Error found in TX2 Boot: "nvdc: open: Permission denied" and ***NvRmMemInit failed***
This was actually a really good thing to do. Sometimes error messages are misleading. A perfect error message can sometimes require knowing about an error which occurs because we don’t know what the error is…a bit of a “Catch 22” as the phrase goes.
Normally I would actually expect to see log messages about duplicate symbols. “exec format error” in no way suggests this, but it might just be what the issue has been all along due to bad error messages. It is true that if there is a duplicate symbol, then insmod would fail, but the message should state this as the reason (versus exec format error). I think this might be why the original install instructions might provide a substitute option.ko module: A need to remove or edit symbols. I don’t know for sure, but this now seems very likely.
Editing what is actually in the source code would certainly work, although editing what is in the modules would in theory do the same thing (provided the changes needed were in code within modules). My main worry with changing the kernel itself is that if there is a normal kernel upgrade at some point, then it would be a more elaborate “fix” to rebuild everything as the kernel upgrades. The result of changing this in module format versus integrated in the kernel is the same, and the only difference is the convenience of what happens when you must repeat the process.
Be certain to save the working kernel source, binary, and modules in case you need to either reinstall the kernel after an unexpected update, or else want to recompile the changes into a new kernel release.
Additionally, when you modify the kernel source, you should also rebuild 100% of the modules and use a new/different “uname -r” (a change to “CONFIG_LOCALVERSION” to get modules to go to a new location different than the unmodified kernel would use). I don’t know if the changes you made could be in a module instead, but should it be only a module which changes, then you wouldn’t need to rebuild the other modules, nor would you need a new “uname -r” (the two go together).
Up until now I’ve not noticed the “usb_wwan: exports duplicate symbol usb_wwan_chars_in_buffer (owned by kernel)” message. I think the exec format error has prevented error messages from going that far. It would have saved a lot of time if the message had been stating this from the start.
Incidentally, you can find the name of the package owning a file, and put that package on hold. An example, to find the owner of “/boot/Image”, you can:
dpkg -S /boot/Image
Not all kernels for Jetsons are handled by packages, at least not in earlier releases. Later releases do put the kernel in a package since it is needed for OTA updates (which were not supported in earlier releases). However, let’s pretend the package owning “/boot/Image” is named (fictitiously) “jetson-kernel”. One could put this on hold from update:
echo 'jetson-kernel hold' | sudo dpkg --set-selections
Or remove it from hold:
echo 'jetson-kernel install' | sudo dpkg --set-selections
For more details on that see:
https://askubuntu.com/questions/18654/how-to-prevent-updating-of-a-specific-package
