I am having a problem on deciding how to implement the dynamic allocation of an array in a structure effectively.
I have a structure as following
struct block_properties
long int no_of_tri, no_of_loops;
long int loops[512];
long int index;
long int end_index;
In kernel I have two for loops:
for(i=index+tid; i< block_p[bid].end_index - 2; i=i+blockDim.x)
for(j=i+1+tidy; j < block_p[bid].end_index; j=j+blockDim.y)
// For simplicity I removed the actual code
roller++;
block_p[bid].loops[] = roller;
Now, I am not able to find a good way to allocate memory for the loops array. Can anyone give me a suggestion.
Note: I am planning to use 23 x 22 threads per block and 128 blocks. end_index varies upon input and goes upto 25,000.
Sambi
