Docker ABEND upon apt update/upgrade
I am hoping someone can point me in the right direction. I was running Docker on a Nvidia Orin with no issues. I did an apt update then upgrade this morning and apparently messed up my docker installation. It appears that the update/upgrade (I am leaning to upgrade) wiped out an overlay that was on the SSD. Below is the error message. Any guidance would be appreciated, e.g., should I just uninstall and reinstall docker? (Seems drastic)
ptc@orin:~$ docker run -d -it --rm -p 8888 --net=host -v /mnt/ssd:/mnt/ssd cronin/mlbase:version4
WARNING: Published ports are discarded when using host network mode
9e67d3eb58e7effddf79f4f20e4f60aa8cfb10f3c816bd7b8401753bc619019e
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #1: error running hook: exit status 1, stdout: , stderr: time="2024-12-19T10:30:03-05:00" level=info msg="Symlinking /mnt/ssd/docker/overlay2/7dede99aca991da3cbbe0f94db1c71c0e1dc5fc4c420bb6f6d20e6225c6f1a7d/merged/etc/vulkan/icd.d/nvidia_icd.json to /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json"
time="2024-12-19T10:30:03-05:00" level=error msg="failed to create link [/usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json /etc/vulkan/icd.d/nvidia_icd.json]: failed to create symlink: failed to remove existing file: remove /mnt/ssd/docker/overlay2/7dede99aca991da3cbbe0f94db1c71c0e1dc5fc4c420bb6f6d20e6225c6f1a7d/merged/etc/vulkan/icd.d/nvidia_icd.json: device or resource busy": unknown.
