:96300000-963fffff memory:30007400000-300087fffff
Given these details, I would appreciate any guidance on:
- How to check if any embedded power-saving modes are active that aren’t visible via
ethtool
. - Steps to disable these power-saving features to prioritize performance, particularly for latency-sensitive applications.
Has anyone else encountered similar challenges? Any advice on managing power settings specifically for Mellanox network cards in performance-critical environments would be very helpful.
Thank you in advance for your insights!
