We are developing a C++ Deepstream application using Triton Inference Server, where we would like to be able to only have one model loaded at the time, but still be able to change to a different one at runtime with a service call. The issue we are seeing is, that if you ever take the nvinferserver plugin from the PAUSED/PLAYING state to the NULL/READY state for reconfiguration, then the TRTIS backend will get stuck in a bad state that you can’t recover from. The problem seems to be that it will try to initialize the Triton Inference Server every time you bring a nvinferserver plugin to PAUSED or PLAYING, and it just can’t handle that.
Reading https://github.com/triton-inference-server/server/blob/master/docs/model_management.md it seems like it should be possible to reconfigure to a different model runtime, but maybe there are some constraints to the interface through the gstreamer plugin that I am overlooking?
I guess my question is: Is this intended behaviour and am I just misusing the SDK? If so, is there a better way to solve the problem? I tried to condense our approach into an example shown below.
Jetson TX2
• DeepStream Version
5.0.0
4.4.0
• TensorRT Version
7.1.3.0
Question/Bug
Create a gstreamer pipeline in a C++ application that uses a sample configuration from deepstream5.0/samples/configs/deepstream-app-trtis/
We use a pipeline very similar to this:
filesrc location=streams/sample_1080p_h264.mp4
! qtdemux
! h264parse
! nvv4l2decoder enable-max-performance=true
! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080
! nvinferserver name=inferserver config-file-path=configs/deepstream-app-trtis/config_infer_primary_detector_ssd_mobilenet_v1_coco_2018_01_28.txt batch-size=1
! nvvideoconvert
! nvdsosd
! nvegltransform
! nveglglessink sync=true
Instantiate the pipeline from a string and load the model with a state change
GError *error;
GstElement *pipeline, *inferserver;
pipeline = gst_parse_launch(pipeline_string, &error);
inferserver = gst_bin_get_by_name(GST_BIN(pipeline), "inferserver");
gst_element_set_state (GST_ELEMENT(g_pipeline), GST_STATE_PAUSED);
If you then unload the model, change to a different configuration, and load the new model, then the TRTIS backend will cause the application to crash because you are trying to initialize it again when it is already running.
gst_element_set_state (GST_ELEMENT(inferserver), GST_STATE_NULL);
g_object_set(inferserver, "config-file-path", "configs/deepstream-app-trtis/config_infer_primary_detector_ssd_mobilenet_v1_trailers.txt", NULL);
g_object_set(inferserver, "batch-size", 1, NULL);
gst_element_set_state (GST_ELEMENT(inferserver), GST_STATE_PAUSED);
This results in the following errors:
