Does NVCC include header files automatically?
Hello.
I wrote some CUDA code not including any CUDA header files like cuda.h. And I used some CUDA functions like cudaMalloc(). But the code could be compiled and run successfully.
Does NVCC include header files automatically? Is there any document to mention this feature?
nvcc automatically includes CUDA-specific header files when handling code in .cu files. You still need to include the standard C/C++ header files and header files for any libraries delivered with CUDA, if you use functions exported by these header files.
Thanks for your reply. I think that is the answer I want.
Hi can you please specify an official document that support this feature
Programming Guide, p. 43:
[…] nvcc implicitly includes cuda_runtime.h at the top of the translation unit.
If you look at cuda_runtime.h it pulls in a number of other CUDA-specific header files. Until just now I have never looked where this is documented, as this has been the case ever since the CUDA runtime API was created around the year 2006 and I was its first users.
I vaguely recall that the idea behind this header file pre-inclusion was to make writing CUDA programs as similar to writing normal C programs as possible (CUDA was initially based on C and did not switch to C++ until 2009 or so), which was considered important for broad acceptance of a new programming environment.
If you use APIs other than the CUDA runtime API you will still need to include the header files for those. I greped through the nvcc.exe binary just now and see no evidence of header files other than cuda_runtime.h being pre-included.
you can also see what nvcc includes using dryrun or verbose compile options (also confirms it is only cuda_runtime.h)
