I want to achieve:
- launch kernel 1 on stream 1 , record event 1
- let stream 2 wait for event 1, and then launch kernel 2
- launch kernel 3 on stream 2
The idea is I want kernel 2 and kernel 3 concurrently execute, but also want to make sure kernel 2 executes after kernel 1.
However, with the following code, I find kernel 2 and kernel 3 still executes sequentially:
Here is my code:
#include <iostream>
#include <cuda_runtime.h>
// Kernel functions to perform computation
__global__ void kernel1(int64_t *data, int64_t repeat) {
int idx = threadIdx.x + blockIdx.x * blockDim.x;
for (size_t i = 0; i < repeat; i++)
data[idx] += 1;
__global__ void kernel2(int64_t *data, int64_t repeat) {
data[idx] += 2;
__global__ void kernel3(int64_t *data, int64_t repeat) {
data[idx] -= 1;
int main() {
const int dataSize = 1024;
const int printSize = 10;
int64_t *h_data = new int64_t[dataSize]; // Host data
int64_t *d_data1, *d_data2; // Device data
// Initialize host data
for (int i = 0; i < dataSize; i++) {
h_data[i] = 0;
// Allocate memory on the device
cudaMalloc((void**)&d_data1, dataSize * sizeof(int64_t));
cudaMalloc((void**)&d_data2, dataSize * sizeof(int64_t));
// Transfer data from host to device
cudaMemcpy(d_data1, h_data, dataSize * sizeof(int64_t), cudaMemcpyHostToDevice);
cudaMemcpy(d_data2, h_data, dataSize * sizeof(int64_t), cudaMemcpyHostToDevice);
// Define grid and block dimensions
dim3 blockDim(256);
dim3 gridDim((dataSize + blockDim.x - 1) / blockDim.x);
// Create streams and event
cudaStream_t stream1, stream2;
cudaEvent_t event1;
cudaStreamCreate(&stream1);
cudaStreamCreate(&stream2);
cudaEventCreate(&event1);
const int64_t repeat = 1000 * 100;
// Execute kernel1 in stream1
kernel1<<<gridDim, blockDim, 0, stream1>>>(d_data1, repeat);
cudaEventRecord(event1, stream1); // Record event1 after kernel1 execution in stream1
// Execute kernel2 in stream2, waiting for event1
cudaStreamWaitEvent(stream2, event1, 0);
kernel2<<<gridDim, blockDim, 0, stream2>>>(d_data1, repeat);
// Execute kernel3 in stream1 on a different array
kernel3<<<gridDim, blockDim, 0, stream1>>>(d_data2, repeat);
// Synchronize streams
cudaStreamSynchronize(stream1);
cudaStreamSynchronize(stream2);
// Transfer data back from device to host
cudaMemcpy(h_data, d_data1, dataSize * sizeof(int64_t), cudaMemcpyDeviceToHost);
// Display the result for d_data1
std::cout << "Data after kernel1 and kernel2:" << std::endl;
for (int i = 0; i < printSize; i++) {
std::cout << h_data[i] << " ";
std::cout << std::endl;
// Transfer data back from device to host for d_data2
cudaMemcpy(h_data, d_data2, dataSize * sizeof(int64_t), cudaMemcpyDeviceToHost);
// Display the result for d_data2
std::cout << "Data after kernel3:" << std::endl;
// Free device memory and destroy streams and event
cudaFree(d_data1);
cudaFree(d_data2);
delete[] h_data;
cudaStreamDestroy(stream1);
cudaStreamDestroy(stream2);
cudaEventDestroy(event1);
return 0;
It seems kernel 3 is blocked by kernel 2. That’s why I ask the question: does cudaStreamWaitEvent(stream2, event1, 0) also block the stream to record event1?
