• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.5.0
• TensorRT Version 8.0.1.6
Can’t find anywhere .engine and calib.table after running DeepStream
Follow the guide https://docs.ultralytics.com/tutorials/nvidia-jetson/#int8-calibration with the INT8 calibration method (that is, compile the library with OPENCV flag=1).
The configuration files have been modified by me and are:
config_infer_primary_yoloV5.txt
enable-dla=1
use-dla-core=0
net-scale-factor=0.0039215697906911373
labelfile-path=labels_coco.txt
custom-network-config=./models/basic/yolov5n.cfg
model-file=./models/basic/yolov5n.wts
model-engine-file=./models/basic/yolov5n_b4_dla0_int8.engine
# model-engine-file=yolov5n6_ori_b1_dla0_int8.engine
# int8-calib-file=/home/watchbot/Repo/DeepStream-Yolo/calib.table
# int8-calib-file=calib.table
int8-calib-file=./models/basic/calib.table
batch-size=4
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
network-type=0
num-detected-classes=1
interval=0
gie-unique-id=1
cluster-mode=2
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseYolo
custom-lib-path=/home/watchbot/Repo/DeepStream-Yolo/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
# nms-iou-threshold=0.45 original value
pre-cluster-threshold=0.25
# pre-cluster-threshold=0.25 original value
topk=300
deepstream_app_config.txt
# Copyright (c) 2019-2021, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=5
camera-csi-sensor-id=0
camera-width=640
camera-height=360
camera-fps-n=10
camera-fps-d=1
camera-v4l2-dev-node=0
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=5
camera-csi-sensor-id=1
camera-width=640
camera-height=360
camera-fps-n=10
camera-fps-d=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=5
camera-csi-sensor-id=2
camera-width=640
camera-height=360
camera-fps-n=10
camera-fps-d=1
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=5
camera-csi-sensor-id=3
camera-width=640
camera-height=360
camera-fps-n=10
camera-fps-d=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
######[sink1]
######enable=0
######type=3
#######1=mp4 2=mkv
######container=1
#######1=h264 2=h265
######codec=1
######sync=0
#######iframeinterval=10
######bitrate=2000000
#######H264 Profile - 0=Baseline 2=Main 4=High
#######H265 Profile - 0=Main 1=Main10
######profile=0
######output-file=out.mp4
######source-id=0
######[sink2]
######enable=0
#######Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
######type=4
######codec=1
######sync=0
######bitrate=4000000
######profile=0
####### set below properties in case of RTSPStreaming
######rtsp-port=8554
######udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
buffer-pool-size=4
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
# model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
model-engine-file=models/basic/yolov5n_b4_dla0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV5.txt
[tests]
file-loop=0
Inside my Jetson, I am running the following command:
deepstream-app -c deepstream_app_config.txt
, inside
/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app
. Here I created a folder “models” and subfolders, depending on the trials I do. In this case, I am using pretrained YOLOV5-N weights, whose yolov5n.wts and yolov5n.cfg are located at
/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/models/basic
Everytime I run this, it says:
File does not exist: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/models/basic/calib.table
and begins loading images for calibration (which takes a while).
Once it finishes, it finally says:
Building complete
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/model_b4_dla0_int8.engine opened error
0:07:10.176037264 13062 0xc4a7920 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1942> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/model_b4_dla0_int8.engine
And despite it works successfully, after quitting, If I want to search the engine file I defined previously in my txt file, it is nowhere, same with the calibration file.
I need both files, what can I do?
Thank you for your time.
