caught an error in v4l2 encoder non-blocking mode, qbuffer capture_plane randomly return ebusy error.
Example with modified 01_video_encode:
./video_encode ~/source.yuv 1280 720 H264 ~/h1.stats --blocking-mode 0 --stats
# ./video_encode ~/hall.yuv 1280 720 H264 ~/h1.stats --blocking-mode 0 --stats
Creating Encoder in non-blocking mode
Opening in O_NONBLOCKING MODE
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
875967048
842091865
H264: Profile = 66, Level = 51
Created the PollThread and Encoder Thread
Starting Device Poll Thread
..........10000..........20000..........30000.....[ERROR] (NvV4l2ElementPlane.cpp:256) <enc0> Capture Plane:Error while Qing buffer: Device or resource busy
Error while Qing buffer at capture plane
Capture plane dequeued 0 size buffer
----------- Element = enc0 -----------
Total Profiling time = 86.6671
Average FPS = 408.783
Total units processed = 35429
Average latency(usec) = 19048
Minimum latency(usec) = 8889
Maximum latency(usec) = 89813
Encoder is in error
App run failed
jetson tx2, lastes l4t2
# R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
# dpkg -l | grep nvidia
ii ffmpeg 7:4.2.2-nvidia arm64 Tools for transcoding, streaming and playing
of multimedia files
ii nvidia-l4t-3d-core 32.4.3-20200625213407 arm64 NVIDIA GL EGL Package
ii nvidia-l4t-apt-source 32.4.3-20200625213407 arm64 NVIDIA L4T apt source list debian package
ii nvidia-l4t-bootloader 32.4.3-20200709231533 arm64 NVIDIA Bootloader Package
ii nvidia-l4t-camera 32.4.3-20200625213407 arm64 NVIDIA Camera Package
ii nvidia-l4t-configs 32.4.3-20200625213407 arm64 NVIDIA configs debian package
ii nvidia-l4t-core 32.4.3-20200625213407 arm64 NVIDIA Core Package
ii nvidia-l4t-cuda 32.4.3-20200625213407 arm64 NVIDIA CUDA Package
ii nvidia-l4t-firmware 32.4.3-20200625213407 arm64 NVIDIA Firmware Package
ii nvidia-l4t-graphics-demos 32.4.3-20200625213407 arm64 NVIDIA graphics demo applications
ii nvidia-l4t-gstreamer 32.4.3-20200625213407 arm64 NVIDIA GST Application files
ii nvidia-l4t-init 32.4.3-20200625213407 arm64 NVIDIA Init debian package
ii nvidia-l4t-initrd 32.4.3-20200625213407 arm64 NVIDIA initrd debian package
ii nvidia-l4t-jetson-io 32.4.3-20200625213407 arm64 NVIDIA Jetson.IO debian package
ii nvidia-l4t-jetson-multimedia-api 32.4.3-20200625213407 arm64 NVIDIA Jetson Multimedia API is a collection
of lower-level APIs that support flexible application development.
ii nvidia-l4t-kernel 4.9.140-tegra-32.4.3-20200625213407 arm64 NVIDIA Kernel Package
ii nvidia-l4t-kernel-dtbs 4.9.140-tegra-32.4.3-20200625213407 arm64 NVIDIA Kernel DTB Package
ii nvidia-l4t-kernel-headers 4.9.140-tegra-32.4.3-20200625213407 arm64 NVIDIA Linux Tegra Kernel Headers Package
ii nvidia-l4t-multimedia 32.4.3-20200625213407 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-multimedia-utils 32.4.3-20200625213407 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-oem-config 32.4.3-20200625213407 arm64 NVIDIA OEM-Config Package
ii nvidia-l4t-tools 32.4.3-20200709231533 arm64 NVIDIA Public Test Tools Package
ii nvidia-l4t-wayland 32.4.3-20200625213407 arm64 NVIDIA Wayland Package
ii nvidia-l4t-weston 32.4.3-20200625213407 arm64 NVIDIA Weston Package
ii nvidia-l4t-x11 32.4.3-20200625213407 arm64 NVIDIA X11 Package
ii nvidia-l4t-xusb-firmware 32.4.3-20200625213407 arm64 NVIDIA USB Firmware Package
ii nvidia-opencv 4.4-b186 arm64 NVIDIA OpenCV Meta Package
patch
- added little sleep between dqbuffer and qbuffer capture_plane
- seek to start file after each reading next frame
diff -ruN jetson_multimedia_api.orig/samples/01_video_encode/video_encode_main.cpp jetson_multimedia_api/samples/01_video_encode/video_encode_main.cpp
--- jetson_multimedia_api.orig/samples/01_video_encode/video_encode_main.cpp 2020-07-30 23:41:18.891615012 +0300
+++ jetson_multimedia_api/samples/01_video_encode/video_encode_main.cpp 2020-07-31 00:09:15.610160262 +0300
@@ -35,6 +35,7 @@
#include <string.h>
#include <fcntl.h>
#include <poll.h>
+#include <unistd.h>
#include "nvbuf_utils.h"
#include "video_encode.h"
@@ -225,6 +226,10 @@
write_encoder_output_frame(ctx->gdr_out_file, buffer);
num_encoded_frames++;
+ if (!(num_encoded_frames % 1000))
+ cout << "." << flush;
+ if (!(num_encoded_frames % 10000))
+ cout << num_encoded_frames << flush;
if (ctx->report_metadata)
@@ -317,6 +322,8 @@
+ usleep(300);
/* encoder qbuffer for capture plane */
if (enc->capture_plane.qBuffer(*v4l2_buf, NULL) < 0)
@@ -880,6 +887,7 @@
v4l2_output_buf.m.planes[2].bytesused = 0;
+ ctx.in_file->seekg(0);
/* Encoder supported input metadata specific configurations */
if (ctx.input_metadata)
