Hi
I’m trying to profile my model (written in pytorch) with DLProf since pyprof is discontinued.
This is the command I used
sudo env “PATH=$PATH” dlprof -f true --reports=summary,detail,iteration,kernel,tensor --profile_name main-1 train.py --num-epochs 2
It will create .qdrep and .sqlite file.
But if I do dlprofviewer xx.sqlite, as instructed by the doc. I would get this error
dlprofviewer /tmp/nsys-report-e7ec-cffc-e4db-7208.sqlite
[dlprofviewer-07:24:08 PM UTC] dlprofviewer running at http://localhost:8000
Sqlite3 error: no such table: view_system_config
Here is the problem query: <SELECT is_valid,num_gpus,cpu_model,driver_version,framework,cuda_version,cudnn_version,nsys_version,dlprof_version,dlprof_build,profile_name,mode_string FROM view_system_config>
Using args: []
[dlprofviewer-07:24:11 PM UTC] Internal Server Error: /dlprof/dlprof/rest/sysconfig_panel
File "/miniconda3/envs/base/lib/python3.8/site-packages/asgiref/sync.py", line 482, in thread_handler
raise exc_info[1]
File "/miniconda3/envs/base/lib/python3.8/site-packages/django/core/handlers/exception.py", line 38, in inner
response = await get_response(request)
File "/miniconda3/envs/base/lib/python3.8/site-packages/django/core/handlers/base.py", line 233, in _get_response_async
response = await wrapped_callback(request, *callback_args, **callback_kwargs)
File "/miniconda3/envs/base/lib/python3.8/site-packages/asgiref/sync.py", line 444, in __call__
ret = await asyncio.wait_for(future, timeout=None)
File "/miniconda3/envs/base/lib/python3.8/asyncio/tasks.py", line 455, in wait_for
return await fut
File "/miniconda3/envs/base/lib/python3.8/site-packages/asgiref/current_thread_executor.py", line 22, in run
result = self.fn(*self.args, **self.kwargs)
File "/miniconda3/envs/base/lib/python3.8/site-packages/asgiref/sync.py", line 486, in thread_handler
return func(*args, **kwargs)
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/rest_endpoints.py", line 81, in sysconfig_panel
return process_endpoint(obj)
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/rest_endpoints.py", line 110, in process_endpoint
result = obj.get_result()
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/endpoints/sql.py", line 77, in get_one_result
db_rows = self.do_query(self._request, self._sql_query, self._sql_args)
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/endpoints/sql.py", line 45, in do_query
raise error
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/endpoints/sql.py", line 37, in do_query
cursor.execute(sql_query, sql_args)
sqlite3.OperationalError: no such table: view_system_config
Sqlite3 error: no such table: view_aggregations
Here is the problem query: <SELECT aggr_id,iter_start,iter_stop,iter_aggregated,key_node_name,user_name,host_name,aggr_start,aggr_end FROM view_aggregations ORDER BY aggr_start>
Using args: []
[dlprofviewer-07:24:11 PM UTC] Internal Server Error: /dlprof/dlprof/rest/aggregation_data
raise exc_info[1]
return await fut
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/rest_endpoints.py", line 37, in aggregation_data
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/endpoints/sql.py", line 63, in get_result
raise error
sqlite3.OperationalError: no such table: view_aggregations
Sqlite3 error: no such table: view_domains
Here is the problem query: <SELECT domain_name FROM view_domains ORDER BY domain_name >
Using args: []
[dlprofviewer-07:24:11 PM UTC] Internal Server Error: /dlprof/dlprof/rest/domain_data
raise exc_info[1]
return await fut
File "/miniconda3/envs/base/lib/python3.8/site-packages/dlprofviewer/dlprofwebserver-project/dlprof/rest_endpoints.py", line 41, in domain_data
raise error
sqlite3.OperationalError: no such table: view_domains
Env info:
conda 4.8.1
python3.8
conda list | grep cuda
cudatoolkit 11.1.1 h6406543_8 conda-forge
pytorch 1.9.0 py3.8_cuda11.1_cudnn8.0.5_0 pytorch
pip list | grep nvidia
nvidia-dlprof 1.2.0
nvidia-dlprof-pytorch-nvtx 1.2.0
nvidia-dlprofviewer 1.2.0
nvidia-ml-py3 7.352.0
nvidia-nsys-cli 2021.2.1.58
nvidia-pyindex 1.0.9
