I am doing some processing on a large chunk of data which cannot fit into shared memory if I try to process it all with a single kernel call, however, the data can be broken down into smaller peices for independent processing. I have determined the maximum number of elements of data which can fit into shared memory per multiprocessor.
I am wondering if I would get better performance by using a larger number of blocks per multiprocessor with fewer threads each (8 blocks with 32 threads each) or a smaller number of blocks per multiprocessor with more threads each (1 block with 256 threads). Or does the answer lie somewhere in the middle?
Also, do I take any sort of performance hit for making many (>64) independent calls to the kernel? My feeling is that any performance lost would be more than gained back by being able to use shared memory instead of global (as I have been).
Thanks for any help.
There isn’t a quick answer to your question. My suggestion would be to try multiple configurations to determine what works best for your particular code. Some things to consider:
a block with many threads will incur a slightly higher overhead when threads synchronize. So, if your code requires many syncs, you may save some clock cycles if you use fewer threads.
the register file is partitioned among the threads of a given block. So, increasing the number of threads reduces the potential number of registers per thread. This may affect occupancy, or, in the worst case, cause a launch failure. The latter is not that frequent, plus it’s predictable since you can check how many registers are required per thread.
switching between warps of a block is fast. Switching between different blocks is slower. So, if thread-switching is the only concern (which it never is, see the above and memory latencies), higher number of threads per block leads to a shorter execution time simply due to lower switching overhead.
Paulius
Thank you for the quick reply. I think my answer may lie somewhere in the middle, mostly due to the issue of register availability.
