nhira
October 27, 2025, 4:53am
1
As explained in this post , the community would appreciate a more recent NGC vLLM image. The current image (nvcr.io/nvidia/vllm:25.09-py3) does not support GGUF loading.
The workaround is to compile against the 25.09 base (as shown in the earlier post).
Specifically, I was trying to load gemma3-4b-it-q4_0, but that is blocked by another issue:
opened 02:09PM - 27 Oct 25 UTC
bug
### Your current environment
<details>
<summary>The output of <code>python coll… ect_env.py</code></summary>
```text
System Info
OS : Ubuntu 24.04.3 LTS (aarch64)
GCC version : (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
Clang version : Could not collect
CMake version : version 3.31.6
Libc version : glibc-2.39
PyTorch Info
PyTorch version : 2.9.0a0+50eac811a6.nv25.09
Is debug build : False
CUDA used to build PyTorch : 13.0
ROCM used to build PyTorch : N/A
Python Environment
Python version : 3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0] (64-bit runtime)
Python platform : Linux-6.11.0-1016-nvidia-aarch64-with-glibc2.39
CUDA / GPU Info
Is CUDA available : True
CUDA runtime version : 13.0.88
CUDA_MODULE_LOADING set to : LAZY
GPU models and configuration : GPU 0: NVIDIA GB10
Nvidia driver version : 580.95.05
cuDNN version : Probably one of the following:
/usr/lib/aarch64-linux-gnu/libcudnn.so.9.13.0
/usr/lib/aarch64-linux-gnu/libcudnn_adv.so.9.13.0
/usr/lib/aarch64-linux-gnu/libcudnn_cnn.so.9.13.0
/usr/lib/aarch64-linux-gnu/libcudnn_engines_precompiled.so.9.13.0
/usr/lib/aarch64-linux-gnu/libcudnn_engines_runtime_compiled.so.9.13.0
/usr/lib/aarch64-linux-gnu/libcudnn_graph.so.9.13.0
/usr/lib/aarch64-linux-gnu/libcudnn_heuristic.so.9.13.0
/usr/lib/aarch64-linux-gnu/libcudnn_ops.so.9.13.0
HIP runtime version : N/A
MIOpen runtime version : N/A
Is XNNPACK available : True
CPU Info
Architecture: aarch64
CPU op-mode(s): 64-bit
Byte Order: Little Endian
CPU(s): 20
On-line CPU(s) list: 0-19
Vendor ID: ARM
Model name: Cortex-X925
Model: 1
Thread(s) per core: 1
Core(s) per socket: 10
Socket(s): 1
Stepping: r0p1
CPU(s) scaling MHz: 91%
CPU max MHz: 4004.0000
CPU min MHz: 1378.0000
BogoMIPS: 2000.00
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mm svebf16 i8mm bf16 dgh bti ecv afp wfxt
Model name: Cortex-A725
Model: 1
Socket(s): 1
Stepping: r0p1
CPU(s) scaling MHz: 87%
CPU max MHz: 2860.0000
CPU min MHz: 338.0000
BogoMIPS: 2000.00
L1d cache: 1.3 MiB (20 instances)
L1i cache: 1.3 MiB (20 instances)
L2 cache: 25 MiB (20 instances)
L3 cache: 24 MiB (2 instances)
NUMA node(s): 1
NUMA node0 CPU(s): 0-19
Vulnerability Gather data sampling: Not affected
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Reg file data sampling: Not affected
Vulnerability Retbleed: Not affected
Vulnerability Spec rstack overflow: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Vulnerability Spectre v1: Mitigation; __user pointer sanitization
Vulnerability Spectre v2: Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Versions of relevant libraries
[pip3] flashinfer-python==0.4.1
[pip3] mypy_extensions==1.1.0
[pip3] numpy==2.1.0
[pip3] nvidia-cudnn-frontend==1.14.0
[pip3] nvidia-cutlass-dsl==4.2.1
[pip3] nvidia-dali-cuda130==1.51.2
[pip3] nvidia-ml-py==13.580.82
[pip3] nvidia-modelopt==0.33.0
[pip3] nvidia-modelopt-core==0.33.0
[pip3] nvidia-nvcomp-cu13==5.0.0.6
[pip3] nvidia-nvimgcodec-cu13==0.6.0.32
[pip3] nvidia-nvjpeg-cu13==0.0.0a0
[pip3] nvidia-nvjpeg2k-cu13==0.9.0.43
[pip3] nvidia-nvtiff-cu13==0.5.1.75
[pip3] nvidia-resiliency-ext==0.4.1+cuda13
[pip3] onnx==1.18.0
[pip3] onnx-ir==0.1.9
[pip3] onnxscript==0.3.1
[pip3] optree==0.17.0
[pip3] pynvml==13.0.1
[pip3] pyzmq==27.0.2
[pip3] torch==2.9.0a0+50eac811a6.nv25.9
[pip3] torch_tensorrt==2.9.0a0
[pip3] torchao==0.13.0+git
[pip3] torchprofile==0.0.4
[pip3] torchvision==0.24.0a0+98f8b375
[pip3] transformers==4.57.1
[pip3] triton==3.4.0+gitc817b9b6
[conda] Could not collect
vLLM Info
ROCM Version : Could not collect
vLLM Version : 0.11.1rc2.dev165+gd31f7844f.d20251019 (git sha: d31f7844f, date: 20251019)
vLLM Build Flags:
CUDA Archs: 8.0 8.6 9.0 10.0 11.0 12.0+PTX; ROCm: Disabled
GPU Topology:
GPU0 NIC0 NIC1 NIC2 NIC3 CPU Affinity NUMA Affinity GPU NUMA ID
GPU0 X NODE NODE NODE NODE 0-19 0 N/A
NIC0 NODE X PIX NODE NODE
NIC1 NODE PIX X NODE NODE
NIC2 NODE NODE NODE X PIX
NIC3 NODE NODE NODE PIX X
Legend:
X = Self
SYS = Connection traversing PCIe as well as the SMP interconnect between NUMA nodes (e.g., QPI/UPI)
NODE = Connection traversing PCIe as well as the interconnect between PCIe Host Bridges within a NUMA node
PHB = Connection traversing PCIe as well as a PCIe Host Bridge (typically the CPU)
PXB = Connection traversing multiple PCIe bridges (without traversing the PCIe Host Bridge)
PIX = Connection traversing at most a single PCIe bridge
NV# = Connection traversing a bonded set of # NVLinks
NIC Legend:
NIC0: rocep1s0f0
NIC1: rocep1s0f1
NIC2: roceP2p1s0f0
NIC3: roceP2p1s0f1
Environment Variables
NVIDIA_VISIBLE_DEVICES=all
CUBLAS_VERSION=13.0.2.14
PYTORCH_TRITON_VERSION=3.4.0+gitc817b9b6
NVIDIA_REQUIRE_CUDA=cuda>=9.0
TORCH_CUDA_ARCH_LIST=8.0 8.6 9.0 10.0 11.0 12.0+PTX
NCCL_VERSION=2.27.7
NVIDIA_DRIVER_CAPABILITIES=compute,utility,video
TORCH_NCCL_USE_COMM_NONBLOCKING=0
NVIDIA_PRODUCT_NAME=vLLM
CUDA_VERSION=13.0.1.012
PYTORCH_VERSION=2.9.0a0+50eac81
PYTORCH_BUILD_NUMBER=0
CUBLASMP_VERSION=0.5.1.65
CUDNN_FRONTEND_VERSION=1.14.0
NVIDIA_VLLM_VERSION=25.09
MAX_JOBS=12
CUDNN_VERSION=9.13.0.50
PYTORCH_HOME=/opt/pytorch/pytorch
LD_LIBRARY_PATH=/usr/local/lib/python3.12/dist-packages/torch/lib:/usr/local/lib/python3.12/dist-packages/torch_tensorrt/lib:/usr/local/cuda/compat/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64
NVIDIA_BUILD_ID=214638690
CUDA_DRIVER_VERSION=580.82.07
PYTORCH_BUILD_VERSION=2.9.0a0+50eac81
CUDA_HOME=/usr/local/cuda
CUDA_MODULE_LOADING=LAZY
NVIDIA_REQUIRE_JETPACK_HOST_MOUNTS=
NVIDIA_PYTORCH_VERSION=25.09
TORCH_ALLOW_TF32_CUBLAS_OVERRIDE=1
PYTORCH_NVML_BASED_CUDA_CHECK=1
TORCHINDUCTOR_COMPILE_THREADS=1
</details>
### 🐛 Describe the bug
I am trying to serve Gemma 3 4B (Q4_0 GGUF) on an NVIDIA DGX Spark using a quantization-aware checkpoint from HuggingFace.
Checkpoint: https://huggingface.co/google/gemma-3-4b-it-qat-q4_0-gguf/blob/main/gemma-3-4b-it-q4_0.gguf
I get an error trying to load the checkpoint using a custom Docker image. It feels related to the bf16/fp16 issue mentioned in [PR 26189](https://github.com/vllm-project/vllm/pull/26189).
Example response:
File "/workspace/vllm/vllm/model_executor/models/gemma3.py", line 564, in compute_logits
logits = self.logits_processor(self.model.embed_tokens, hidden_states)
File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1775, in _wrapped_call_impl
return self._call_impl(*args, **kwargs)
File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1786, in _call_impl
return forward_call(*args, **kwargs)
File "/workspace/vllm/vllm/model_executor/layers/logits_processor.py", line 60, in forward
logits = self._get_logits(hidden_states, lm_head, embedding_bias)
File "/workspace/vllm/vllm/model_executor/layers/logits_processor.py", line 92, in _get_logits
logits = lm_head.quant_method.apply(lm_head, hidden_states, bias=embedding_bias)
File "/workspace/vllm/vllm/model_executor/layers/quantization/gguf.py", line 477, in apply
out = fused_mul_mat_gguf(x, qweight, qweight_type)
File "/usr/local/lib/python3.12/dist-packages/torch/_ops.py", line 1254, in __call__
return self._op(*args, **kwargs)
File "/workspace/vllm/vllm/model_executor/layers/quantization/gguf.py", line 130, in _fused_mul_mat_gguf
return x @ qweight.T
RuntimeError: expected mat1 and mat2 to have the same dtype, but got: c10::BFloat16 != c10::Half
Command used:
# vLLM API server version 0.11.1rc2.dev165+gd31f7844f.d20251019 (see Dockerfile below)
CHECKPOINT=/root/.cache/huggingface/gemma-3-4b-it-q4_0.gguf
MODEL=google/gemma-3-4b-it
vllm serve ${CHECKPOINT} --tokenizer ${MODEL}
Key log entries:
[model.py:1969] Downcasting torch.float32 to torch.bfloat16.
[__init__.py:225] Automatically detected platform cuda.
[cuda.py:403] Using Flash Attention backend on V1 engine.
### Dockerfile used
# Start with the official NVIDIA NGC vLLM image.
# This provides the necessary CUDA, PyTorch, and Python environment.
FROM nvcr.io/nvidia/vllm:25.09-py3
WORKDIR /workspace
RUN git clone https://github.com/vllm-project/vllm.git && \
cd vllm && \
python3 use_existing_torch.py && \
pip3 install -r requirements/build.txt && \
MAX_JOBS=12 pip3 install -e . --no-build-isolation
# simple entrypoint for interactive use
CMD ["/bin/bash"]
### Why not try the NVIDIA/NGC image?
I cannot use `nvcr.io/nvidia/vllm:25.09-py3` because this uses an older version of vLLM that does not support GGUF-loading.
### Why not use the vLLM:nightly Docker image?
I cannot use the vLLM nightly image because it does not recognize this GPU.
HF_TOKEN=...
DOCKER_IMAGE="vllm/vllm-openai:nightly"
MODEL="google/gemma-3-4b-it"
MODEL_NAME="gemma-3-4b-it-q4_0"
CHECKPOINT="/root/.cache/huggingface/gemma-3-4b-it-q4_0.gguf"
docker run --gpus all --rm -it \
-v ~/.cache/huggingface:/root/.cache/huggingface \
-p 8000:8000 \
--env "HF_TOKEN=${HF_TOKEN}" \
--ipc=host --ulimit memlock=-1 --ulimit stack=67108864 \
${DOCKER_IMAGE} --model ${CHECKPOINT} --tokenizer ${MODEL} --hf-overrides '{"architectures": ["Gemma3ForCausalLM"]}' --served-model-name ${MODEL_NAME}
Error:
File "/usr/local/lib/python3.12/dist-packages/torch/_inductor/codegen/wrapper.py", line 1695, in generate_and_run_autotune_block
raise RuntimeError(f"Failed to run autotuning code block: {e}") from e
torch._inductor.exc.InductorError: RuntimeError: Failed to run autotuning code block: No valid triton configs. PTXASError: PTXAS error: Internal Triton PTX codegen error
`ptxas` stderr:
ptxas fatal : Value 'sm_121a' is not defined for option 'gpu-name'
Repro command: /usr/local/lib/python3.12/dist-packages/triton/backends/nvidia/bin/ptxas -lineinfo -v --gpu-name=sm_121a /tmp/tmp_kapypnl.ptx -o /tmp/tmp_kapypnl.ptx.o
### Before submitting a new issue...
- [x] Make sure you already searched for relevant issues, and asked the chatbot living at the bottom right corner of the [documentation page](https://docs.vllm.ai/en/latest/), which can answer lots of frequently asked questions.
Please correct/refine if you see any errors with this Dockerfile and invocation.
Dockerfile
WORKDIR /workspace
cd vllm && \
CMD ["/bin/bash"]
Invocation (from the container)
We recently released a new vLLM container, 25.10-py3. Please try this one and let us know if it works.
nhira
October 29, 2025, 8:34pm
3
Appreciate the help! Thank you. Unfortunately, the quantization issues won’t be solved until vLLM 0.11.x is included, so I’ll just add some instructions to my post and acknowledge the updated container image.
nhira
October 29, 2025, 8:46pm
4
It’s great to see an updated NGC vLLM container available, which includes vLLM v0.10.2 ! Thank you!
If you’d like to use a more recent version of vLLM (like v0.11.x so you can serve quantization-aware Gemma3 checkpoints), you can actually build an image right on the DGX Spark in a couple of hours.
You can start with this Dockerfile (this uses vLLM 0.11.1rc4)
FROM nvcr.io/nvidia/vllm:25.10-py3
WORKDIR /workspace
# Build vllm with the installed CUDA and PyTorch
# https://docs.vllm.ai/en/latest/getting_started/installation/gpu.html#use-an-existing-pytorch-installation
RUN git clone --branch v0.11.1rc4 https://github.com/vllm-project/vllm.git && \
cd vllm && \
CMD ["/bin/bash"]
Next, you can build the Docker container image
docker build \
--build-arg max_jobs=120 \
--build-arg nvcc_threads=20 \
--build-arg torch_cuda_arch_list="13.0" \
--build-arg CUDA_VERSION="13.0.1" \
--platform "linux/arm64" \
--file dgx-spark-cu13.Dockerfile \
--tag vllm-spark-cu13 .
You can start the container using something like this
HF_TOKEN=... # your HuggingFace auth token here
DOCKER_IMAGE="vllm-spark-cu13:latest"
-p 8000:8000 \
${DOCKER_IMAGE}
In the container, you can serve the unsloth Gemma (quantization-aware) using something like this (presuming you’ve downloaded the checkpoint from Hugging Face already):
export MODEL="unsloth/gemma-3-4b-it"
export MODEL_NAME="unsloth_gemma-3-4b-it-q4_0"
export CHECKPOINT="/root/.cache/huggingface/unsloth_gemma-3-4b-it-Q4_0.gguf"
vllm serve ${CHECKPOINT} \
--tokenizer ${MODEL} \
--served-model ${MODEL_NAME} \
--gpu-memory-utilization 0.75
In the latest vLLM container, 26.03, GGUF on Blackwell works as expected. You would still need to add --dtype float32 but other dtypes are now automatically rejected by vLLM anyways.
