Erroneous results in a loop
I am running the following code using PGI Openacc compiler on ubuntu 14.04.
Run as pgcc -V15.5 -acc fitzhugh_allSynapseTypes.c ; ./a.out
Enter grid size : 6
For testing purposes, for a loop of size 6x6, I am giving the same initial condition for every iteration of the loop and essentially should get the same result in the output for each iteration.
Serial code (without -acc during compilation ) gives the right result, whereas the accelerator gives the right result for all but the last four rows in the output.
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <sys/time.h>
#define N_EQ1		2
#define NP1		8
#define COUPLING_THRESHOLD	0. //
#define THRESHOLD_SLOPE		100. //
#pragma acc routine seq
double boltzmann(const double V, const double V_0, const double k)
	return 1./(1.+exp(-k*(V-V_0)));
void derivs_one_electricExcitatoryAndInhibitoryConnections(double* y, double* dxdt, const double* p)
	dxdt[0] = p[7]*(y[0]-y[0]*y[0]*y[0])-y[1]+p[0]; // x' = m (x-x^3)-y+I
	dxdt[1] = p[1]*(boltzmann(y[0], p[2], p[3])-y[1]); // y' = eps * (Bfun(x, x_0, k_2) - y)
This is different from integrate_n_rk4 in that it returns both V and X whereas integrate_n_rk4 returns just V
void integrate_one_rk4(double* y, const double* params, double* output, const double dt, const unsigned N, const unsigned stride)
	unsigned i, j, k;
	double dt2, dt6;
	double y1[N_EQ1], y2[N_EQ1], k1[N_EQ1], k2[N_EQ1], k3[N_EQ1], k4[N_EQ1];
	dt2 = dt/2.; dt6 = dt/6.;
	for(j=0; j<N_EQ1; j++) output[j] = y[j];
	for(i=1; i<N; i++)
		for(j=0; j<stride; j++)
			derivs_one_electricExcitatoryAndInhibitoryConnections(y, k1, params);
			for(k=0; k<N_EQ1; k++) y1[k] = y[k]+k1[k]*dt2;
			derivs_one_electricExcitatoryAndInhibitoryConnections(y1, k2, params);
			for(k=0; k<N_EQ1; k++) y2[k] = y[k]+k2[k]*dt2;
			derivs_one_electricExcitatoryAndInhibitoryConnections(y2, k3, params);
			for(k=0; k<N_EQ1; k++) y2[k] = y[k]+k3[k]*dt;
			derivs_one_electricExcitatoryAndInhibitoryConnections(y2, k4, params);
			for(k=0; k<N_EQ1; k++) y[k] += dt6*(k1[k]+2.*(k2[k]+k3[k])+k4[k]);
		for(j=0; j<N_EQ1; j++) output[N_EQ1*i+j] = y[j];
Computes the following derivatives for each neuron and also adds the input from other neurons :
     x' = m (x-x^3)-y+I
         n => number of neurons
         y => array with structure x0,y0,x1,y1,x2,y2,...x{n-1},y{n-1} for the above equations
         dydt => derivatives of y i.e., x0',y0',x1',y1',x2',y2'...x{n-1}',y{n-1}'
         p => parameter array storing NP1 parameters for each neuron i.e., p[0] to p[NP1-1] for x0',y0' followed by
                                p[NP] to p[2*NP-1] for x1',y1' and so on
         coupling_strengths_type => array of size n*n storing coupling strengths in the order (0->0),(0->1),(0->2) ... (0->n-1) followed by
                              (1->0),(1->1),(1->2),(1->3)...(1->n-1) and so on
     xi'_coupled = xi' + (E0_chlorine - xi) * ( coupling_strengths_chlorine(0->i)*bm_factor(x0) + coupling_strength_chlorine(1->i)*bm_factor(x1) + ... )
                    + (E0_potassium - xi) * ( coupling_strengths_potassium(0->i)*bm_factor(x0) + coupling_strength_potassium(1->i)*bm_factor(x1) + ... )
                    + (E0_sodium - xi) * ( coupling_strengths_sodium(0->i)*bm_factor(x0) + coupling_strength_sodium(1->i)*bm_factor(x1) + ... )
                    + (x0 - xi) * coupling_strengths_chlorine(0->i) + (x1 - xi) * coupling_strengths_chlorine(1->i) + ... ;
     yi'_coupled = yi'
     bm_factor here uses different k, x0 than in the computation of uncoupled y' ;
     A neuron j will influence neuron i only if it's voltage is above the threshold obtained from the boltzmann function; See bolzmann.py
     TODO : Instead of using three different arrays, should use a linked list for the coupling strengths; For each neuron 'i', the correspoinding linked list will contain nodes each having the presynaptic neuron number, synaptic strenght, and type of channel (or the channel's equilibrium potential); This improves performance from O(n^2) to O(E) where E is no.of edges or synaptic connections
void derivs_n_variablecoupling_electricExcitatoryAndInhibitoryConnections(const unsigned n, double* y, double* dydt,
                                const double* p, const double* coupling_strengths_chlorine, const double* coupling_strengths_potassium,
                                const double* coupling_strengths_sodium, const double* coupling_strengths_electric,
                                double* bm_factor)
	unsigned i, j;
	for(i=0;i <n; i++){
	    bm_factor[i] = boltzmann(y[i*N_EQ1], COUPLING_THRESHOLD, THRESHOLD_SLOPE);
		derivs_one_electricExcitatoryAndInhibitoryConnections(y+i*N_EQ1, dydt+i*N_EQ1, p+i*NP1);
	for(i=0; i<n; i++)
		double bm_factor_sum = 0;
		for(j=0;j<n;j++){
		//TODO : p[4] is E_Cl; p[5] is E_K; p[6] is E_Na;
		   dydt[i*N_EQ1] += ((p[4+i*NP1]-y[i*N_EQ1])*coupling_strengths_chlorine[j*n+i] +
		                        (p[5+i*NP1]-y[i*N_EQ1])*coupling_strengths_potassium[j*n+i] +
		                            (p[6+i*NP1]-y[i*N_EQ1])*coupling_strengths_sodium[j*n+i] )
		                             * bm_factor[j]
                             + (y[j*N_EQ1]-y[i*N_EQ1])*coupling_strengths_electric[j*n+i] ;
    This method finds the rk4 approximation of the curve for a system of 'n' neurons obeying the following equations :
         x' = m (x-x^3)-y+I
     networkSize => number of neurons
     coupling_strengths => array of size n*n storing coupling strengths in the order (0->0),(0->1),(0->2) ... (0->n-1) followed by
     output => array of size n*N in the following order x0,x1,...x{n-1} representing initial point on the curve
                        followed by x0-1,x1-1,...x{n-1}-1 representing the next point and so on
     dt => step size
     N => number of points to compute
     stride => number of strides to make while computing each of the N points
     also in the output for each time point 1 to N, check crossings for each neuron;
     for each neuron store all the crossings and also the number of crossings present;
     compute and return phase differences of all cells w.r.t the first cell phase differences
void integrate_n_rk4_phasedifferences_electricExcitatoryAndInhibitoryConnections(const unsigned networkSize,
                    const double* initial_state, const double* p,
                    double* output, double* phase_differences_output, unsigned* numberOfPhaseDifferences,
                    double* current_state, double* temp_state, double*k1, double*k2, double*k3, double*k4,
                    int* lastCrossings, int* numberOfCrossingsToEdit, double *bm_factor,
                    const double dt, const unsigned N, const unsigned stride, const unsigned initial_states_start) {
    unsigned i, j, m, point_dimension = networkSize*N_EQ1;
	int threshhold = 0, allCellsHadZeroPhaseBefore = 0, numberOfCrossingsUnedited = 0, phase_differences_output_index=0;
	for(m=0; m<point_dimension; m++){
	    current_state[m]=initial_state[m+initial_states_start];
	    if(m%2==0) {
	        output[m/2]=current_state[m];
	        lastCrossings[m/2]=N+1;
            numberOfCrossingsToEdit[m/2] = 0;
	for(i=1; i<N; i++)
			derivs_n_variablecoupling_electricExcitatoryAndInhibitoryConnections(networkSize, current_state, k1, p, coupling_strengths_chlorine, coupling_strengths_potassium, coupling_strengths_sodium, coupling_strengths_electric, bm_factor);
				temp_state[m] = current_state[m]+k1[m]*dt/2;
			derivs_n_variablecoupling_electricExcitatoryAndInhibitoryConnections(networkSize, temp_state, k2, p, coupling_strengths_chlorine, coupling_strengths_potassium, coupling_strengths_sodium, coupling_strengths_electric,bm_factor);
				temp_state[m] = current_state[m]+k2[m]*dt/2;
			derivs_n_variablecoupling_electricExcitatoryAndInhibitoryConnections(networkSize, temp_state, k3, p, coupling_strengths_chlorine, coupling_strengths_potassium, coupling_strengths_sodium, coupling_strengths_electric, bm_factor);
				temp_state[m] = current_state[m]+k3[m]*dt;
			derivs_n_variablecoupling_electricExcitatoryAndInhibitoryConnections(networkSize, temp_state, k4, p, coupling_strengths_chlorine, coupling_strengths_potassium, coupling_strengths_sodium, coupling_strengths_electric, bm_factor);
				current_state[m] += (k1[m]+2.*(k2[m]+k3[m])+k4[m])*dt/6;
            if(m%2==0) {
                //Outputs only voltages of each cell.
                output[i*point_dimension/2+m/2]=current_state[m];
                // computing the crossings here itself
                if(m==0){ // first cell
                    if(current_state[m]>=threshhold && output[(i-1)*point_dimension/2+m/2] < threshhold){
                        //implies a crossing in the first cell
                        if(!allCellsHadZeroPhaseBefore){
                            int allCellsHadZeroPhaseBefore1 = 1;
                            for(j=1;j<point_dimension/2;j++){
                                if(i<lastCrossings[j]) {
                                    allCellsHadZeroPhaseBefore1=0;
                            allCellsHadZeroPhaseBefore = allCellsHadZeroPhaseBefore1;
                        if(allCellsHadZeroPhaseBefore){
                                phase_differences_output[phase_differences_output_index*(point_dimension/2 -1) + j-1] = i - lastCrossings[j];
                                numberOfCrossingsToEdit[j]=numberOfCrossingsToEdit[j]+1;
                            phase_differences_output_index++;
                } else{ // cells other than first cell
                            lastCrossings[m/2]=i;
                        }else{
                            j=numberOfCrossingsToEdit[m/2];
                            while(j>0){
                                phase_differences_output[(phase_differences_output_index-j)*(point_dimension/2-1)+m/2-1]/=i-lastCrossings[m/2];
                                j--;
                            numberOfCrossingsToEdit[m/2]=0;
	    if(m%2==0) {
            if(numberOfCrossingsToEdit[m/2]>numberOfCrossingsUnedited){
                numberOfCrossingsUnedited = numberOfCrossingsToEdit[m/2];
    //number of the phase differences in the array
    *numberOfPhaseDifferences = phase_differences_output_index - numberOfCrossingsUnedited;
    Same as integrate_n_rk4_phasedifferences_electricExcitatoryAndInhibitoryConnections
    No need to return output array, so uses a cyclic array for output
void integrate_n_rk4_phasedifferences_nooutput_electricExcitatoryAndInhibitoryConnections(const unsigned networkSize,
	    if(m%2==0) {
	for(i=1; i<N; i++)
            if(m%2==0) {
                output[(i%2)*point_dimension/2+m/2]=current_state[m];
                    if(current_state[m]>=threshhold && output[((i-1)%2)*point_dimension/2+m/2] < threshhold){
                        }else{
                            while(j>0){
                                j--;
	    if(m%2==0) {
for an array of initial conditions, do everything in integrate_n_rk4_phasedifferences and return just the last point in phase differences trajectory for each initial condition
void sweeptraces_electricExcitatoryAndInhibitoryConnections(const long networkSize, const double* initial_states_array, const double* p,
                    double* trajectory_targets_phasedifferences,
                    const long noOfInitialStates, const double dt, const long N, const long stride) {
    int l,m, point_dimension = networkSize*N_EQ1;
    //double output[N*networkSize]; not working when 'output' copied privately since size exceeds 2.3GB for all threads together; As of pgcc v15.5
    //double output[N*networkSize*noOfInitialStates];
    //experimenting with stateless computations; not using full output array since we are only using phase_difference array; also making it private since
    // size won't be greater than 2.3GB anymore
    double output[2*networkSize];
    //double phase_differences_output[(networkSize-1)*(N/2+1)];
    double phase_differences_output[(networkSize-1)*(N/2+1)*noOfInitialStates];
    unsigned numberOfPhaseDifferences=0;
    double current_state[point_dimension], temp_state[point_dimension], k1[point_dimension], k2[point_dimension], k3[point_dimension], k4[point_dimension];
    int lastCrossings[point_dimension/2], numberOfCrossingsToEdit[point_dimension/2];
    double bm_factor[networkSize];
    struct timeval start_time, stop_time, elapsed_time;
    gettimeofday(&start_time,NULL);
	In order to avoid memory issues, the number of threads, regulated here by num_gangs(16) vector_length(128), could also be dynamic, based on the size of N*networkSize*noOfInitialStates .
	Also, for very large resolutions, say 150x150, rather than clogging memory and thereby slowing down everything, it is instead better to run in multiple batches of say, 50x50 -
	something that makes a reasonable use of GPU memory.
	/*#pragma omp parallel for \
        private(phase_differences_output,numberOfPhaseDifferences),\
        private(current_state,temp_state,k1,k2,k3,k4,lastCrossings,numberOfCrossingsToEdit),\
        private(bm_factor)*/
        //copy(output)
	private(output) ; not working for >2.3GB
	num_gangs(16) vector_length(128) ; Can set the maximum no.of parallel threads with this; Could adopt dynamically based on sizes but not worth the wait.
	                                                    Rather, if memory requirement's too great to be fulfilled, split the input array and run in batches
    #pragma acc parallel loop independent ,\
        pcopyin(initial_states_array[0:point_dimension*noOfInitialStates],p[0:NP1*networkSize],coupling_strengths_chlorine[0:networkSize*networkSize],coupling_strengths_potassium[0:networkSize*networkSize],coupling_strengths_sodium[0:networkSize*networkSize],coupling_strengths_electric[0:networkSize*networkSize]), \
        copy(trajectory_targets_phasedifferences[0:(networkSize-1)*noOfInitialStates]), \
        private(bm_factor),\
        private(output,numberOfPhaseDifferences),\
        copy(phase_differences_output)
	for (l=0;l<noOfInitialStates;l++){
        integrate_n_rk4_phasedifferences_nooutput(networkSize,initial_states_array, p, coupling_strengths,
                    output+l*N*networkSize, phase_differences_output, &numberOfPhaseDifferences,
                    lastCrossings,numberOfCrossingsToEdit,bm_factor,
                    dt, N, stride, l*point_dimension);
        integrate_n_rk4_phasedifferences_nooutput_electricExcitatoryAndInhibitoryConnections(networkSize,initial_states_array, p,
                    output, phase_differences_output+l*(networkSize-1)*(N/2+1), &numberOfPhaseDifferences,
        for(m=0;m<networkSize-1;m++){
	    if(numberOfPhaseDifferences>0)
            	trajectory_targets_phasedifferences[l*(networkSize-1)+m]=
                    phase_differences_output[(numberOfPhaseDifferences-1)*(networkSize-1)+m];
	printf("\n");
	for(l=0; l<noOfInitialStates;l++){
		for(m=0;m<networkSize-1;m++)printf("%f ",trajectory_targets_phasedifferences[l*(networkSize-1)+m]);
		printf("\n");
	fflush(stdout);
    gettimeofday(&stop_time,NULL);
    timersub(&stop_time, &start_time, &elapsed_time); // Unix time subtract routine
    printf("Total time was %f seconds.\n", elapsed_time.tv_sec+elapsed_time.tv_usec/1000000.0);
int main(){
	// test case for 6 cells
	double *initial_states_array;
	double p[] =    {0.4,0.3,0.,10.,-1.5,-1.2,1.5,1.,
	                0.4,0.3,0.,10.,-1.5,-1.2,1.5,1};
	double coupling_strengths_chlorine[] = {0.,0.001,0.001,0.001,0.001,0.,
                                            0.,0.001,0.001,0.001,0.001,0.};
	double *trajectory_targets_phasedifferences;
	void *ptr ;
	int i,j,n, networkSize = 6;
	printf("Enter size of grid\n");
	scanf("%d",&n);
	trajectory_targets_phasedifferences = (double*)malloc(5*n*n*sizeof(double));
	ptr = malloc(networkSize*N_EQ1*n*n*sizeof(double));
	if(!ptr)
		printf("malloc returns NULL\n");
		return 1;
	initial_states_array = (double*)ptr;
	double initial_state[] = {-0.026541128437339426, 0.07017957749966305, -0.026541128437339426, 0.07017957749966305, -0.026541128437339426, 0.07017957749966305, -0.026541128437339426,
	                            0.07017957749966305, -0.026541128437339426, 0.07017957749966305, -0.026541128437339426, 0.07017957749966305};
	for(i=0;i<n*n;i++){
		for(j=0;j<networkSize*N_EQ1;j++){
			initial_states_array[i*networkSize*N_EQ1+j]=initial_state[j];
	sweeptraces_electricExcitatoryAndInhibitoryConnections(networkSize, initial_states_array, p,
                    coupling_strengths_chlorine, coupling_strengths_chlorine, coupling_strengths_chlorine,
                    trajectory_targets_phasedifferences,n*n,
					(double)3/1000, 1006, 30);
Output with serial code :
 pgcc -V15.5  fitzhugh_allSynapseTypes.c; ./a.out
Enter size of grid
6
0.010684 0.010684 0.010684 0.010684 1.000000
Total time was 2.549745 seconds.
Output with accelerator code :
pgcc -V15.5 -acc  fitzhugh_allSynapseTypes.c; ./a.out
Enter size of grid
6
5.000000 5.000000 5.000000 5.000000 1.000000
Total time was 16.210918 seconds.
Last four rows in the above accelerator output are inaccurate. I have printed and verified that the input to each iteration is the same. And the dimensions of copy(trajectory_targets_phasedifferences[0:(networkSize-1)*noOfInitialStates]) also look fine.
Can you please help me understand what’s going wrong?
Hi Krishna,
I’ve spent several hours reviewing your code and don’t see what’s wrong. It seems to be a race condition once more than one warp is used. Though, I don’t see what’s causing it. Hence, I added a problem report (TPR#21818) and sent it on to our compiler engineers to see if they can track down the problem.
The work around I found is to limit your program to use a single warp. It wont be good for performance, but hopefully get you by until the root cause of the problem is found.
#pragma acc parallel loop num_gangs(1) vector_length(32)
I’ll continue to investigate as well as time permits.
  • Mat
Thanks, Mat, appreciate it.
Also, if it helps in debugging, this problem occurs only after I started passing four different parameter arrays to the functions - ‘coupling_strengths_chlorine’, ‘coupling_strengths_potassium’, ‘coupling_strengths_sodium’, ‘coupling_strengths_electric’.
The earlier version of the code had only one parameter array - ‘coupling_strengths’ and that was running fine and did not have this issue.
