Error Code 1: Myelin (Division by 0 detected in the shape graph. Tensor (Divisor) "sp__mye3" is equal to 0.; )
Tensort version : 8.6.2.3-1+cuda12.2
config_infer_primary_yoloV8_seg.txt :
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=yolov8s-seg.onnx
model-engine-file=yolov8s-seg.onnx_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=0
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=3
cluster-mode=4
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-instance-mask-func-name=NvDsInferParseYoloSeg
custom-lib-path=nvdsinfer_custom_impl_Yolo_seg/libnvdsinfer_custom_impl_Yolo_seg.so
output-instance-mask=1
segmentation-threshold=0.5
[class-attrs-all]
pre-cluster-threshold=0.25
topk=100
verbose=1
Error:
nvstreammux: Successfully handled EOS for source_id=0
ERROR: [TRT]: 1: [runner.cpp::shapeChangeHelper::621] Error Code 1: Myelin (Division by 0 detected in the shape graph. Tensor (Divisor) “sp__mye3” is equal to 0.; )
ERROR: Failed to enqueue trt inference batch
ERROR: Infer context enqueue buffer failed, nvinfer error:NVDSINFER_TENSORRT_ERROR
0:00:11.744366453 15239 0xaaab371ad600 WARN nvinfer gstnvinfer.cpp:1418:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
0:00:11.803543873 15239 0xaaab371ad600 WARN nvinfer gstnvinfer.cpp:1418:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
ERROR from primary_gie: Failed to queue input batch for inferencing
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1418): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
0:00:11.852672214 15239 0xaaab371ad600 WARN nvinfer gstnvinfer.cpp:1418:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
0:00:11.911965380 15239 0xaaab371ad600 WARN nvinfer gstnvinfer.cpp:1418:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
App run failed
Please use “trtexec” tool to generate the TensorRT engine first.
Close for duplicating with Error Code 1: Myelin (Division by 0 detected in the shape graph. Tensor (Divisor) “sp__mye3” is equal to 0.; )
