DMA'ing into GPU card from another device
Does anyone know if it is possible to DMA directly into GPU memory from another PCI card? I guess that to be able to do this we’d need to allocate a block of GPU device memory and then get a handle/address for it which could be passed to the DMA master. Is this possible via the CUDA API or some other means? I assume that the GPU acts as a DMA master for the pinned memory transfer ops (?) but can it be pushed into? Has anyone tried this before?
regards
Mark
There is nothing in the CUDA API to facilitate direct DMA transfer between different PCI devices. However, this feature is requested every 6 months, so hopefully someone at NVIDIA is thinking about it.
