Hi.
I’ve been trying to install them by compiling using two different methods, which I will explain further. Both compile the modules successfully but still yield exec format error when attempting to add them.
First is what you’ve suggested:
I was able to find a thread where you gave a more detailed explanation on how to do this (errror executing modules prepare)
So, I’ve installed the sources in /usr/sr via ./source_sync.sh -k tegra-l4t-r32.1. Now I have the full kernel source at /usr/src/sources/kernel/kernel-4.9.
In /lib/modules/$(uname -r) I changed where build points to, to point to the full kernel source. Looks something like this:
heifu@heifu-tx2-nx:/lib/modules/4.9.253-tegra
$ ls -l
total 1292
lrwxrwxrwx 1 root root 34 Oct 3 11:01 build -> /usr/src/sources/kernel/kernel-4.9
Now, inside build (which is pointing to the full kernel sources), I did:
sudo make mrproper
sudo make tegra_defconfig
I’m not sure the correct way of setting the LOCALVERSION, so I tried two different ways, one was simply export LOCALVERSION=-tegra, and the other way was to manually edit the generated .config file and change CONFIG_LOCALVERSION to CONFIG_LOCALVERSION="-tegra".
Either way, after setting CONFIG_LOCALVERSION to -tegra, I did sudo make modules_prepare. No problems until here.
Now I run this very straight forward install script (also provided by waveshare but with slight changes to just make and install both modules):
cd option
make
mv /lib/modules/$(uname -r)/kernel/drivers/usb/serial/option.ko /lib/modules/$(uname -r)/kernel/drivers/usb/serial/option_bk.ko
cp option.ko /lib/modules/$(uname -r)/kernel/drivers/usb/serial/
cd ..
cd qmi_wwan_simcom
make
cp qmi_wwan_simcom.ko /lib/modules/$(uname -r)/kernel/drivers/net/usb
cd ..
depmod
modprobe option
modprobe qmi_wwan_simcom
modprobe -r qmi_wwan_simcom
Which outputs (hopefully it’s not too big of a text dump):
make -C /lib/modules/4.9.253-tegra/build -I ./usb_wwan SUBDIRS=/home/heifu/Sim8200_for_jetsonnano/option modules
make[1]: Entering directory '/usr/src/sources/kernel/kernel-4.9'
WARNING: Symbol version dump ./Module.symvers
is missing; modules will have no dependencies and modversions.
CC [M] /home/heifu/Sim8200_for_jetsonnano/option/option.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/heifu/Sim8200_for_jetsonnano/option/option.mod.o
LD [M] /home/heifu/Sim8200_for_jetsonnano/option/option.ko
make[1]: Leaving directory '/usr/src/sources/kernel/kernel-4.9'
rm -rf *.o *~ core .depend .*.cmd *.ko *.mod.c .tmp_versions Module.* modules.order
make -C /lib/modules/4.9.253-tegra/build M=/home/heifu/Sim8200_for_jetsonnano/qmi_wwan_simcom modules
CC [M] /home/heifu/Sim8200_for_jetsonnano/qmi_wwan_simcom/qmi_wwan_simcom.o
MODPOST 1 modules
CC /home/heifu/Sim8200_for_jetsonnano/qmi_wwan_simcom/qmi_wwan_simcom.mod.o
LD [M] /home/heifu/Sim8200_for_jetsonnano/qmi_wwan_simcom/qmi_wwan_simcom.ko
modprobe: ERROR: could not insert 'option': Exec format error
modprobe: ERROR: could not insert 'qmi_wwan_simcom': Exec format error
There’s a warning for each module build, not sure how important or relevant it is for the process.
It is indeed building with the full sources, as far as I can tell, and also I am not (intentionally) cross compiling it anywhere. I’m really not sure at this point if I setup something wrong or if there’s another problem.
If, for example, i run the cmd file for one of the modules I get:
file option.ko
option.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=dd94366b76bb65de18c801b075540f05d4f5d52d, with debug_info, not stripped
Which, unless I’m overlooking something, tell’s me it is compiled for the correct architecture, which would imply that ARCH=arm64 was specified at some point for this not to work.
I’m really not sure how to go on from here.
For the second method
Here I tried to actually cross compile the modules, but now on my actual work machine, which is linux 20.04, x86_64. My idea was, if it was somehow cross compiling inside the jetson with native tools, let’s try to actually cross compile it from a different architecture.
So I basically did the same, I setup the environment for cross compiling (which I’ve done before for compiling the actual kernel sources). I setup a directory with the full kernel sources, ran the same setup, same commands (only now I’m explicitly providing the env variables CROSS_COMPILE=/usr/bin/aarch64-linux-gnu- ARCH=arm64 LOCALVERSION=-tegra.
It compiles with some warnings (Not sure how important they are, i’ll just attach the compile logs):
crosscompile_logs.txt (5.1 KB)
and I confirmed the module is indeed for aarch64
file option.ko
option.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=94c395ed44a856871b01bf3d7e71adcdce1340e0, with debug_info, not stripped
So I moved these modules, cross compiled in my x86_64 machine, to the jetson, tried to install them but still I get the exec format error.
I’m not sure if this would work (though in my mind it should, since now, while I’m cross compiling, i’m not doing it with native tools so, from what I understood from you, should’ve been fine) but still couldn’t do it.
I insisted more on the first method, since it’s what you’ve actually recommended but I can’t get it to work. Not sure if you can spot something I did wrong or might’ve missed but either way, I think I still need some help here.
Hopefully this makes sense, I’m not very knowledgeable here but I think I’ve been understanding your points so far, but I’m still not able to get this to work.
Thank you so much for your help so far.
Francisco.
