Does TAO 5.0 support exporting a model trained by TAO 3.0?
• Hardware (T4/V100/Xavier/Nano/etc): GPU
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc): Yolo_v4
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here): NA
• Training spec file(If have, please share here): NA
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.): NA
I need to deploy a Yolo_v4 model trained using TAO 3.0 in Deepstream 8.0, since tao-converter is deprecated and the exported file is .etlt, I used nvinfer to build the engine but I got this error:
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1261 Deserialize engine failed because file path: /home/me/detector/detector.engine open error
0:00:00.321296740 3265927 0x5b20590ec6e0 WARN                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<detector> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2097> [UID = 1]: deserialize engine from file :/home/me/detector/detector.engine failed
0:00:00.321311770 3265927 0x5b20590ec6e0 WARN                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<detector> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2202> [UID = 1]: deserialize backend context from engine from file :/home/me/detector/detector.engine failed, try rebuild
0:00:00.321319070 3265927 0x5b20590ec6e0 INFO                 nvinfer gstnvinfer.cpp:685:gst_nvinfer_logger:<detector> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2123> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnxOpImporters.cpp:6521: Attribute caffeSemantics not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
WARNING: [TRT]: BatchedNMSPlugin is deprecated since TensorRT 9.0. Use INetworkDefinition::addNMS() to add an INMSLayer OR use EfficientNMS plugin.
WARNING: [TRT]: Calibration Profile is not defined. Calibrating with Profile 0
ERROR: [TRT]: Unexpected exception _Map_base::at
It seems that the model was exported with BatchedNMSPlugin which is deprecated since TensorRT 9.0 and Deepstream 8.0 uses TensorRT 10.9 so nvinfer cannot build an engine for this .etltfile.
Can I re-export the original .tlt file (trained using TAO 3.0) to .onnx using TAO 5.0? If not, how do I deploy a model trained using TAO 3.0 to Deepstream 8.0?
Please try either of below options.
  1. Please try to change the .etlt file to .onnx file. Reference: tao_toolkit_recipes/tao_forum_faq/FAQ.md at main · NVIDIA-AI-IOT/tao_toolkit_recipes · GitHub.
  2. Please try to change the .tlt file to .hdf5 file. Reference: tao_toolkit_recipes/tao_forum_faq/FAQ.md at main · NVIDIA-AI-IOT/tao_toolkit_recipes · GitHub. And then export to .onnx file using TAO5.0.
@Morganh
After I convert the .etlt file to .onnx file and use trtexec to build an int8 engine from the .onnx file.
The .onnx file was converted from a .etlt file exported using TAO 3.0 following the link you provided, the calibration file is for the .etlt file, I reuse the same the calibration file for the .onnx file to build engine file.
I got this error:
[11/07/2025-13:22:05] [I] [TRT] No checker registered for op: BatchedNMSDynamic_TRT. Attempting to check as plugin.
[11/07/2025-13:22:05] [I] [TRT] No importer registered for op: BatchedNMSDynamic_TRT. Attempting to import as plugin.
[11/07/2025-13:22:05] [I] [TRT] Searching for plugin: BatchedNMSDynamic_TRT, plugin_version: 1, plugin_namespace:
[11/07/2025-13:22:05] [W] [TRT] onnxOpImporters.cpp:6521: Attribute caffeSemantics not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
[11/07/2025-13:22:05] [W] [TRT] BatchedNMSPlugin is deprecated since TensorRT 9.0. Use INetworkDefinition::addNMS() to add an INMSLayer OR use EfficientNMS plugin.
[11/07/2025-13:22:05] [I] [TRT] Successfully created plugin: BatchedNMSDynamic_TRT
[11/07/2025-13:22:05] [I] Finished parsing network model. Parse time: 0.015883
[11/07/2025-13:22:05] [I] Set shape of input tensor Input for optimization profile 0 to: MIN=1x3x832x4096 OPT=3x3x832x4096 MAX=3x3x832x4096
[11/07/2025-13:22:05] [I] FP32 and INT8 precisions have been specified - more performance might be enabled by additionally specifying --fp16 or --best
[11/07/2025-13:22:05] [I] Set calibration profile for input tensor Input to 3x3x832x4096
[11/07/2025-13:22:05] [I] [TRT] Calibration table does not match calibrator algorithm type.
[11/07/2025-13:22:05] [I] [TRT] Perform graph optimization on calibration graph.
[11/07/2025-13:22:05] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[11/07/2025-13:22:06] [I] [TRT] Compiler backend is used during engine build.
[11/07/2025-13:22:07] [I] [TRT] Detected 1 inputs and 4 output network tensors.
[11/07/2025-13:22:07] [I] [TRT] Total Host Persistent Memory: 430976 bytes
[11/07/2025-13:22:07] [I] [TRT] Total Device Persistent Memory: 0 bytes
[11/07/2025-13:22:07] [I] [TRT] Max Scratch Memory: 55355904 bytes
[11/07/2025-13:22:07] [I] [TRT] [BlockAssignment] Started assigning block shifts. This will take 284 steps to complete.
[11/07/2025-13:22:07] [I] [TRT] [BlockAssignment] Algorithm ShiftNTopDown took 29.9706ms to assign 19 blocks to 284 nodes requiring 1458625536 bytes.
[11/07/2025-13:22:07] [I] [TRT] Total Activation Memory: 1458625536 bytes
[11/07/2025-13:22:07] [I] [TRT] Total Weights Memory: 6216192 bytes
[11/07/2025-13:22:07] [I] [TRT] Compiler backend is used during engine execution.
[11/07/2025-13:22:07] [I] [TRT] Engine generation completed in 1.58926 seconds.
[11/07/2025-13:22:07] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +1391, now: CPU 0, GPU 1397 (MiB)
[11/07/2025-13:22:07] [I] [TRT] Starting Calibration.
[11/07/2025-13:22:07] [E] Error[3]: IExecutionContext::executeV2: Error Code 3: API Usage Error (Parameter check failed, condition: nullPtrAllowed. Tensor "Input" is bound to nullptr, which is allowed only for an empty input tensor, shape tensor, or an output tensor associated with an IOuputAllocator.)
[11/07/2025-13:22:07] [E] Error[2]: [calibrator.cpp::calibrateEngine::1236] Error Code 2: Internal Error (Assertion context->executeV2(bindings.data()) failed. )
[11/07/2025-13:22:07] [E] Engine could not be created from network
[11/07/2025-13:22:07] [E] Building engine failed
[11/07/2025-13:22:07] [E] Failed to create engine from model or file.
[11/07/2025-13:22:07] [E] Engine set up failed
trtexec command:
/usr/src/tensorrt/bin/trtexec \
                --onnx=/home/me/Downloads/8.0-engine-build-test/models/detector/yolov4.onnx \
                --saveEngine=/home/me/Downloads/8.0-engine-build-test/models/detector/yolov4.engine \
                --minShapes=Input:1x3x832x4096 \
                --optShapes=Input:3x3x832x4096 \
                --maxShapes=Input:3x3x832x4096 \
                --int8 \
                --calib=/home/me/Downloads/8.0-engine-build-test/models/detector/yolov4.bin \
                --memPoolSize=workspace:1G
For float 16 precision, I can build the engine from the .onnx file, but with these warnings:
[11/07/2025-13:44:43] [I] [TRT] No checker registered for op: BatchedNMSDynamic_TRT. Attempting to check as plugin.
[11/07/2025-13:44:43] [I] [TRT] No importer registered for op: BatchedNMSDynamic_TRT. Attempting to import as plugin.
[11/07/2025-13:44:43] [I] [TRT] Searching for plugin: BatchedNMSDynamic_TRT, plugin_version: 1, plugin_namespace:
[11/07/2025-13:44:43] [W] [TRT] onnxOpImporters.cpp:6521: Attribute caffeSemantics not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
[11/07/2025-13:44:43] [W] [TRT] BatchedNMSPlugin is deprecated since TensorRT 9.0. Use INetworkDefinition::addNMS() to add an INMSLayer OR use EfficientNMS plugin.
[11/07/2025-13:44:43] [I] [TRT] Successfully created plugin: BatchedNMSDynamic_TRT
Can you share the yolov4.bin ?
@Morganh
Here is the file (I had to add .txt extension because .bin file is not allowed to be uploaded):
yolov4.bin.txt (3.1 KB)
Please use 5.5 tao-deploy docker to generate cal.bin again.
nvcr.io/nvidia/tao/tao-toolkit:5.5.0-deploy
Reference: tao_tutorials/notebooks/tao_launcher_starter_kit/yolo_v4/yolo_v4.ipynb at tao_5.5_release · NVIDIA/tao_tutorials · GitHub
yolo_v4 gen_trt_engine -m $USER_EXPERIMENT_DIR/export/yolov4_resnet18_epoch_$EPOCH.onnx \
                                   -e $SPECS_DIR/yolo_v4_retrain_resnet18_kitti.txt \
                                   --cal_image_dir $DATA_DOWNLOAD_DIR/testing/image_2 \
                                   --data_type int8 \
                                   --batch_size 16 \
                                   --min_batch_size 1 \
                                   --opt_batch_size 8 \
                                   --max_batch_size 16 \
                                   --batches 10 \
                                   --cal_cache_file $USER_EXPERIMENT_DIR/export/cal.bin  \
                                   --cal_data_file $USER_EXPERIMENT_DIR/export/cal.tensorfile \
                                   --engine_file $USER_EXPERIMENT_DIR/export/trt.engine.int8 \
                                   --results_dir $USER_EXPERIMENT_DIR/export
@Morganh
To remove TAO 3.0 to TAO 5.5 migration complexity, we repeated the exact same steps using a .hdf5 model trained with TAO 5.5. We exported the ONNX and calibration files again, following the same procedure, and we still got the same error. QAT is enabled in both the training and retraining processes.
We generated the .onnx file using the following command:
!tao model yolo_v4 export \
    -m $USER_EXPERIMENT_DIR/yolov4_cspdarknet19_epoch_152.hdf5 \
    -o $USER_EXPERIMENT_DIR/export_qat_152/yolov4_cspdarknet19_epoch_152.onnx \
    -e $SPECS_DIR/yolo_v4_retrain_cspdarknet19_kitti_seq.txt \
    --cal_json_file $USER_EXPERIMENT_DIR/export_qat_152/cal.json \
    --gen_ds_config
After generating the ONNX file, we created the calibration file using the following command:
!tao deploy yolo_v4 gen_trt_engine \
    -m $USER_EXPERIMENT_DIR/export_qat_152/yolov4_cspdarknet19_epoch_152.hdf5 \
    --data_type int8 \
    --batch_size 8 \
    --opt_batch_size 3 \
    --cal_cache_file $USER_EXPERIMENT_DIR/export_qat_152/cal.bin \
    --engine_file $USER_EXPERIMENT_DIR/export_qat_152/trt.engine.int8 \
    --results_dir $USER_EXPERIMENT_DIR/export_qat_152
I got this error when I tried to build int8 engine using trtexec:
[11/17/2025-11:27:01] [I] [TRT] No checker registered for op: BatchedNMSDynamic_TRT. Attempting to check as plugin.
[11/17/2025-11:27:01] [I] [TRT] No importer registered for op: BatchedNMSDynamic_TRT. Attempting to import as plugin.
[11/17/2025-11:27:01] [I] [TRT] Searching for plugin: BatchedNMSDynamic_TRT, plugin_version: 1, plugin_namespace:
[11/17/2025-11:27:01] [W] [TRT] onnxOpImporters.cpp:6521: Attribute caffeSemantics not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
[11/17/2025-11:27:01] [W] [TRT] BatchedNMSPlugin is deprecated since TensorRT 9.0. Use INetworkDefinition::addNMS() to add an INMSLayer OR use EfficientNMS plugin.
[11/17/2025-11:27:01] [I] [TRT] Successfully created plugin: BatchedNMSDynamic_TRT
[11/17/2025-11:27:01] [I] Finished parsing network model. Parse time: 0.0170763
[11/17/2025-11:27:01] [I] Set shape of input tensor Input for optimization profile 0 to: MIN=1x3x832x4096 OPT=3x3x832x4096 MAX=3x3x832x4096
[11/17/2025-11:27:01] [I] FP32 and INT8 precisions have been specified - more performance might be enabled by additionally specifying --fp16 or --best
[11/17/2025-11:27:01] [I] Set calibration profile for input tensor Input to 3x3x832x4096
[11/17/2025-11:27:01] [I] [TRT] Calibration table does not match calibrator algorithm type.
[11/17/2025-11:27:01] [I] [TRT] Perform graph optimization on calibration graph.
[11/17/2025-11:27:01] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[11/17/2025-11:27:01] [I] [TRT] Compiler backend is used during engine build.
[11/17/2025-11:27:02] [I] [TRT] Detected 1 inputs and 4 output network tensors.
[11/17/2025-11:27:03] [I] [TRT] Total Host Persistent Memory: 429056 bytes
[11/17/2025-11:27:03] [I] [TRT] Total Device Persistent Memory: 0 bytes
[11/17/2025-11:27:03] [I] [TRT] Max Scratch Memory: 55359488 bytes
[11/17/2025-11:27:03] [I] [TRT] [BlockAssignment] Started assigning block shifts. This will take 284 steps to complete.
[11/17/2025-11:27:03] [I] [TRT] [BlockAssignment] Algorithm ShiftNTopDown took 28.1168ms to assign 19 blocks to 284 nodes requiring 1440734208 bytes.
[11/17/2025-11:27:03] [I] [TRT] Total Activation Memory: 1440734208 bytes
[11/17/2025-11:27:03] [I] [TRT] Total Weights Memory: 6082560 bytes
[11/17/2025-11:27:03] [I] [TRT] Compiler backend is used during engine execution.
[11/17/2025-11:27:03] [I] [TRT] Engine generation completed in 1.72396 seconds.
[11/17/2025-11:27:03] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +1373, now: CPU 0, GPU 1379 (MiB)
[11/17/2025-11:27:03] [I] [TRT] Starting Calibration.
[11/17/2025-11:27:03] [E] Error[3]: IExecutionContext::executeV2: Error Code 3: API Usage Error (Parameter check failed, condition: nullPtrAllowed. Tensor "Input" is bound to nullptr, which is allowed only for an empty input tensor, shape tensor, or an output tensor associated with an IOuputAllocator.)
[11/17/2025-11:27:03] [E] Error[2]: [calibrator.cpp::calibrateEngine::1236] Error Code 2: Internal Error (Assertion context->executeV2(bindings.data()) failed. )
[11/17/2025-11:27:03] [E] Engine could not be created from network
[11/17/2025-11:27:03] [E] Building engine failed
[11/17/2025-11:27:03] [E] Failed to create engine from model or file.
[11/17/2025-11:27:03] [E] Engine set up failed
I also tried using nvinfer plugin to build engines, same outcomes, nvinfer can build fp16 engine, but cannot build int8 engine, I got this error:
Hardware/Software info:
  • Train PC: TAO 5.5, GPU: GeForce 4090
  • Engine building PC: DeepStream 8.0, GPU: GeForce 5090
The calibration file:
yolov4-tao5.5-nov17.bin.txt (3.1 KB)
OK, this is the important information. For QAT workflow, you can refer to “12.7. Deployment of the QAT model” of tao_tutorials/notebooks/tao_launcher_starter_kit/yolo_v4/yolo_v4.ipynb at tao_5.5_release · NVIDIA/tao_tutorials · GitHub. You need not use --cal_cache_file. Please refer to below and retry. Thanks.
@Morganh
We followed this: Does TAO 5.0 support exporting a model trained by TAO 3.0? - #9 by Morganh
But there was no calibration file generated. Is that expected?
I went ahead and create int8 and fp16 engines from the exported .onnx file anyway.
Here are the two setups:
  • Case 1:
  • Case 2:
    • Model: YOLO V4
    • On Train PC:
      • Trained using TAO 5.5 (.hdf5 file)
      • Exported using TAO 5.5 (.onnx file)
    • On Engine building PC
      • Engines built using trtexec (TensorRT version 10.9)
In both cases:
I can build fp16 engine from the exported .onnx file and the engine detects objects as expect.
However, for int8 mode, although I can create nt8 engine from the exported .onnx file, the engine doesn’t detect any object at all.
Here are three ways I built int8 engine from the exported .onnx for both case 1 and case 2 mentioned above:
    • --int8: build int 8 engine without provide a calibration file
  • Can build engine with this warning:
[W] [TRT] Calibrator is not being used. Users must provide dynamic range for all tensors that are not Int32 or Bool.
  1. --int8 --calib=cal.bin: build int 8 engine providing a calibration file that doesn’t exist
  • Can build engine with these info:
[I] [TRT] Calibrated batch 0 in 0.558499 seconds.
[I] [TRT] Post Processing Calibration data in 11.0437 seconds.
[I] [TRT] Calibration completed in 13.2405 seconds.
  1. --int8 --calib=cal.json: build int 8 engine providing cal.json instead of cal.bin
  • Failed to build engine with these errors:
The parse-bbox-func-name=NvDsInferParseCustomBatchedNMSTLT I used is from: deepstream_tao_apps/post_processor at release/tao_ds8.0ga · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
Hi @hyperlight ,
Thanks for the detailed info. Seems that the two cases have similar behavior. Let us focus on case2 to check further.
Use the steps of notebook[tao_tutorials/notebooks/tao_launcher_starter_kit/yolo_v4/yolo_v4.ipynb at tao_5.5_release · NVIDIA/tao_tutorials · GitHub] as below.
1.After you run tao model yolo_v4 export, please use Netron to check if the onnx file has QDQ node. During this step, yes, there was no cal.bin generated. Only cal.json is generated.
2. If onnx file has QDQ node, then use tao deploy yolo_v4 gen_trt_engine to generate int8 engine. Then, please use tao deploy yolo_v4 inference to check the inference result.
All of above items follow tao’s pipeline. Temporally not use trtexec and deepstream. Just to narrow down to check if tao’s pipeline works.
Hi @Morganh,
Based on your suggestion, after running tao model yolo_v4 export, my co-worker inspected the exported ONNX file in Netron and confirmed that there are no QDQ nodes. I’ve attached a screenshot of the exported model for reference. (Note: enable_qat: true was set during the train, prune, and retrain phases.)
Even though the ONNX file did not contain QDQ nodes, my co-worker was still able to generate an INT8 engine using tao deploy yolo_v4 gen_trt_engine, and then ran tao deploy yolo_v4 inference to test it. The INT8 engine successfully detected the objects and drew bounding boxes. For both cases I mentioned in my previous response, she tested that INT8 engine works in TAO (tao deploy engine creation and inference). The same yolov4 model was used to create INT8 engine using trtexec on the PC with Deepstream 8.0 installed, but the INT8 engine created by trtexec didn’t detect anything on inference, and trtexec failed to create INT8 engine with the cal.json file.
Note: Based on NVIDIA’s documentation (relevant part is in the below screenshot), it is normal that the exported ONNX file does not contain QDQ nodes. For YOLOv4, the QAT scale information is extracted during export and written into the cal.json file instead.
Additionally, if I install TAO 5.5 on the PC that has DeepStream 8.0 installed and use TAO 5.5 to create INT8 engine, would the INT8 engine created by TAO 5.5 work for DeepStream 8.0. Two caveats with this approach:
  • TAO 5.5 Software Requirements uses Ubuntu LTS 22.04 but DeepStream 8.0 uses Ubuntu LTS 24.04.
  • TAO 5.5 and DeepStream 8.0 also use different CUDA and TensorRT version too.
So, may I confirm that using the tao pipeline, the Int8 trt engine can work without any issue?
Could you do one more experiment? Please use the trtexec which is inside the deploy docker to generate int8 engine and run inference again.
You can use below way.
$ docker run --runtime=nvidia -it --rm nvcr.io/nvidia/tao/tao-toolkit:5.5.0-deploy /bin/bash
Then run something like
# yolo_v4 gen_trt_engine xxx
# yolo_v4 inference xxx
Hi @Morganh,
Yes.
My co-worker ran yolo_v4 gen_trt_engine and yolo_v4 inference inside the deploy docker to generate int8 engine and run inference again. She can create an int8 engine and the int8 engine also successfully detected the objects and drew bounding boxes. The deploy docker gives the same outcomes as running yolo_v4 gen_trt_engine and yolo_v4 inference to generate int8 engine and run inference using TAO launcher.
My co-worker did another experiment. Inside the deploy docker, she used trtexec to generate int8 engine and yolo_v4 inference to run inference. Because there is no calibration file, even though she can generate int8 engine, that engine doesn’t detect anything.
Glad to know the tao deploy inference works. More, it is expected to get the same outcomes when use tao-launcher because tao-launcher is just a wrapper.
If there is no calibration cache file(cal.bin), it is expected to be not working for int8 engine. So, it is needed to generate cal.bin if run with trtexec.
You can add below
--cal_cache_file /path/to/export_qat/cal.bin
in belowyolo_v4 gen_trt_engine command line. (Reference code)
Then, cal.bin will be generated.
BTW, the cal.json can not be used in trtexec. The trtexec can only accept calibration cache(cal.bin).
Hi @Morganh,
Here is a summary of what we have tried so far:
  1. Build int8 engine using TAO 3.0 exported files (yolo4.etlt and yolo4.bin) using DeepStream 8.0 nvinfer
Outcome:
Failed to build int8 engine, TAO 3.0 exported files are incompatible with DeepStream 8.0
  1. We followed your suggestions in Does TAO 5.0 support exporting a model trained by TAO 3.0? - #3 by Morganh
suggestion 1: change the .etlt file to .onnx file
suggestion 2: change the .tlt file to .hdf5 file, and then export to .onnx file using TAO5
Outcome:
In both suggestions, what we ended up with is an .onnx file. I can build float 16 engine from the .onnx file for DeepStream 8.0, but I cannot build int 8 engine because both suggestion only provide an .onnx file, there is no new calibration cache (cal.bin) file. The calibration cache file exported by TAO 3.0 cannot be used with the .onnx file.
  1. We followed your suggestions in Does TAO 5.0 support exporting a model trained by TAO 3.0? - #7 by Morganh
Outcome:
Failed to build int8 engine with the following errors:
  1. We followed your suggestions in Does TAO 5.0 support exporting a model trained by TAO 3.0? - #9 by Morganh
For QAT workflow […]. You need not use --cal_cache_file . Please refer to below and retry. Thanks.
We shared the outcomes for two cases in Does TAO 5.0 support exporting a model trained by TAO 3.0? - #10 by hyperlight
  • Trained using TAO 3.0 + Exported using TAO 5.5
  • Trained using TAO 5.5 + Exported using TAO 5.5
Again, in both cases, we ended up with is an .onnx file:
  • float 16 engine: build works, detection works
  • int 8 engine: build works, detection failed due to missing calibration cache file.
  1. We followed your suggestions in Does TAO 5.0 support exporting a model trained by TAO 3.0? - #11 by Morganh and Does TAO 5.0 support exporting a model trained by TAO 3.0? - #13 by Morganh
Outcome:
We can create an int8 engine and the int8 engine also successfully detected the objects and drew bounding boxes. The deploy docker gives the same outcomes as running yolo_v4 gen_trt_engine and yolo_v4 inference to generate int8 engine and run inference using TAO launcher.
  1. We followed your suggestions in Does TAO 5.0 support exporting a model trained by TAO 3.0? - #15 by Morganh
You can add --cal_cache_file /path/to/export_qat/cal.bin inyolo_v4 gen_trt_engine command line. Then, cal.bin will be generated.
Outcome:
Please let me state our goal again:
Our goal is to deploy yolov4 model trained by TAO 3.0 as int8 precision egnine in DeepStream 8.0, how do we do that?
OK, could you please share below files via private message?
  • TAO 3.0 .tlt file and .hdf5 file, model_key
  • TAO 3.0 exported files (yolo4.etlt and yolo4.bin) and .onnx file , model_key
  • several images
I will try to reproduce and debug further. Thanks!
More, the official way to deploy TAO3.0 model in deepstream is to follow the official github in GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream.
You can checkout the corresponding branch as below.
You can also find the Deestream version in “Prerequisites” of readme for each branch.
Please use a new name cal_qat.bin to avoid using existing cal.bin. Thanks.
--cal_cache_file $USER_EXPERIMENT_DIR/export_qat/cal_qat.bin
Hi @Morganh,
I sent you the files you requested.
We deployed yolov4 model trained by TAO 3.0 as int8 precision egnine using tao-converter up to DS6.4. We are upgrading to DS8.0 and tao-converter is no longer supported.
We tried that and got the same error:
Well received. I will check further about the trtexec.
