I am reposting this from another forum as this requires the use of nvml. I’m new to using MIG functionality. I wanted to know if there is support for dynamically changing mig profiles on a GPU. For example, on an A30, let’s say that it is currently in MIG config 5 from the table. GPU slice #0 is running a workload. Is it possible to switch to configuration 4 without having to halt the running process on slice #0? NVML has the functions to create/destroy GPU slices, but I wanted to know if this can be done dynamically in a scenario similar to the above example.
