We have an issue when using 2 screens in full screen mode randomly when you log in it freezes and you get vertical and horizontal scrolls bars on your endpoint device. The Xendesktop session never launches the only solution is to kill it from the Delivery control and have the user login again. This only affects multi-monitor users, single screen users work just fine. I have tried setting the resolution to the lowest on the monitors as a test and still have the same issue. Environment information below.
Dell R730 Server
2 K1 cards installed in server
Hypervisor: Vsphere 6.0 All updates as of 1/6/2016
Citrix Xendesktop 7.6 with most current VDA
Citrix PVS 7.6
Driver version from Nvidia: 354.56
Virtual machines
2008R2
2 VCPU
4GB Memory
Profile 120Q (Have tried with all the other profiles as well, same issue
If I uninstall the Nvidia driver from the VM the issue goes away even if I leave the card attached to the virtual machine. Reinstalling the driver the issue comes back
Any thoughts?
