One end of the USB cable must be “type B”, the other end must be “type A” (some combination of cable and adapter has to achieve this combination…if the length exceeds the maximum allowed length the signal will fail due to a certain amount of latency per distance exceeding the maximum allowed…this cannot be circumvented with better cables).
The dmesg you show above indicates a Jetson TX1 in recovery mode:
[109309.608562] usb 2-2: New USB device found, idVendor=0955, idProduct=7721
This part of dmesg differs from my Jetsons:
[109309.608566] usb 2-2: Product: <b>APX</b>
…I do not know what APX is…but perhaps it is because I have an older TX2. Can anyone from NVIDIA say if APX is valid on any revision of a TX2?
Of the cables you gave web URLs for, the first appears to be a type-A full-size to type-A full-size. This cable has no technical use other than as an extension when applied with a second cable or adapter…both ends are full-size type-A. The maximum length requirement I mentioned above is because if this cable is combined with another long cable you can be guaranteed that signal latency from cable length will cause signal failure.
I can’t read the text for the second cable, and I have to warn you that people who post pictures of USB cables with micro connectors for sales literature have an extremely high rate of not posting the picture of the cable which is actually shipped (type-A and type-B micro look the same unless you are very familiar with the cable). Within the picture of that second cable the micro connector is a type-B which is what is used for flashing. This should be exactly equivalent to the cable the Jetson ships with.
No Jetson will show up under lsblk in recovery mode. Device mode is not the same as saying the device shows up as a hard drive…this is just something that many common consumer devices (especially music players) have set up through software as a convenience. In recovery mode the Jetson becomes a device, but it becomes a custom device and not a hard drive. When running normally it is possible to program a Jetson to appear as a hard drive (this would be via customization of the “gadget” interface to the Linux kernel). You would have to do this customization yourself. There are actually many kinds of devices this port could be programmed to behave as, e.g., it could be used to cause the Jetson to appear as a USB ethernet adapter or as a keyboard.
Note that whenever a host computer has a device attached to it the host will need software to understand the device. If the USB device is a keyboard, then the host needs software which understands keyboards. If the USB device is an external hard drive, then the host needs software which knows how to use a USB hard drive. In the case of a Jetson in recovery mode this is a custom device, and thus only a custom driver will understand how to use the device. This is the “driver package” which you can download and use to flash the Jetson (JetPack is a front end to the driver package).
