It turned out it was a power problem. I fixed it by supplying 3V3 to the module.
However I’m now getting kernel panic about in 2-3 seconds after I plug in ethernet cable to the module.
Anybody knows why this might be happening? I am attaching the driver I modified to use interrupts - based on MCP2515 example in this forum to make interrupts work - enc28j60.c (45.6 KB) The module does not work without it.
[ 48.329864] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 0
[ 48.337123] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.9.140-l4t-r32.4.2+ge3c8d1
[ 48.345400] Hardware name: NVIDIA Jetson Nano
[ 48.353150] Call trace:
[ 48.355621] [<ffffff800808c0a8>] dump_backtrace+0x0/0x178
[ 48.361037] [<ffffff800808c244>] show_stack+0x24/0x30
[ 48.366102] [<ffffff800844e758>] dump_stack+0x98/0xc0
[ 48.371168] [<ffffff80081bc5e0>] panic+0x118/0x27c
[ 48.375975] [<ffffff800817eeb8>] watchdog_nmi_enable+0x0/0x60
[ 48.381734] [<ffffff800817e064>] watchdog_timer_fn+0x8c/0x2a0
[ 48.387494] [<ffffff8008136c78>] __hrtimer_run_queues+0xf8/0x350
[ 48.393512] [<ffffff80081375b0>] hrtimer_interrupt+0xa8/0x1d8
[ 48.399273] [<ffffff8008bc79c0>] tegra210_timer_isr+0x38/0x48
[ 48.405033] [<ffffff800811fd98>] __handle_irq_event_percpu+0x60/0x280
[ 48.411487] [<ffffff800811ffe0>] handle_irq_event_percpu+0x28/0x70
[ 48.417679] [<ffffff8008120078>] handle_irq_event+0x50/0x80
[ 48.423265] [<ffffff8008123c4c>] handle_fasteoi_irq+0xc4/0x1a0
[ 48.429109] [<ffffff800811edcc>] generic_handle_irq+0x34/0x50
[ 48.434867] [<ffffff800811f49c>] __handle_domain_irq+0x6c/0xc0
[ 48.440711] [<ffffff8008080d2c>] gic_handle_irq+0x54/0xa8
[ 48.446121] [<ffffff8008082c28>] el1_irq+0xe8/0x194
[ 48.451013] [<ffffff8008b70274>] cpuidle_enter_state+0xec/0x380
[ 48.456945] [<ffffff8008b7057c>] cpuidle_enter+0x34/0x48
[ 48.462269] [<ffffff800810ff3c>] call_cpuidle+0x44/0x68
[ 48.467506] [<ffffff800811027c>] cpu_startup_entry+0x18c/0x210
[ 48.473354] [<ffffff8008092844>] secondary_start_kernel+0x13c/0x160
[ 48.479631] [<0000000080f271a4>] 0x80f271a4
[ 48.483827] SMP: stopping secondary CPUs
[ 48.487870] Kernel Offset: disabled
[ 48.491374] Memory Limit: none
[ 48.517301] Rebooting in 5 seconds..
Here is how dmesg looks:
root@jetson-nano-qspi-sd:~# dmesg | grep eth0
[ 6.344103] net eth0: enc28j60 driver registered
[ 16.793892] net eth0: link down
[ 16.797052] net eth0: multicast mode
[ 16.800750] net eth0: multicast mode
[ 16.804384] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.843407] net eth0: multicast mode
[ 16.847004] net eth0: multicast mode
[ 16.850574] net eth0: multicast mode
Here is what I modified in enc28j60.c:
diff --git a/drivers/net/ethernet/microchip/enc28j60.c b/drivers/net/ethernet/microchip/enc28j60.c
index 0a26b11ca8f6..bbfb9236693d 100644
--- a/drivers/net/ethernet/microchip/enc28j60.c
+++ b/drivers/net/ethernet/microchip/enc28j60.c
@@ -30,6 +30,10 @@
#include <linux/spi/spi.h>
#include <linux/of_net.h>
+#include <linux/of_gpio.h>
+#include <asm-generic/gpio.h>
#include "enc28j60_hw.h"
#define DRV_NAME "enc28j60"
@@ -1555,6 +1559,10 @@ static int enc28j60_probe(struct spi_device *spi)
const void *macaddr;
int ret = 0;
+ int gpio;
+ struct device_node *np = spi->dev.of_node;
if (netif_msg_drv(&debug))
dev_info(&spi->dev, DRV_NAME " Ethernet driver %s loaded\n",
DRV_VERSION);
@@ -1566,6 +1574,42 @@ static int enc28j60_probe(struct spi_device *spi)
priv = netdev_priv(dev);
+ /* If GPIO based interrupt is passed in device tree */
+ gpio = of_get_named_gpio(np, "interrupts", 0);
+ if (gpio < 0) {
+ dev_err(&spi->dev, "failed to get GPIO from device tree\n");
+ else {
+ ret = gpio_request(gpio, "enc28j60-gpio");
+ if (ret) {
+ dev_err(&spi->dev, "failed to request GPIO %d\n", gpio);
+ return ret;
+ ret = gpio_export(gpio, false);
+ if (ret) {
+ dev_err(&spi->dev, "failed to export GPIO %d\n", gpio);
+ return ret;
+ ret = gpio_direction_input(gpio);
+ if (ret) {
+ dev_err(&spi->dev, "failed to set pin to input state\n");
+ return -EINVAL;
+ /* IRQ setup */
+ ret = gpio_to_irq(gpio);
+ if (ret < 0) {
+ dev_err(&spi->dev, "failed to map GPIO to IRQ: %d\n", ret);
+ return -EINVAL;
+ spi->irq = ret;
priv->netdev = dev; /* priv to netdev reference */
priv->spi = spi; /* priv to spi reference */
priv->msg_enable = netif_msg_init(debug.msg_enable,
More info:
root@jetson-nano-qspi-sd:~# cat /proc/interrupts | grep enc
299: 0 0 0 0 GPIO 200 Edge enc28j60
Ifconfig (eth0 is the ENC28J60):
root@jetson-nano-qspi-sd:~# ifconfig
eth0 Link encap:Ethernet HWaddr 96:5F:7B:84:22:60
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:43
eth1 Link encap:Ethernet HWaddr 00:04:4B:E7:25:42
inet addr:192.168.1.24 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::204:4bff:fee7:2542/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:79 errors:0 dropped:0 overruns:0 frame:0
TX packets:57 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:10114 (9.8 KiB) TX bytes:6871 (6.7 KiB)
Interrupt:150 Base address:0xe000
I checked netdev: enc28j60 kernel panic fix. - Patchwork , no use.
