Running CentOS 7.4 with MLNX_OFED_LINUX-4.3-1.0.1.0 (OFED-4.3-1.0.1)
with TWO dual-port ConnectX-4 100Gbit EDR adapters for 4 ports total.
ibstats shows all 4 ports
ibstat -l
mlx5_0
mlx5_1
mlx5_2
mlx5_3
ibdev2netdev -v
0000:17:00.0 mlx5_0 (MT4115 - MT1609X08073) CX456A - ConnectX-4 QSFP28 fw 12.22.1002 port 1 (ACTIVE) ==> ib0 (Up)
0000:17:00.1 mlx5_1 (MT4115 - MT1609X08073) CX456A - ConnectX-4 QSFP28 fw 12.22.1002 port 1 (ACTIVE) ==> ib1 (Up)
0000:65:00.0 mlx5_2 (MT4115 - MT1545X04735) CX456A - ConnectX-4 QSFP fw 12.22.1002 port 1 (ACTIVE) ==> ib2 (Down)
0000:65:00.1 mlx5_3 (MT4115 - MT1545X04735) CX456A - ConnectX-4 QSFP fw 12.22.1002 port 1 (ACTIVE) ==> ib3 (Down)
All 4 ports are active for the SRP protocol for storage.
There are scripts in /etc/sysconfig/network-scripts for “ifcfg-ib0” and “ifcfg-ib1” but not for devices ib2 and ib3.
How do you get the initial “ifcfg” scripts created for ib2 and ib3? The critical setting in these files is the UUID for the IPoIB device, which I don’t know how to query or generate.
I suspect there is a config file setting somewhere that needs to be set, but I can’t determine which configuration setting is limiting the IBoIP scan to only 2 devices.
There ARE entries in /sys/class/net for all for devices …ib0, ib1, ib2, and ib3:
ls -al /sys/class/net
total 0
drwxr-xr-x 2 root root 0 Apr 23 09:24 .
drwxr-xr-x 63 root root 0 Apr 23 08:28 …
lrwxrwxrwx 1 root root 0 Apr 23 09:24 em1 → …/…/devices/pci0000:00/0000:00:1f.6/net/em1
lrwxrwxrwx 1 root root 0 Apr 23 09:24 ib0 → …/…/devices/pci0000:16/0000:16:00.0/0000:17:00.0/net/ib0
lrwxrwxrwx 1 root root 0 Apr 23 09:24 ib1 → …/…/devices/pci0000:16/0000:16:00.0/0000:17:00.1/net/ib1
lrwxrwxrwx 1 root root 0 Apr 23 09:24 ib2 → …/…/devices/pci0000:64/0000:64:00.0/0000:65:00.0/net/ib2
lrwxrwxrwx 1 root root 0 Apr 23 09:24 ib3 → …/…/devices/pci0000:64/0000:64:00.0/0000:65:00.1/net/ib3
lrwxrwxrwx 1 root root 0 Apr 23 09:24 lo → …/…/devices/virtual/net/lo
lrwxrwxrwx 1 root root 0 Apr 23 09:24 p1p1 → …/…/devices/pci0000:b2/0000:b2:00.0/0000:b3:00.0/net/p1p1
lrwxrwxrwx 1 root root 0 Apr 23 09:24 p1p2 → …/…/devices/pci0000:b2/0000:b2:00.0/0000:b3:00.1/net/p1p2
Thanks for your help.
Follow-on … I found that the command “uuidgen” can be used to generate the UUIDs for ib2 and ib3 … and with this information I can create the ifcfg-ib2 and ifcfg-ib3 files
This should solve my problem, but does not identify why the files were not created in the first place.
