Before device link-time optimization (DLTO) was introduced in CUDA 11.2, it was relatively easy to ensure forward compatibility without worrying too much about differences in performance. You would typically just create a fatbinary containing PTX for the lowest possible arch and SASS for the specific architectures you would normally target. For any future GPU architectures, the JIT compiler would then assemble the PTX into SASS optimized for that specific GPU arch.
Now, however, with DLTO, it is less clear to me how to ensure forward compatibility and maintain performance on those future architectures.
Let’s say I compile/link an application using nvcc
with the following options:
Compile
-gencode=arch=compute_52,code=[compute_52,lto_52,lto_61]
Link
-gencode=arch=compute_52,code=[sm_52,sm_61] -dlto
This will create a fatbinary containing PTX for sm_52
, LTO intermediaries for sm_52
and sm_61
, and link-time optimized SASS for sm_52
and sm_61
(or at least this appears to be the case when dumping the resulting fatbin sections using cuobjdump -all
anyway).
Assuming the above is correct, what happens when the application is run on a later GPU architecture (e.g. sm_70
)? Does the JIT compiler just assemble the sm_52
PTX without using link-time optimization (resulting in less optimal code)? Or does it somehow link the LTO intermediaries using link-time optimization? Is there a way to determine/guide what the JIT compiler is doing?
