Do non-coalesced memory accesses cause branch divergence?
I always thought that branch divergence is only caused by the branching code, like “if”, “else”, “for”, “switch”, etc. However I have read a paper recently in which it says:
[i]" One can clearly observe that the number of divergent branches taken by threads in each first exploration-based algorithm is at least twice more important than the full exploration strategy. This is typically the results from additional non-coalesced accesses to the global memory. Hence, such a threads divergence leads to many memory accesses that have to be serialized, increasing the total number of instructions executed.
One can observe that the number of warp serializations for the version using non-coalesced accesses is between seven and sixteen times more important than for its counterpart. Indeed, a threads divergence caused by non-coalesced accesses leads to many memory accesses that have to be serialized, increasing the instructions to be executed. "[/i]
It seems like, according to the author, non-coalesced accesses can cause divergent branches. Is that true? My question is, how many reasons exactly are there for the branch divergence? Thanks in advance.
