Google Drive Link for the .onnx
model.
The inference results are wrong [Log 1, for the given code.]
If the quoted line is changed to size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
then there is cuda out of memory error. [Log 2]
Log 1 of 2
Loading ONNX file from path ssd.onnx...
Beginning ONNX file parsing
[TensorRT] WARNING: onnx2trt_utils.cpp:198: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
Completed parsing of ONNX file
Building an engine; this may take a while...
Completed creating engine
Completed serializing and saving the engine
Reading engine: ssd.engine
before B shape (-1, 3, 300, 300)
[TensorRT] WARNING: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
after B shape (1, 3, 300, 300)
(34928,)
(707292,)
Log 2 of 2
engine.binding_shape: (-1, 3, 300, 300)
size trying to allocate(trt.volume): -270000
File "trtssd.py", line 317, in <module>
inputs, outputs, bindings, stream = allocate_buffers(engine)
File "trtssd.py", line 233, in allocate_buffers
host_mem = cuda.pagelocked_empty(size, dtype)
pycuda._driver.MemoryError: cuMemHostAlloc failed: out of memory
