Hello, I have a problem launching games through Steam and Heroic Launcher.
If you run the game directly from the folder and close it, then all games start normally until the next reboot. Apparently this problem only occurs in steam flatpak, since RPM does not have this problem.
GPU: NVIDIA GeForce RTX 3060 Laptop GPU
Driver: 550.76
OS: Fedora 40 KDE (Wayland)
Perhaps this will be useful:
opened 04:02PM - 09 Apr 24 UTC
closed 01:42PM - 19 Apr 24 UTC
nvidia
not our bug
Since a week or so ago I keep encountering this error every time I try t… o launch a game from Heroic Launcher or Steam alike:
I'm on Fedora 39 (KDE Wayland) on a laptop with dedicated Nvidia GPU, and am not yet very proficient in the ways of Linux. I tried reinstalling Fedora several times (for this and other unrelated issues) and for a couple of days everything works flawlessly, but then breaks suddenly and without any evident reason. Searching online for answers I found that disabling the "Auto Install/Update DXVK on Prefix" and "Auto Install/Update VKD3D on Prefix" options on Heroic works as a rough patch; similarly, setting `PROTON_USE_WINED3D11=1 %COMMAND%` as a launch option on Steam, I manage to launch the games (albeit with major graphical glitches and performance impairments). I figured to ask here about it since the issue seems to be related to dxvk. Here is one of the games' log file after a launch attempt:
[game-LastPlay.log](https://github.com/doitsujin/dxvk/files/14920996/game-LastPlay.log)
Any help is appreciated as I really don't know how to approach this. Thanks
Edit: since I forgot to mention it, here's my system information.
- GPU: NVIDIA GTX 1650 Ti (Mobile)
- Driver: 550.67
- DXVK version: 2.3.1 (through Heroic Launcher and Steam flatpaks)
- OS: Fedora 39 (KDE spin, Wayland compositor)
Doesn't seem to be a Wayland-specific issue because the error pops up in X11 sessions too. Furthermore, sometimes (though rarely) upon booting up everything works without throwing any errors, and I can perfectly play my games.
Edit 2: I found a temporary solution that works really well for some reason. Before opening your preferred game launcher, you just need to run `sudo vulkaninfo`. After doing so every game runs flawlessly and the system behaves like there wasn't any error in the first place. I can't really wrap my head around it as of **why** it works, but I'm not complaining tbh
Edit3: Found a permanent solution, check my last comment!
Hello kind people, I recently installed Fedora 39 KDE on my laptop, which has a dedicated Nvidia Gtx 1650ti GPU. As I planned to game a fair bit on it, I installed the proprietary Nvidia drivers through rpmfusion and signed them to work with safe...
Reading time: 4 mins 🕑
Likes: 1 ❤
In version 550.78 everything is unchanged…
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
I’m sorry, I’ve attached it here
nvidia-bug-report.log.gz (396.8 KB)
As it turns out, this problem also occurs in Bottles.
Reading the github issue and the logfiles, I guess you should manually add the nvidia modules nvidia,nvidia-drm,nvidia-modeset to the initrd:
https://www.suse.com/de-de/support/kb/doc/?id=000019945
The instructions did not work because they are not suitable for Fedora. I added modules to the grub and modprobe load, but this did not bring any results, the error remains.
Mart
May 5, 2024, 9:17pm
7
I’m not a fedora user, but that’s what search engines are for:
For Fedora, just put the module name in /etc/modprobe.conf and run mkinitrd. See also Common kernel problems - Fedora Project Wiki .
Thank you for your “invaluable” help, only this is outdated documentation, and the current one is here: Working with Kernel Modules :: Fedora Docs . I did everything according to it, there was no effect.
UPD:
Still, I managed to add modules to the initrd, so I’ll follow the guide: Работа в системе — Неофициальный FAQ по Fedora (версия 2023.05.30)
But alas, the error remains…
nvidia-bug-report.log.gz (401.4 KB)
Please disable the simpledrm driver and check if that helps.
I specified nvidia-drm.modeset=1 in grub, the problem remained.
Please check flatpak for installed nvidia support:
flatpak list |grep nvidia
The problem is still present on driver 555.58.02.
A clean installation was performed for verification.
nvidia-bug-report.log.gz (417.1 KB)
