• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5.2
I have a pre trained PyTorch model which I convert to .onnx them .TRT. I have modified the config file according as below
model-file=/./facenet.trt
model-engine-file=/./facenet.trt_b30_gpu0_fp32.engine
labelfile-path=/./labels.txt
I’m sure about the directory however there’s no engine file in the directory.
The engine file creation showed the below error
EERROR: [TRT]: UffParser: Could not read buffer.
parseModel: Failed to parse UFF model
ERROR: Failed to build network, error in model parsing.
ERROR: [TRT]: 3: [builder.cpp::~Builder::307] Error Code 3: API Usage Error (Parameter check failed at: optimizer/api/builder.cpp::~Builder::307, condition: mObjectCounter.use_count() == 1. Destroying a builder object before destroying objects it created leads to undefined behavior.
ERROR: Failed to create network using custom network creation function
ERROR: Failed to get cuda engine from custom library API
0:00:04.930114170 5694 0xaaaad18654f0 ERROR nvinfer gstnvinfer.cpp:674:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1943> [UID = 2]: build engine file failed
ERROR: [TRT]: 2: [logging.cpp::decRefCount::65] Error Code 2: Internal Error (Assertion mRefCount > 0 failed. )
corrupted size vs. prev_size while consolidating
Aborted (core dumped)
please support
