Enable secure boot without fusing SOM
Hi Nvidia:
As the topic said, we were trying to enable secure boot without fusing the SOM.
We are using Jetpack 6.0 + Custom Board + AGX Orin 64GB.
From the document and posts on the forum, I tried the following :
$ sudo apt install efitools
$ cd Linux_for_Tegra/
$ mkdir uefi_keys && cd uefi_keys
# Gen Keys for secure boot.
$ openssl ecparam -name secp521r1 -genkey -noout -out james_PK.key
$ openssl ecparam -name secp521r1 -genkey -noout -out james_KEK.key
$ openssl ecparam -name secp521r1 -genkey -noout -out james_db_1.key
$ openssl ecparam -name secp521r1 -genkey -noout -out james_db_2.key
# Use the key to gen Certs
# Instead of generating key and crt at the same time, the key should be generated separately.
$ openssl req -new -x509 -sha256 -days 3650 -key james_PK.key -subj "/CN=my Platform Key/" -out james_PK.crt
$ openssl req -new -x509 -sha256 -days 3650 -key james_KEK.key -subj "/CN=my Key Exchange Key/" -out james_KEK.crt
$ openssl req -new -x509 -sha256 -days 3650 -key james_db_1.key -subj "/CN=my Signature Database key 1/" -out james_db_1.crt
$ openssl req -new -x509 -sha256 -days 3650 -key james_db_2.key -subj "/CN=my Signature Database key 2/" -out james_db_2.crt
$ openssl ecparam -name secp521r1 -genkey -noout -out james_private_key.pem
Update the config ($ nano uefi_keys/uefi_keys.conf):
UEFI_PK_KEY_FILE="james_PK.key";
UEFI_PK_CERT_FILE="james_PK.crt";
UEFI_KEK_KEY_FILE="james_KEK.key";
UEFI_KEK_CERT_FILE="james_KEK.crt";
UEFI_DB_1_KEY_FILE="james_db_1.key";
UEFI_DB_1_CERT_FILE="james_db_1.crt";
UEFI_DB_2_KEY_FILE="james_db_2.key";
UEFI_DB_2_CERT_FILE="james_db_2.crt";
Gen UEFI capsules:
# Gen UEFI Capsule
$ sudo ./tools/gen_uefi_default_keys_dts.sh uefi_keys/uefi_keys.conf
$ sudo chmod 644 uefi_keys/_out/*.auth
$ sudo cp uefi_keys/UefiDefaultSecurityKeys.dtbo bootloader/
Flash them to NVMe:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -u uefi_keys/james_private_key.pem --uefi-keys uefi_keys/uefi_keys.conf -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --no-flash --network usb0 jetson-agx-orin-devkit internal
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -u uefi_keys/james_private_key.pem --uefi-keys uefi_keys/uefi_keys.conf --no-flash --external-device nvme0n1p1 -S 70GiB -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --external-only --append --network usb0 jetson-agx-orin-devkit external
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -u uefi_keys/james_private_key.pem --network usb0 --flash-only
So far, I suppose that we have one signed & encrypted orin + one signed & encrypted nvme. As comparison, we use another Linux_for_Tegra folder to flash another orin & nvme by:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --no-flash --network usb0 jetson-agx-orin-devkit internal
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -S 70GiB -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --external-only --append --network usb0 jetson-agx-orin-devkit external
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
However, we do a couple tests to check if anything secure or not:
AGX Orin Encrypted? NVMe Encrypted? OS Boot? Serial Log File
Y Y Y SecurityBoot-log1_dtbo.txt
Y N Y SecurityBoot-log2_dtbo.txt
N Y Y SecurityBoot-log3_dtbo.txt
SecurityBoot-log1_dtbo.txt (81.8 KB)
SecurityBoot-log2_dtbo.txt (82.7 KB)
SecurityBoot-log3_dtbo.txt (81.2 KB)
Now I’m curious about:
  1. Enable UEFI secure boot without fuse is even possible?
  2. If possible, what’s wrong with the steps above?
  3. In document Ref, it said Refer to Using the Fuse Burning Toolkit for T234 from Jetson Download Center for more information. But I can’t find it in Jetson Download Center. Is this the root cause? Since the l4t_initrd_flash.sh reported Please install the Secureboot package to use initrd flash for fused board during the flash.
Please help.
Many Thanks.
hello jameskuo,
there’re bootloader SecureBoot and UEFI SecureBoot.
it’s possible to enable UEFI SecureBoot without fuse burn the target.
although UEFI secure boot can be independently enabled from a low-level bootloader secure boot, we strongly recommended users enable bootloader secure boot so that the root-of-trust can start from the BootROM.
Hi Jerry:
Thanks for the reply.
I understand the root-of-trust might be an issue. But for now, we tried to use UEFI Secure Boot.
I assume doing the steps, should be able to enable UEFI Secure Boot, and the image should by signing & encrypted during flash process?
But after switching NVMe and Orin SOM, system can still boot into OS. I’m not sure if this is normal or not.
it does not check/verify the signature if fuse variables, OemKeyValid and SecurityMode are not burned.
Hi Jerry:
The secure Boot is still disabled after the flashing. Isn’t this should be enabled if we pass --uefi-keys into flash script?
hello jameskuo,
it looks incorrect, it should report Current Secure Boot State as enabled.
please double check your UEFI keys, and the flash command-line.
for instance, you may see-also developer guide, Generate UefiDefaultSecurityKeys.dtbo.
$ vim uefi_keys/uefi_keys.conf
$ sudo ./tools/gen_uefi_keys_dts.sh uefi_keys/uefi_keys.conf
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 --uefi-keys uefi_keys/uefi_keys.conf -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit external
Hi Jerry:
I believe the issue is from P-521 keys.
Now I return to RSA2048, everything works fine.
Many Thanks for the support.
