Docker nvidia/vllm issue
recently, i refresh the dgx spark due to some issue
i download the docker from nvidai again,
but have below error, but seem driver 590 is not support DGx spark yet? any ideas?
NVIDIA Release 25.12.post1 (build 247811356)
vLLM Version 0.12.0+35a9f223
Container image Copyright (c) 2025, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
GOVERNING TERMS: The software and materials are governed by the NVIDIA Software License Agreement
(found at https://www.nvidia.com/en-us/agreements/enterprise-software/nvidia-software-license-agreement/)
and the Product-Specific Terms for NVIDIA AI Products
(found at https://www.nvidia.com/en-us/agreements/enterprise-software/product-specific-terms-for-ai-products/).
ERROR: This container was built for NVIDIA Driver Release 590.44 or later, but
version 580.126.09 was detected and compatibility mode is UNAVAILABLE.
That is a very old container version (for LLM time), 3 months out of date. My guess is you had it pinned.
If you want to stick with NGC image, pull nvcr.io/nvidia/vllm:26.02-py3 and try again. Or, better yet, clone https://github.com/eugr/spark-vllm-docker and run ./build-and-copy.sh
yes, i pull nvcr.io/nvidia/vllm:26.02-py3 also have this issue, so i try to use old version, not sure why, previous, i can run old version wihtout issue before i factory reset
DGX Spark currently supports version 590 drivers. I am using version 590.48.01 drivers.
| NVIDIA-SMI 590.48.01 Driver Version: 590.48.01 CUDA Version: 13.1 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GB10 On | 0000000F:01:00.0 Off | N/A |
| N/A 73C P0 39W / N/A | Not Supported | 84% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 6337 C …RayWorkerWrapper.ray_call 10873… |
590 drivers have not been rolled into the official update as far as I am able to tell. I’m not surprised things don’t work. Any particular reason for attempting this?
Which version of DGX OS do you have? The newest Version 7.4 (?) doesn’t have 590 Drivers…
