All,
I’m using an Nvidia 8800 GTS 640Mb card and all the Cuda Sample Programs work except the Eigenvalues. I’m using NVIDIA Driver Version: 173.08.
My real simple Cuda programs work ok as well. Device values are:
[font=“Courier”][root@zoozesrv release]# ./deviceQuery
There is 1 device supporting CUDA
Device 0: “GeForce 8800 GTS”
Major revision number: 1
Minor revision number: 0
Total amount of global memory: 670367744 bytes
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1188000 kilohertz
Test PASSED
Press ENTER to exit…[/font]
I’m not 100% cure why but this is the output I’m getting:
[font=“Courier”][root@zoozesrv eigenvalues]# ./eigenvalues
Matrix size: 2048 x 2048
Precision: 0.000010
Iterations to be timed: 100
Result filename: ‘eigenvalues.dat’
Gerschgorin interval: -2.894310 / 2.923304
Average time step 1: 20.285193 ms
Average time step 2, one intervals: 6.267208 ms
Average time step 2, mult intervals: 0.027550 ms
Average time TOTAL: 26.675930 ms
FAILED.
[/font]
Although this doesn’t really bother me as its doing what I want it to do, I’m not 100% sure why this sample program fails (I’m afraid some of the maths is beyond my aging brain).
Any help would be most appreciated, kindest regards
Zoozer
