Hi, I’ve tried and googled a lot, but I know when I’m beat.
So I have a laptop, I could plugin a razer core in and configure more or less to have everything working, the problem is that not everything works at the same time.
Precisely, I don’t manage to make both my gpus work at the same time. Which means either I have my built-in monitor working, either I have my 2 external monitors working, but I can’t find a way to make all 3 working at the same time. And I’m out of ideas.
This is my working eGPU version xorg :
Section "ServerLayout"
Identifier "Layout0"
Screen "Screen0" 0 0
EndSection
Section "Module"
Load "modesetting"
Load "extmod"
Load "dbe"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce RTX 2080 SUPER"
BusID "PCI:61:0:0"
Option "AllowEmptyInitialConfiguration"
Option "AllowExternalGpus" "True"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BoardName "Quadro M620"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung LC27RG50"
HorizSync 255.0 - 255.0
VertRefresh 48.0 - 240.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Samsung C24F390"
HorizSync 0.0 - 0.0
VertRefresh 0.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor2"
ModelName "LGD"
HorizSync 0.0 - 0.0
VertRefresh 0.0
Option "DPMS"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-6"
Option "metamodes" "DP-2: 1920x1080_240 +1980+0, DP-5: nvidia-auto-select +0+0, DFP-3"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor2"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
If I replace the second line of the serverlayout :
Screen "Screen1"
EndSection
Then it uses the built-in monitor
If I dare putting both in like this :
Screen "Screen1" RightOf "Screen0"
EndSection
Section "ServerFlags"
Option "Xinerama" "ON"
EndSection
Then it tells me that Xinerama on with Composite extension enabled is not supported and in fact > nothing works, I get black screen on built-in, nothing on the others, but I can move my mouse around on the built-in.
if I disable Composite :
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
EndSection
Then the login doesn’t work, crashes and tells me to log out and retry (so rude).
So I’m at this point, I really don’t know X server nor NVidia, so I’m out of ideas, please help me.
For info I have :
- Ubuntu 20.04
- lightdm as display manager (but it’s the same results with gdm3)
- Quadro M620 for internal GPU
- GeForce RTX 2080 Super in the Razer Core (eGPU)
Thanks for any suggestions, if you need logs tell me of which tentative, I’m saving them all :D
