I am using a system containing two A4000 GPUs, however when I run the modulus examples only one of these is being used at a time. running the line:
torch.cuda.device_count()
in python within the docker container generates the output “2”, indicating both GPUs can be seen by pytorch (as far as I understand), but only GPU 0 is actually used during the running of the examples.
My question is what additional steps do I need to take to ensure that Modulus is able to run with both GPUs available on the system. The line I am using to start the container is:
docker run --gpus all --runtime nvidia --ipc=host --ulimit memlock=-1 --ulimit stack=67108864 -it -p 8888:8888 modulus:22.09
