Dear all
I havewe problem for the Digtis KITTY as follow :
caffe_output.log
[libprotobuf FATAL google/protobuf/stubs/common.cc:67] This program requires version 3.8.0 of the Protocol Buffer runtime library, but the installed version is 3.2.0. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "google/protobuf/descriptor.pb.cc".)
terminate called after throwing an instance of 'google::protobuf::FatalException'
what(): This program requires version 3.8.0 of the Protocol Buffer runtime library, but the installed version is 3.2.0. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "google/protobuf/descriptor.pb.cc".)
*** Aborted at 1565420534 (unix time) try "date -d @1565420534" if you are using GNU date ***
PC: @ 0x7fdcc4426428 gsignal
*** SIGABRT (@0x3e800005114) received by PID 20756 (TID 0x7fdcc67dc280) from PID 20756; stack trace: ***
@ 0x7fdcc44264b0 (unknown)
@ 0x7fdcc442802a abort
Someone can help me ,please.
