Hi@all,
I would like to calculate the dot productof two matrices and I have no idea how I should do this in an efficient way.
The C code looks like this:
int width = 128;
for(int i=0; i<width; i++)
for(int j=0; j<width; j++)
for(int n=0; n<400; n++)
C[i*width+ j] += A[(iwidth+j) + n] * C[(jwidth+ i) + n];
In Cuda I have the problem, that I’m not able to shift the data from global memory to shared memory, which results in a very low performance:
dim3 dimBlock(128,1);
dim3 dimGridPPA (1, 128);
dot<<<dimGrid, dimBlock>>>(A, B, C);
global void dot(double* A, double* B, double* C)
//index
const unsigned int tidx = blockDim.x * blockIdx.x + threadIdx.x;
const unsigned int tidy = blockDim.y * blockIdx.y + threadIdx.y;
const unsigned int tid = tidy * AnzR + tidx;
const unsigned int row = tidx * NMAX;
const unsigned int col = tidy * NMAX;
double sum = 0;
#pragma loop unroll 400
for(int i=0; i<400; i++)
sum = __fma_rn(A[row + i], B[col + i], sum) ;
__syncthreads();
C[tid] = sum;
Exits there a paper/documentation about such problems or any suggestions are welcome :)
My graphiccard is a GT425M
Many thanks in advance!
